    MMM-TelegramBot error
    13 Posts 3 Posters 3.8k Views 3 Watching
      sdetweil @Stoffbeuteluwe
      @Stoffbeuteluwe what does it say?
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @sdetweil
        @sdetweil it says the same
          @Stoffbeuteluwe ok, try this in the MagicMirror folder
          sudo chown -R patrickhahn *.*
          • StoffbeuteluweS
            it is still the same error
              @Stoffbeuteluwe sorry, dumb
              in the users home folder, not from MagicMirror…
              my mistake
              cd ~
              StoffbeuteluweS 2 Replies Last reply Reply Quote 0
              • StoffbeuteluweS
                @sdetweil it is the same…I will try again tomorrow thank you
                • StoffbeuteluweS
                  @sdetweil now I have a new install off MM but still the same problem. Maybe the module doesn’t work on Mac
                    A Former User @Stoffbeuteluwe
                    @Stoffbeuteluwe
                    It works on OSX well (Basically all my magicmirror modules were developed on MacBookPro)
                    I agree to @sdetweil . You might have made a mistake to use sudo on making your environment.
                    To solve this problem
                    • delete your npm cache
                    • reset the permissions of your /Users/patrickhah/.npm
                    https://docs.npmjs.com/getting-started/fixing-npm-permissions
                    https://docs.npmjs.com/troubleshooting/try-clearing-the-npm-cache
                    Or try this;
                    sudo npm cache clean -f
                    • StoffbeuteluweS
                      Stoffbeuteluwe Project Sponsor @Guest
                      @Sean what I doing wrong when installing magic mirror or npm
                      -I do the manual install…from MM site
                      -I download node js and install
                      • I install pm2
                      • than I install modules
                      • StoffbeuteluweS
                        @Sean works thank you 🙏
                        With your input, this post could be even better đź’—
