    Error code EADDRINUSE
    41 Posts 3 Posters 17.1k Views 3 Watching
      PXNDA
      Same thing:
      Electron Security Warning (Insecure Content-Security-Policy)
      This renderer process has either no Content Security
      Policy set or a policy with “unsafe-eval” enabled. This exposes users of
      this app to unnecessary security risks.
      For more information and help, consult
      https://electronjs.org/docs/tutorial/security.
      This warning will not show up
      once the app is packaged.
        sdetweil @PXNDA
        @PXNDA ok… kill mirror
        then from the MagicMirror folder do
        npm start &
        there should be a stream of info , like this
        > magicmirror@2.8.0 start /home/pi/MagicMirror
        > sh run-start.sh
        Starting MagicMirror: v2.8.0
        Loading config ...
        Loading module helpers ...
        handler helper in init
        Module helper loaded: MMM-SleepWake
        Module helper loaded: MMM-ImagesPhotos
        Module helper loaded: MMM-voice
        Module helper loaded: WaterLevels
        All module helpers loaded.
        Starting server on port 8086 ...
        Server started ...
        Connecting socket for: MMM-SleepWake
        handler helper in start
        Connecting socket for: MMM-ImagesPhotos
        Starting node helper for: MMM-ImagesPhotos
        Connecting socket for: MMM-voice
        Starting module helper: MMM-voice
        Connecting socket for: WaterLevels
        Starting module: WaterLevels
        Launching application.
        then u should see any messages from the node_modules…
          PXNDA
          Will this work with Git Bash? This is what I’m using.
            PXNDA
            Tried it twice got this
            npm ERR! code ELIFECYCLE
            npm ERR! errno ENOENT
            npm ERR! syscall spawn
            npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
            npm ERR! spawn ENOENT
            npm ERR!
            npm ERR! Failed at the magicmirror@2.8.0 start script.
            npm ERR!     C:\Users\user1\AppData\Roaming\npm-cache\_logs\2019-07-30T19_47_00_790Z-debug.log
              PXNDA
              Starts fine without the &
                sdetweil @PXNDA
                @PXNDA no idea
                  PXNDA
                  I think the sh script may have become corrupt. Thank you anyway @sdetweil for sticking up to the mess I made of MM.
                    sdetweil @PXNDA
                    @PXNDA well, if u found it thats all that matters
                      PXNDA
                      I’ve tracked the problem to the address. I’ve changed it from localhost to 0.0.0.0. Any ideas why.
                        PXNDA
                        Ok, I’ve figured that Electron only accepts https certified addresses so how can i fix that.
                          sdetweil @PXNDA
                          @PXNDA electron does not do https unless u do a lot of extra work
                            PXNDA
                            I mean that Electron won’t accept 0.0.0.0
                              PXNDA
                              It works fine with localhost.
                                PXNDA
                                I’m trying to use MMM-Remote-Control.
                                  sdetweil @PXNDA
                                  @PXNDA that just says listen anywhere (all adapters)
                                  localhost means ONLY localhost, ONLY from THAT machine to THAT machine
                                  external machines should not be able to connect
                                  with 0.0.0.0 you also need to open the whitelist (allowed sources) , by default NO other ip address (localhost only still)…
                                  RemoteControl ois listening on the MM ip address (using the express server and routes/(paths in the url)
                                  so if ONLY localhost then cannot connect from outside the pi)… makes ;remote ’ control pretty hard…
                                    PXNDA
                                    I’ve also done that, no change.
                                    S mumblebajM 2 Replies Last reply Reply Quote 0
                                      sdetweil @PXNDA
                                      @PXNDA is this windows? Open the firewall on 8080
                                        PXNDA
                                        • mumblebajM Offline
                                          mumblebaj Module Developer @PXNDA
                                          @PXNDA It was suggested with the v2.8 update that anybody running Electron should update to the latest Raspbian version prior to upgrading to v2.8. Have you updated your Raspbian to the latest version?
                                            PXNDA
                                            I’ve opened a new rule on firewall for port 8080 @sdetweil and there is no change. @mumblebaj I’m using Windows 10.
                                            • 2 / 3
