    Error code EADDRINUSE
    41 Posts 3 Posters 18.3k Views 3 Watching
      sdetweil @PXNDA
      @PXNDA ok… kill mirror
      then from the MagicMirror folder do
      npm start &
      there should be a stream of info , like this
      > magicmirror@2.8.0 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.8.0
      Loading config ...
      Loading module helpers ...
      handler helper in init
      Module helper loaded: MMM-SleepWake
      Module helper loaded: MMM-ImagesPhotos
      Module helper loaded: MMM-voice
      Module helper loaded: WaterLevels
      All module helpers loaded.
      Starting server on port 8086 ...
      Server started ...
      Connecting socket for: MMM-SleepWake
      handler helper in start
      Connecting socket for: MMM-ImagesPhotos
      Starting node helper for: MMM-ImagesPhotos
      Connecting socket for: MMM-voice
      Starting module helper: MMM-voice
      Connecting socket for: WaterLevels
      Starting module: WaterLevels
      Launching application.
      then u should see any messages from the node_modules…
        PXNDA
        Will this work with Git Bash? This is what I’m using.
          PXNDA
          Tried it twice got this
          npm ERR! code ELIFECYCLE
          npm ERR! errno ENOENT
          npm ERR! syscall spawn
          npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
          npm ERR! spawn ENOENT
          npm ERR!
          npm ERR! Failed at the magicmirror@2.8.0 start script.
          npm ERR!     C:\Users\user1\AppData\Roaming\npm-cache\_logs\2019-07-30T19_47_00_790Z-debug.log
            PXNDA
            Starts fine without the &
              sdetweil @PXNDA
              @PXNDA no idea
                PXNDA
                I think the sh script may have become corrupt. Thank you anyway @sdetweil for sticking up to the mess I made of MM.
                  sdetweil @PXNDA
                  @PXNDA well, if u found it thats all that matters
                    PXNDA
                    I’ve tracked the problem to the address. I’ve changed it from localhost to 0.0.0.0. Any ideas why.
                      PXNDA
                      Ok, I’ve figured that Electron only accepts https certified addresses so how can i fix that.
                        sdetweil @PXNDA
                        @PXNDA electron does not do https unless u do a lot of extra work
                          PXNDA
                          I mean that Electron won’t accept 0.0.0.0
                            PXNDA
                            It works fine with localhost.
                              PXNDA
                              I’m trying to use MMM-Remote-Control.
                                sdetweil @PXNDA
                                @PXNDA that just says listen anywhere (all adapters)
                                localhost means ONLY localhost, ONLY from THAT machine to THAT machine
                                external machines should not be able to connect
                                with 0.0.0.0 you also need to open the whitelist (allowed sources) , by default NO other ip address (localhost only still)…
                                RemoteControl ois listening on the MM ip address (using the express server and routes/(paths in the url)
                                so if ONLY localhost then cannot connect from outside the pi)… makes ;remote ’ control pretty hard…
                                  PXNDA
                                  I’ve also done that, no change.
                                  S mumblebajM 2 Replies Last reply Reply Quote 0
                                    sdetweil @PXNDA
                                    @PXNDA is this windows? Open the firewall on 8080
                                      PXNDA
                                      • mumblebajM
                                        mumblebaj Module Developer @PXNDA
                                        @PXNDA It was suggested with the v2.8 update that anybody running Electron should update to the latest Raspbian version prior to upgrading to v2.8. Have you updated your Raspbian to the latest version?
                                          PXNDA
                                          I’ve opened a new rule on firewall for port 8080 @sdetweil and there is no change. @mumblebaj I’m using Windows 10.
                                            sdetweil @PXNDA
                                            @PXNDA ok, change the config.js port to something else, 8090 for example
                                            • 2 / 3
