    Error code EADDRINUSE
    41 Posts 3 Posters 17.6k Views 3 Watching
      PXNDA
        sdetweil @PXNDA
        @PXNDA there is a field called filter, center … there should be a lot of info in the console…
        the very top row, elements, console, sources, network, …
          sdetweil @PXNDA
          @PXNDA not the word all, next to it there is a drop down says default levels
            PXNDA
            Same thing:
            Electron Security Warning (Insecure Content-Security-Policy)
            This renderer process has either no Content Security
            Policy set or a policy with “unsafe-eval” enabled. This exposes users of
            this app to unnecessary security risks.
            For more information and help, consult
            https://electronjs.org/docs/tutorial/security.
            This warning will not show up
            once the app is packaged.
              sdetweil @PXNDA
              @PXNDA ok… kill mirror
              then from the MagicMirror folder do
              npm start &
              there should be a stream of info , like this
              > magicmirror@2.8.0 start /home/pi/MagicMirror
              > sh run-start.sh
              Starting MagicMirror: v2.8.0
              Loading config ...
              Loading module helpers ...
              handler helper in init
              Module helper loaded: MMM-SleepWake
              Module helper loaded: MMM-ImagesPhotos
              Module helper loaded: MMM-voice
              Module helper loaded: WaterLevels
              All module helpers loaded.
              Starting server on port 8086 ...
              Server started ...
              Connecting socket for: MMM-SleepWake
              handler helper in start
              Connecting socket for: MMM-ImagesPhotos
              Starting node helper for: MMM-ImagesPhotos
              Connecting socket for: MMM-voice
              Starting module helper: MMM-voice
              Connecting socket for: WaterLevels
              Starting module: WaterLevels
              Launching application.
              then u should see any messages from the node_modules…
                PXNDA
                Will this work with Git Bash? This is what I’m using.
                  PXNDA
                  Tried it twice got this
                  npm ERR! code ELIFECYCLE
                  npm ERR! errno ENOENT
                  npm ERR! syscall spawn
                  npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
                  npm ERR! spawn ENOENT
                  npm ERR!
                  npm ERR! Failed at the magicmirror@2.8.0 start script.
                  npm ERR!     C:\Users\user1\AppData\Roaming\npm-cache\_logs\2019-07-30T19_47_00_790Z-debug.log
                    PXNDA
                    Starts fine without the &
                      sdetweil @PXNDA
                      @PXNDA no idea
                        PXNDA
                        I think the sh script may have become corrupt. Thank you anyway @sdetweil for sticking up to the mess I made of MM.
                          sdetweil @PXNDA
                          @PXNDA well, if u found it thats all that matters
                            PXNDA
                            I’ve tracked the problem to the address. I’ve changed it from localhost to 0.0.0.0. Any ideas why.
                              PXNDA
                              Ok, I’ve figured that Electron only accepts https certified addresses so how can i fix that.
                                sdetweil @PXNDA
                                @PXNDA electron does not do https unless u do a lot of extra work
                                  PXNDA
                                  I mean that Electron won’t accept 0.0.0.0
                                    PXNDA
                                    It works fine with localhost.
                                      PXNDA
                                      I’m trying to use MMM-Remote-Control.
                                        sdetweil @PXNDA
                                        @PXNDA that just says listen anywhere (all adapters)
                                        localhost means ONLY localhost, ONLY from THAT machine to THAT machine
                                        external machines should not be able to connect
                                        with 0.0.0.0 you also need to open the whitelist (allowed sources) , by default NO other ip address (localhost only still)…
                                        RemoteControl ois listening on the MM ip address (using the express server and routes/(paths in the url)
                                        so if ONLY localhost then cannot connect from outside the pi)… makes ;remote ’ control pretty hard…
                                          PXNDA
                                          I’ve also done that, no change.
                                          S mumblebajM 2 Replies Last reply Reply Quote 0
                                            sdetweil @PXNDA
                                            @PXNDA is this windows? Open the firewall on 8080
                                            • 2 / 3
