    EADDRINUSE assistant not working
    7 Posts 2 Posters 1.7k Views 2 Watching
      siddhartha
      Starting MagicMirror: v2.8.0
      Loading config …
      Loading module helpers …
      Module helper loaded: MMM-AlexaPi
      Module helper loaded: MMM-NetworkConnection
      No helper found for module: MMM-iFrame.
      No helper found for module: MMM-page-indicator.
      Module helper loaded: MMM-MusicOnDemand
      Module helper loaded: MMM-AssistantMk2
      Module helper loaded: MMM-Hotword
      Module helper loaded: MMM-NotificationTrigger
      No helper found for module: MMM-pages.
      All module helpers loaded.
      Starting server on port 8080 …
      Server started …
      Starting module: newsfeed
      Connecting socket for: MMM-AlexaPi
      Starting node helper for: MMM-AlexaPi
      Connecting socket for: MMM-NetworkConnection
      MMM-NetworkConnection helper started …
      Connecting socket for: MMM-MusicOnDemand
      Connecting socket for: MMM-AssistantMk2
      Connecting socket for: MMM-Hotword
      [HOTWORD] MMM-Hotword starts
      Connecting socket for: MMM-NotificationTrigger
      Sockets connected & modules started …
      Whoops! There was an uncaught exception…
      { Error: listen EADDRINUSE 0.0.0.0:8080
      at Server.setupListenHandle [as _listen2] (net.js:1330:14)
      at listenInCluster (net.js:1378:12)
      at doListen (net.js:1492:7)
      at process._tickCallback (internal/process/next_tick.js:63:19)
      at Function.Module.runMain (internal/modules/cjs/loader.js:755:11)
      at startup (internal/bootstrap/node.js:241:19)
      at bootstrapNodeJSCore (internal/bootstrap/node.js:579:3)
      errno: ‘EADDRINUSE’,
      code: ‘EADDRINUSE’,
      syscall: ‘listen’,
      address: ‘0.0.0.0’,
      port: 8080 }
      Launching application.
      n^CShutting down server…
      Stopping module helper: updatenotification
      Stopping module helper: calendar
      Stopping module helper: newsfeed
      Stopping module helper: MMM-AlexaPi
      Stopping module helper: MMM-NetworkConnection
        Something else is using port 8080. Are u using pm2?
        pm2 list
        pm2 stop 0 ( or it’s name from the list)
          siddhartha
          yes i am using pm2 .
          any idea how can i make assistantmk2 to use some other port ??
            siddhartha
            @siddhartha said in EADDRINUSE assistant not working:
            these 4 module wants to connect to 8080 port but its already being used by remote control so what can i do now?
              sdetweil @siddhartha
              @siddhartha they should be using the MagicMirror port, so not a problem
              Are two MagicMirrors trying to run at the same time?
              pm2 list
                siddhartha
                nope just one.
                  @siddhartha while you think nothing is running do
                  ps -ef | grep node
                  Does that produce more than 1 line of output?
