    Error code EADDRINUSE
    41 Posts 3 Posters 18.3k Views 3 Watching
      PXNDA
      Starts fine without the &
        sdetweil @PXNDA
        @PXNDA no idea
          PXNDA
          I think the sh script may have become corrupt. Thank you anyway @sdetweil for sticking up to the mess I made of MM.
            sdetweil @PXNDA
            @PXNDA well, if u found it thats all that matters
              PXNDA
              I’ve tracked the problem to the address. I’ve changed it from localhost to 0.0.0.0. Any ideas why.
                PXNDA
                Ok, I’ve figured that Electron only accepts https certified addresses so how can i fix that.
                  sdetweil @PXNDA
                  @PXNDA electron does not do https unless u do a lot of extra work
                    PXNDA
                    I mean that Electron won’t accept 0.0.0.0
                      PXNDA
                      It works fine with localhost.
                        PXNDA
                        I’m trying to use MMM-Remote-Control.
                          sdetweil @PXNDA
                          @PXNDA that just says listen anywhere (all adapters)
                          localhost means ONLY localhost, ONLY from THAT machine to THAT machine
                          external machines should not be able to connect
                          with 0.0.0.0 you also need to open the whitelist (allowed sources) , by default NO other ip address (localhost only still)…
                          RemoteControl ois listening on the MM ip address (using the express server and routes/(paths in the url)
                          so if ONLY localhost then cannot connect from outside the pi)… makes ;remote ’ control pretty hard…
                            PXNDA
                            I’ve also done that, no change.
                            S mumblebajM 2 Replies Last reply Reply Quote 0
                              sdetweil @PXNDA
                              @PXNDA is this windows? Open the firewall on 8080
                                PXNDA
                                • mumblebajM
                                  mumblebaj Module Developer @PXNDA
                                  @PXNDA It was suggested with the v2.8 update that anybody running Electron should update to the latest Raspbian version prior to upgrading to v2.8. Have you updated your Raspbian to the latest version?
                                    PXNDA
                                    I’ve opened a new rule on firewall for port 8080 @sdetweil and there is no change. @mumblebaj I’m using Windows 10.
                                      sdetweil @PXNDA
                                      @PXNDA ok, change the config.js port to something else, 8090 for example
                                      • 2 / 3
