    Error code EADDRINUSE
    41 Posts 3 Posters 19.1k Views 3 Watching
      sdetweil @PXNDA
      @PXNDA not the word all, next to it there is a drop down says default levels
        PXNDA
        Same thing:
        Electron Security Warning (Insecure Content-Security-Policy)
        This renderer process has either no Content Security
        Policy set or a policy with “unsafe-eval” enabled. This exposes users of
        this app to unnecessary security risks.
        For more information and help, consult
        https://electronjs.org/docs/tutorial/security.
        This warning will not show up
        once the app is packaged.
          sdetweil @PXNDA
          @PXNDA ok… kill mirror
          then from the MagicMirror folder do
          npm start &
          there should be a stream of info , like this
          > magicmirror@2.8.0 start /home/pi/MagicMirror
          > sh run-start.sh
          Starting MagicMirror: v2.8.0
          Loading config ...
          Loading module helpers ...
          handler helper in init
          Module helper loaded: MMM-SleepWake
          Module helper loaded: MMM-ImagesPhotos
          Module helper loaded: MMM-voice
          Module helper loaded: WaterLevels
          All module helpers loaded.
          Starting server on port 8086 ...
          Server started ...
          Connecting socket for: MMM-SleepWake
          handler helper in start
          Connecting socket for: MMM-ImagesPhotos
          Starting node helper for: MMM-ImagesPhotos
          Connecting socket for: MMM-voice
          Starting module helper: MMM-voice
          Connecting socket for: WaterLevels
          Starting module: WaterLevels
          Launching application.
          then u should see any messages from the node_modules…
            PXNDA
            Will this work with Git Bash? This is what I’m using.
              PXNDA
              Tried it twice got this
              npm ERR! code ELIFECYCLE
              npm ERR! errno ENOENT
              npm ERR! syscall spawn
              npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
              npm ERR! spawn ENOENT
              npm ERR!
              npm ERR! Failed at the magicmirror@2.8.0 start script.
              npm ERR!     C:\Users\user1\AppData\Roaming\npm-cache\_logs\2019-07-30T19_47_00_790Z-debug.log
                PXNDA
                Starts fine without the &
                  sdetweil @PXNDA
                  @PXNDA no idea
                    PXNDA
                    I think the sh script may have become corrupt. Thank you anyway @sdetweil for sticking up to the mess I made of MM.
                      sdetweil @PXNDA
                      @PXNDA well, if u found it thats all that matters
                        PXNDA
                        I’ve tracked the problem to the address. I’ve changed it from localhost to 0.0.0.0. Any ideas why.
                          PXNDA
                          Ok, I’ve figured that Electron only accepts https certified addresses so how can i fix that.
                            sdetweil @PXNDA
                            @PXNDA electron does not do https unless u do a lot of extra work
                              PXNDA
                              I mean that Electron won’t accept 0.0.0.0
                                PXNDA
                                It works fine with localhost.
                                  PXNDA
                                  I’m trying to use MMM-Remote-Control.
                                    sdetweil @PXNDA
                                    @PXNDA that just says listen anywhere (all adapters)
                                    localhost means ONLY localhost, ONLY from THAT machine to THAT machine
                                    external machines should not be able to connect
                                    with 0.0.0.0 you also need to open the whitelist (allowed sources) , by default NO other ip address (localhost only still)…
                                    RemoteControl ois listening on the MM ip address (using the express server and routes/(paths in the url)
                                    so if ONLY localhost then cannot connect from outside the pi)… makes ;remote ’ control pretty hard…
                                      PXNDA
                                      I’ve also done that, no change.
                                      S mumblebajM 2 Replies Last reply
                                        sdetweil @PXNDA
                                        @PXNDA is this windows? Open the firewall on 8080
                                          PXNDA
                                          • mumblebajM
                                            mumblebaj Module Developer @PXNDA
                                            @PXNDA It was suggested with the v2.8 update that anybody running Electron should update to the latest Raspbian version prior to upgrading to v2.8. Have you updated your Raspbian to the latest version?
                                            • 2 / 3
