    Error code EADDRINUSE
    41 Posts 3 Posters 18.3k Views 3 Watching
      PXNDA
      same thing:
      C:\Users\user1\MagicMirror\node_modules\electron\dist\resources\electron.asar\renderer\security-warnings.js:184
      Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
      Policy set or a policy with “unsafe-eval” enabled. This exposes users of
      this app to unnecessary security risks.
      For more information and help, consult
      https://electronjs.org/docs/tutorial/security.
      This warning will not show up
      once the app is packaged.
      warnAboutInsecureCSP @ C:\Users\user1\MagicMirror\node_modules\electron\dist\resources\electron.asar\renderer\security-warnings.js:184
        sdetweil @PXNDA
        @PXNDA change the filter from defaults to all
          PXNDA
          What do you mean?
            PXNDA
              sdetweil @PXNDA
              @PXNDA there is a field called filter, center … there should be a lot of info in the console…
              the very top row, elements, console, sources, network, …
                sdetweil @PXNDA
                @PXNDA not the word all, next to it there is a drop down says default levels
                  PXNDA
                  Same thing:
                    sdetweil @PXNDA
                    @PXNDA ok… kill mirror
                    then from the MagicMirror folder do
                    npm start &
                    there should be a stream of info , like this
                    > magicmirror@2.8.0 start /home/pi/MagicMirror
                    > sh run-start.sh
                    Starting MagicMirror: v2.8.0
                    Loading config ...
                    Loading module helpers ...
                    handler helper in init
                    Module helper loaded: MMM-SleepWake
                    Module helper loaded: MMM-ImagesPhotos
                    Module helper loaded: MMM-voice
                    Module helper loaded: WaterLevels
                    All module helpers loaded.
                    Starting server on port 8086 ...
                    Server started ...
                    Connecting socket for: MMM-SleepWake
                    handler helper in start
                    Connecting socket for: MMM-ImagesPhotos
                    Starting node helper for: MMM-ImagesPhotos
                    Connecting socket for: MMM-voice
                    Starting module helper: MMM-voice
                    Connecting socket for: WaterLevels
                    Starting module: WaterLevels
                    Launching application.
                    then u should see any messages from the node_modules…
                      PXNDA
                      Will this work with Git Bash? This is what I’m using.
                        PXNDA
                        Tried it twice got this
                        npm ERR! code ELIFECYCLE
                        npm ERR! errno ENOENT
                        npm ERR! syscall spawn
                        npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
                        npm ERR! spawn ENOENT
                        npm ERR!
                        npm ERR! Failed at the magicmirror@2.8.0 start script.
                        npm ERR!     C:\Users\user1\AppData\Roaming\npm-cache\_logs\2019-07-30T19_47_00_790Z-debug.log
                          PXNDA
                          Starts fine without the &
                            sdetweil @PXNDA
                            @PXNDA no idea
                              PXNDA
                              I think the sh script may have become corrupt. Thank you anyway @sdetweil for sticking up to the mess I made of MM.
                                sdetweil @PXNDA
                                @PXNDA well, if u found it thats all that matters
                                  PXNDA
                                  I’ve tracked the problem to the address. I’ve changed it from localhost to 0.0.0.0. Any ideas why.
                                    PXNDA
                                    Ok, I’ve figured that Electron only accepts https certified addresses so how can i fix that.
                                      sdetweil @PXNDA
                                      @PXNDA electron does not do https unless u do a lot of extra work
                                        PXNDA
                                        I mean that Electron won’t accept 0.0.0.0
                                          PXNDA
                                          It works fine with localhost.
                                            PXNDA
                                            I’m trying to use MMM-Remote-Control.
                                            • 2 / 3
