Solved My MagicMirror screen keeps turning off
@EhsanMomeni81 does the tv or monitor have a power off function? Sleep maybe?
120 minutes seems a long time for a screensaver or so.
Normally that would be 5 to 15 minutes.Which exact file did you edit?
There are, for example, multiple autostart files on your system and only one of them will work, depending on your debian version.
To locate them:sudo find / -name autostart -type f
@sdetweil It’s the official RPi 7" screen, and what I can see no power off/sleep function
@evroom
I edited the autostart which was stated in the MagicMirror guidesudo nano /etc/xdg/lxsession/LXDE/autostart
@EhsanMomeni81
For Debian buster that seems to be right.
For Debian stretch it is/home/pi/.config/lxsession/LXDE-pi/autostart
On my Debian buster Pi with official RPI 7 inch screen, I have this for screen off after15 minutes.
So, your xset settings seem right; have them like that on my other MagiMirror install (on Debian stretch) too.pi@raspberrypi:~ $ cat /etc/xdg/lxsession/LXDE-pi/autostart @lxpanel --profile LXDE-pi @pcmanfm --desktop --profile LXDE-pi @xscreensaver -no-splash point-rpi @xset s 900 @xset s blank @xset -dpms
@sdetweil made install scripts, so I guess he knows a bit more.
@evroom not for screen stuff yet
@evroom
Sorry, but Debian buster and Debian stretch?I have a cronjob to turn off the screen at 11 pm until 6 am, which works, but other than that I want the screen to be on. Is it possible to change 900 to 61 200 (17 h) instead?
@EhsanMomeni81 said in My MagicMirror screen keeps turning off:
I guess you downloaded and installed an image with Debian, like from
https://www.raspberrypi.org/downloads/raspbian/
Debian Buster is the latest Debian version.With
lsb_release -a
you can find out which version you have.If your cronjob works for turning on / off the screen, then I guess you do not need to use the @xset parameters to turn off the screen.
This is what I currently have:
For Debain Stretch (screen always on):
$ cat /home/pi/.config/lxsession/LXDE-pi/autostart @lxpanel --profile LXDE-pi @pcmanfm --desktop --profile LXDE-pi @xscreensaver -no-splash @point-rpi @unclutter -display :0 -idle 3 -root -noevents @xset s noblank @xset s off @xset -dpms
For Debian Buster (screen off after 900 seconds):
Not sure what the other entries do, I just appended the @xset lines to the existing entries.
Will try what happens when I remove them a bit later. -
@evroom said in My MagicMirror screen keeps turning off:
To answer myself.
lxpanel 0.10.0-2+rpt4 armhf LXDE panel pcmanfm 1.3.1-1+rpt7 armhf extremely fast and lightweight file manager point-rpi 0.20160905 armhf Locate the mouse pointer over the menu button xscreensaver - not installed
Using Debian Buster and a RPI 7 inch display, these settings should work for ‘screen always on’:
@point-rpi # locate the mouse pointer over the menu button @xset s off # don't activate screensaver @xset -dpms # disable DPMS (Energy Star) features. @xset s noblank # don't blank the video device
I left
@point-rpi
as it sounds useful somehow; for screensaver settings not needed though.
Will test it now. -
Talking to myself :-)
The settings for Buster are not working.
My display goes to sleep after 10 minutes.
Perhaps because it isn’t a HDMI connected monitor.I found 2 interesting files though:
pi@raspberrypi:~ $ ls -als /home/pi/.xsession-errors 4 -rw------- 1 pi pi 2426 Aug 1 12:30 /home/pi/.xsession-errors pi@raspberrypi:~ $ ls -als /home/pi/.cache/lxsession/LXDE-pi/run.log 20 -rw------- 1 pi pi 17988 Aug 1 12:30 /home/pi/.cache/lxsession/LXDE-pi/run.log
Also see that this file is being used, so that seems right:
