    Error code EADDRINUSE
    41 Posts 3 Posters 19.1k Views 3 Watching
      PXNDA
      No, and i only have that warning.
        PXNDA
          select the console tab… you are on the elements tab
            PXNDA
            same thing:
            C:\Users\user1\MagicMirror\node_modules\electron\dist\resources\electron.asar\renderer\security-warnings.js:184
            Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
            Policy set or a policy with “unsafe-eval” enabled. This exposes users of
            this app to unnecessary security risks.
            For more information and help, consult
            https://electronjs.org/docs/tutorial/security.
            This warning will not show up
            once the app is packaged.
            warnAboutInsecureCSP @ C:\Users\user1\MagicMirror\node_modules\electron\dist\resources\electron.asar\renderer\security-warnings.js:184
              sdetweil @PXNDA
              @PXNDA change the filter from defaults to all
                PXNDA
                What do you mean?
                  PXNDA
                    sdetweil @PXNDA
                    @PXNDA there is a field called filter, center … there should be a lot of info in the console…
                    the very top row, elements, console, sources, network, …
                      sdetweil @PXNDA
                      @PXNDA not the word all, next to it there is a drop down says default levels
                        PXNDA
                        Same thing:
                          sdetweil @PXNDA
                          @PXNDA ok… kill mirror
                          then from the MagicMirror folder do
                          npm start &
                          there should be a stream of info , like this
                          > magicmirror@2.8.0 start /home/pi/MagicMirror
                          > sh run-start.sh
                          Starting MagicMirror: v2.8.0
                          Loading config ...
                          Loading module helpers ...
                          handler helper in init
                          Module helper loaded: MMM-SleepWake
                          Module helper loaded: MMM-ImagesPhotos
                          Module helper loaded: MMM-voice
                          Module helper loaded: WaterLevels
                          All module helpers loaded.
                          Starting server on port 8086 ...
                          Server started ...
                          Connecting socket for: MMM-SleepWake
                          handler helper in start
                          Connecting socket for: MMM-ImagesPhotos
                          Starting node helper for: MMM-ImagesPhotos
                          Connecting socket for: MMM-voice
                          Starting module helper: MMM-voice
                          Connecting socket for: WaterLevels
                          Starting module: WaterLevels
                          Launching application.
                          then u should see any messages from the node_modules…
                            PXNDA
                            Will this work with Git Bash? This is what I’m using.
                              PXNDA
                              Tried it twice got this
                              npm ERR! code ELIFECYCLE
                              npm ERR! errno ENOENT
                              npm ERR! syscall spawn
                              npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
                              npm ERR! spawn ENOENT
                              npm ERR!
                              npm ERR! Failed at the magicmirror@2.8.0 start script.
                              npm ERR!     C:\Users\user1\AppData\Roaming\npm-cache\_logs\2019-07-30T19_47_00_790Z-debug.log
                                PXNDA
                                Starts fine without the &
                                  sdetweil @PXNDA
                                  @PXNDA no idea
                                    PXNDA
                                    I think the sh script may have become corrupt. Thank you anyway @sdetweil for sticking up to the mess I made of MM.
                                      sdetweil @PXNDA
                                      @PXNDA well, if u found it thats all that matters
                                        PXNDA
                                        I’ve tracked the problem to the address. I’ve changed it from localhost to 0.0.0.0. Any ideas why.
                                          PXNDA
                                          Ok, I’ve figured that Electron only accepts https certified addresses so how can i fix that.
                                            sdetweil @PXNDA
                                            @PXNDA electron does not do https unless u do a lot of extra work
                                            • 2 / 3
