    Spotify module newbi
    9 Posts 2 Posters 2.7k Views 2 Watching
      berne @sdetweil
      @sdetweil said in Spotify module newbi:
      @berne said in Spotify module newbi:
      MMM-NowPlayingOnSpotify
      ok, from the MagicMirror/modules folder do
      ls
      it will list the folders and files…
      linux is case sensitive
      $ cd /home/pi/MagicMirror/modules
      pi@raspberrypi:~/MagicMirror/modules $ ls
      default MMM-NowPlayingonSpotify node_modules package-lock.json README.md
      EDIT: i can see all the files in /home/pi/MagicMirror/Moduels/MMM-NowPlayingSpotify
      EDIT2 pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingonSpotify $
      get the same result
      EDIT3
      i went to pi@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingonSpotify and then write npm install. i think thaht works:S
        berne
        i@raspberrypi:~/MagicMirror/modules/MMM-NowPlayingonSpotify $ npm install
        npm WARN deprecated socks@1.1.10: If using 2.x branch, please upgrade to at least 2.1.6 to avoid a serious bug with socket data flow and an import issue introduced in 2.1.0
        npm notice created a lockfile as package-lock.json. You should commit this file.
        added 675 packages from 771 contributors and audited 4894 packages in 216.211s
        found 27 vulnerabilities (2 low, 5 moderate, 20 high)
        run npm audit fix to fix them, or npm audit for details
          berne
          98:11 error Parsing error: Unexpected token, expected ";" 96 | { 97 | module: "MMM-NowPlayingOnSpotify", > 98 | position: "top_left", | ^ 99 | 100 | config: { 101 | clientID: "431313e344ta464erfef3c0812323235c9232äå"
          When i now trying to boot MM , i cant find any config, if i have use the java liner to chek it, got this?
            sdetweil @berne
            @berne can u show us what you added to config… seems a missing comma probably
              berne @sdetweil
              yes, u have done some thing i Home assistent, but this semms alot harder, when pasteing code, i did a new intall, Think i will do the spotify to morrow
