Raspberry Pi Memory Loss
17 Posts 3 Posters 5.6k Views 3 Watching
    dazza120
    Hi not sure if anyone else with a pi has noticed but the longer the Magic Mirror runs the more ram it uses for exactly the same thing it started up with, ie start up MagicMirror and I have 80% memory free four hours later and it’s 78% still not bad but a day later then it’s 58% memory free. This is on a Pi 4 with 4Gb of ram so I’m not sure how all the other Pi’s and other mirrors are doing but it seems to tear up a lot of memory. Anyone able to offer any help in this area?
    E 1 Reply Last reply Jul 30, 2019, 2:44 PM Reply Quote 0
    • E Offline
      evroom @dazza120
      @dazza120
      how do you determine free memory?
      With the later Linux distros it becomes easy to jump to wrong conclusions and there are several settings involved. that can influence it.
      MagicMirror version: 2.30.0
      Test environment:
      MagicMirror version: v2.30.0
      D 1 Reply Last reply Jul 30, 2019, 3:53 PM Reply Quote 0
        dazza120 @evroom
        @evroom I’m using mmm-SystemStats to view it on the magic mirror, unless this is monitoring the memory wrong?
        E 1 Reply Last reply Jul 30, 2019, 5:36 PM Reply Quote 0
        • E Offline
          evroom @dazza120
          @dazza120
          This modules uses the free command to determine memory usage.
          It does free / total times 100 %.
          But free (the value) does not take into account the shared memory, cache and buffers used by the system.
          It would be better to use the available value.
          This value tells you how much memory is available to start a new application.
          See man free for some more details.
          Modern Linux is making more and more advanced use of memory and swap techniques, making it more and more difficult to determine certain values.
          Test environment:
          E 1 Reply Last reply Jul 30, 2019, 5:49 PM Reply Quote 0
          • E Offline
            evroom @evroom
            @evroom
            In node_helper.js you could change line 67.
            Change $4 into $7.
            Then observe if you see the same behavior.
            Test environment:
            D 3 Replies Last reply Jul 30, 2019, 8:59 PM Reply Quote 1
              dazza120 @evroom
              @evroom changed it thanks I’ll continue the test much appreciated
                dazza120 @evroom
                @evroom hi it’s still declining but a lot slower, I’ll let it continue and see if the mirror locks up if it reaches 0%
                  dazza120 @evroom
                  @evroom yeah it just died, MagicMirror crashed showing the black screen, when MacicMirror was restarted boom 80% free memory. So now I’ve got watchdog on for hopefully when it crashes it will restart with 80% memory
                  E 1 Reply Last reply Aug 1, 2019, 10:41 PM Reply Quote 0
                    jsteel715
                    Have you tried running top or (htop if installed) from a terminal cli to see which process(es) are using up the memory?
                    • E Offline
                      evroom @dazza120
                      @dazza120
                      Could you send the output of the following commands, when running more or less normal?
                      free
                      swapon -s
                      vmstat 5 10
                      top -b -o +%MEM | head -n 22
                      And the suggested htop command is also nice to look at.
                      Might need to be installed separately.
                      Test environment:
                      D 1 Reply Last reply Aug 2, 2019, 6:54 PM Reply Quote 0
