    Simple Text that reads a .txt file
    15 Posts 2 Posters 6.1k Views 2 Watching
      sdetweil @Jackkt
      @Jackkt you need to use the node_helper module to launch your python script, and capture the output of the python script… then send that up to the module.js via sendSocketNotification…
      then the module needs to signal updateDom() to tell MM there is new content, and it will call back at getDom() to get the new content, where u format your html to be shown.
      node_helper
      const { exec } = require('child_process');
      exec('python your_script', (error, stdout, stderr) => {
        if (error) {
          console.error(`exec error: ${error}`);
          return;
        console.log(`stdout: ${stdout}`);
         this.sendSocketNotification('some id string', stdout);
        console.log(`stderr: ${stderr}`);
      module.js
         if( notification ==='some id string') {
         var save_payload=payload)
         this.updateDom(1000)
      getDom: function (){
         create the html here using save_payload)
         return created_html
         MM will inject the html in the div for your module
      you can use my sample module for starters…
      https://github.com/sdetweil/SampleModule
      check out the difference between exec (one time) and spawn (send multiple responses over time)
      J 1 Reply Last reply
        Jackkt @sdetweil
        @sdetweil Thanks for the response. Im having trouble making the module(I have no experience and the "Head first developing MM module for extreme beginner"didnt work). Also The python script can run in the background and can output into a .txt file. Can I just edit helloworld to just print the thing in the text file? Sorry if this is stupid.
          Jackkt @Jackkt
          @Jackkt Also the text file updates every 5 seconds by the results of the python script
            sdetweil @Jackkt
            @Jackkt if the python script can be changed to just write to the screen, you can use spawn instead. And it can send u info every time it writes
              Jackkt @sdetweil
              @sdetweil Hey, I get a syntax error from “const { exec } = require(‘child_process’); unexpected token {” its the one before exec. Get the same from spawn.
                Jackkt @Jackkt
                @Jackkt Also without the {} the error is “unexpected identifier” for
                “spawn”
                  sdetweil @Jackkt
                  @Jackkt that leading quote shouldn’t be there
                    Jackkt @sdetweil
                    @sdetweil I was just quoting sorry it looks like:
                    and
                    const exec = require(‘child_process’);
                      sdetweil @Jackkt
                      @Jackkt ok. I just cut/pasted it from a working module.
                      When posting code or config in the forum, please use the markup syntax. 3 backticks (key left of number 1) before your content on a separate line
                      And 3 more after on a separate line
                      S J 2 Replies Last reply
                        @sdetweil also, it doesn’t just go anywhere… I didn’t give u exact code, but close
                          Jackkt @sdetweil
                          @sdetweil What module was that working module? Sorry im just not good at this stuff so I rather cut down a working module then make my own.
                          S 2 Replies Last reply
                            sdetweil @Jackkt
                            @Jackkt I don’t remember. I am away til Sunday.
                              sdetweil @Jackkt
                              @Jackkt come to the discord chat and I will post you a zip file with a display of repeating data from a background python process. I am sam, $5710
                                Jackkt
                                It works, thank you soo much.
