    My MagicMirror screen keeps turning off
    20 Posts 4 Posters 9.1k Views 4 Watching
    • evroomE Offline
      evroom @EhsanMomeni81
      @EhsanMomeni81
      120 minutes seems a long time for a screensaver or so.
      Normally that would be 5 to 15 minutes.
      Which exact file did you edit?
      There are, for example, multiple autostart files on your system and only one of them will work, depending on your debian version.
      To locate them:
      sudo find / -name autostart -type f
      MagicMirror version: 2.33.0
      Test environment:
      MagicMirror version: v2.33.0
      • E Offline
        EhsanMomeni81 @sdetweil
        @sdetweil It’s the official RPi 7" screen, and what I can see no power off/sleep function
        • E Offline
          EhsanMomeni81 @evroom
          @evroom
          I edited the autostart which was stated in the MagicMirror guide
          sudo nano /etc/xdg/lxsession/LXDE/autostart
          • evroomE Offline
            @EhsanMomeni81
            For Debian buster that seems to be right.
            For Debian stretch it is
            /home/pi/.config/lxsession/LXDE-pi/autostart
            On my Debian buster Pi with official RPI 7 inch screen, I have this for screen off after15 minutes.
            So, your xset settings seem right; have them like that on my other MagiMirror install (on Debian stretch) too.
            pi@raspberrypi:~ $ cat /etc/xdg/lxsession/LXDE-pi/autostart
            @lxpanel --profile LXDE-pi
            @pcmanfm --desktop --profile LXDE-pi
            @xscreensaver -no-splash
            point-rpi
            @xset s 900
            @xset s blank
            @xset -dpms
            @sdetweil made install scripts, so I guess he knows a bit more.
            Test environment:
            S E 2 Replies Last reply Reply Quote 0
              sdetweil @evroom
              @evroom not for screen stuff yet
              • E Offline
                @evroom
                Sorry, but Debian buster and Debian stretch?
                I have a cronjob to turn off the screen at 11 pm until 6 am, which works, but other than that I want the screen to be on. Is it possible to change 900 to 61 200 (17 h) instead?
                • evroomE Offline
                  evroom
                  @EhsanMomeni81 said in My MagicMirror screen keeps turning off:
                  I guess you downloaded and installed an image with Debian, like from
                  https://www.raspberrypi.org/downloads/raspbian/
                  Debian Buster is the latest Debian version.
                  With lsb_release -ayou can find out which version you have.
                  If your cronjob works for turning on / off the screen, then I guess you do not need to use the @xset parameters to turn off the screen.
                  This is what I currently have:
                  For Debain Stretch (screen always on):
                  $ cat /home/pi/.config/lxsession/LXDE-pi/autostart
                  @point-rpi
                  @unclutter -display :0 -idle 3 -root -noevents
                  @xset s noblank
                  @xset s off
                  @xset -dpms
                  For Debian Buster (screen off after 900 seconds):
                  point-rpi
                  @xset s 900
                  @xset s blank
                  @xset -dpms
                  Not sure what the other entries do, I just appended the @xset lines to the existing entries.
                  Will try what happens when I remove them a bit later.
                  Test environment:
                  • evroomE Offline
                    evroom @evroom
                    @evroom said in My MagicMirror screen keeps turning off:
                    To answer myself.
                    lxpanel        0.10.0-2+rpt4 armhf        LXDE panel
                    pcmanfm        1.3.1-1+rpt7 armhf        extremely fast and lightweight file manager
                    point-rpi      0.20160905   armhf        Locate the mouse pointer over the menu button
                    xscreensaver - not installed
                    Using Debian Buster and a RPI 7 inch display, these settings should work for ‘screen always on’:
                    @point-rpi          # locate the mouse pointer over the menu button
                    @xset s off         # don't activate screensaver
                    @xset -dpms         # disable DPMS (Energy Star) features.
                    @xset s noblank     # don't blank the video device
                    I left @point-rpias it sounds useful somehow; for screensaver settings not needed though.
                    Will test it now.
                    Test environment:
                    • evroomE Offline
                      evroom @evroom
                      @evroom
                      Talking to myself :-)
                      The settings for Buster are not working.
                      My display goes to sleep after 10 minutes.
                      Perhaps because it isn’t a HDMI connected monitor.
                      I found 2 interesting files though:
                      pi@raspberrypi:~ $ ls -als /home/pi/.xsession-errors
                      4 -rw------- 1 pi pi 2426 Aug  1 12:30 /home/pi/.xsession-errors
                      pi@raspberrypi:~ $ ls -als /home/pi/.cache/lxsession/LXDE-pi/run.log
                      20 -rw------- 1 pi pi 17988 Aug  1 12:30 /home/pi/.cache/lxsession/LXDE-pi/run.log
                      Also see that this file is being used, so that seems right:
                      Test environment:
                      • evroomE Offline
                        evroom @evroom
                        @evroom
                        This works (running for 100 minutes at the moment of posting):
                        $ sudo nano /etc/xdg/lxsession/LXDE-pi/autostart
                        @touch /home/pi/.started_etc_xdg_lxsession_LXDE-pi_autostart
                        @point-rpi
                        @xset -dpms
                        @xset s off
                        @xset s noblank
                        Note: the autostart file does not like comments.
                        Reboot:
                        $ sudo reboot
                        After reboot is finished, check:
                        $ ls -als /home/pi/.started_etc_xdg_lxsession_LXDE-pi_autostart
                        That will tell if the autostart file was used (timestamp should match reboot time).
                        Then check for set errors:
                        $ grep xset /home/pi/.cache/lxsession/LXDE-pi/run.log
                        It should say 3 times Launching xset, with 3 times exit 0 (for every set entry in the autostart file).
                        Works for Raspberry Pi 7" Touchscreen Display.
                        $ lsb_release -a
                        No LSB modules are available.
                        Distributor ID:	Raspbian
                        Description:	Raspbian GNU/Linux 10 (buster)
                        Release:	10
                        Codename:	buster
                        Test environment:
