    MMM-ImageSlideshow Showing images from a USB drive
    13 Posts 3 Posters 8.5k Views 5 Watching
      MYLE-01
      wanted to show off Photos that I had a a usb stick
      So I plug in my USB 16gb Stick with a photos on then
      The Stick name is call FRAME cool I can see the files
      in my MMM-ImageSlideshow folder add the folder call USB
      know terminal window write this
      ln -s /media/pi /home/pi/MagicMirror/modules/MMM-ImageSlideshow/USB
      now that create a short cut in the USB folder ( windows man HERE LOL)
      I drill down into it
      got the full path and
      and change the config to match
      		module: 'MMM-ImageSlideshow',
      		position: 'center',
      		// ln -s /media/pi /home/pi/MagicMirror/modules/MMM-ImageSlideshow/USB
      			imagePaths: ['modules/MMM-ImageSlideshow/USB/pi/FRAME'],
      			fixedImageHeight: 500
      hope this help some one
      only day 3 into this magic mirror still
      want rounded concers
      add this to the custom.css
      .MMM-ImageSlideshow .module-content img {
        border-radius: 15px;
      makes
        MYLE-01
        Starting to remeber all my html stuff
          -moz-box-shadow: 2px 2px 2px #ccc;
        	-webkit-box-shadow: 2px 2px 2px #ccc;
        	-khtml-box-shadow: 2px 2px 2px #ccc;
        will add a 3d white frame around the images
          MwMagicMirror
          I’ve configured ImageSlideshow accordingly however I do not get any photos to display, I get a box the correct size and a little icon in the upper left of the box.
          These are photos I have been using for months in Google Photos, the example photos do not display either.
          I have the width and height both set to 600
          Any Ideas
          MM
            sdetweil @MwMagicMirror
            @MwMagicMirror open the developers window, ctrl-shift-i, select the console tab, and then scroll up to see any errors. Usually red text
            what is the exact config path for the images?
              MwMagicMirror
              Hmm
              Failed to load resource: The server responded with a status of 404 Not Found
              I tried giving it the full path, that didnt work either.
                                position: 'top_center',
                                fixedImageWidth: 600,
                                fixedImageHeight: 600,
                                //imagePaths: ['modules/MMM-ImageSlideshow/example1']
                                imagePaths: ['/home/pi/MagicMirror/modules/MMM-ImageSlideshow/exampleImages']
                @MwMagicMirror if u leave out the imagePaths config entry it defaults to
                 imagePaths: [ 'modules/MMM-ImageSlideshow/exampleImages' ],
                the web server is already using /home/pi/MagicMirror as its root, so no explicit full path will work.
                and u are specifying a folder in all cases…
                the path is case sensitive
                  MwMagicMirror
                  Perfect
                  I’m following now, working as advertised.
                  tyvm
                    MwMagicMirror @sdetweil
                    I do have one question.
                    All of my pictures have the proper orientation when viewed on my windows PC, however when copied over to my MM some of them are not oriented correctly.
                    Anyone know the reason or if there is a fix?
                    I really like the ImageSlideShow, I feel like it gives me more control over the Google Photo version.
                    MM
                      @MwMagicMirror sadly the browser doesn’t honor the orientation setting in the images…
                      i had a few like that and had to edit the image to force the correct orientation
                      there are a couple of libraries that could be used, but they are really pretty big.
                      I use MMM-ImagesPhotos
                        Hey Sam,
                        Hows the weather down there in TX, We are originally from the Dallas area. Miss TX alot.
                        Yea the picture orientation is a show stoppper for me, I have a hard time convincing my wife that she likes the mirror in the bathroom…lol
                        What is MMM-ImagesPhotos? I dont see it on the Builders site.
                          @MwMagicMirror Texas is hot this time of year. 104 for next 2 weeks they say.
                          I am near Austin.
                          I find modules on GitHub.
                          It’s another image display tool
                            Just an FYI I did get all my photos to display correctly after using:
                            xnconvert from:
                            http://www.xnconvert.com
                            I selected ALL my photos and in the Actions section I selected Clear Meta data. I cleared everything but from a little research I believe I only needed to clear the EXIF data.
                            Anyway it worked.
                            MM
                              @MwMagicMirror thanks for that great info!
