    Simple Text that reads a .txt file
    15 Posts 2 Posters 5.9k Views 2 Watching
      Jackkt @sdetweil
      @sdetweil Hey, I get a syntax error from “const { exec } = require(‘child_process’); unexpected token {” its the one before exec. Get the same from spawn.
        Jackkt @Jackkt
        @Jackkt Also without the {} the error is “unexpected identifier” for
        “spawn”
          sdetweil @Jackkt
          @Jackkt that leading quote shouldn’t be there
            Jackkt @sdetweil
            @sdetweil I was just quoting sorry it looks like:
            and
            const exec = require(‘child_process’);
              sdetweil @Jackkt
              @Jackkt ok. I just cut/pasted it from a working module.
              When posting code or config in the forum, please use the markup syntax. 3 backticks (key left of number 1) before your content on a separate line
              And 3 more after on a separate line
              S J 2 Replies Last reply Reply Quote 1
                @sdetweil also, it doesn’t just go anywhere… I didn’t give u exact code, but close
                  Jackkt @sdetweil
                  @sdetweil What module was that working module? Sorry im just not good at this stuff so I rather cut down a working module then make my own.
                    sdetweil @Jackkt
                    @Jackkt I don’t remember. I am away til Sunday.
                      sdetweil @Jackkt
                      @Jackkt come to the discord chat and I will post you a zip file with a display of repeating data from a background python process. I am sam, $5710
                        Jackkt
                        It works, thank you soo much.
