    MMM-AssistantMk2
    421 Posts 61 Posters 796.8k Views 57 Watching
    • O
      otto
      i just what to check so if this is right or wrong before i try it:S
      https://pastebin.com/m4d4nhJH
      on line 20 i get this: ‘arrow function syntax (=>)’ is only available in ES6 (use ‘esversion: 6’).
      on line 21 i get this: Missing semicolon.
      is this anyting i need to change?
      O S 2 Replies Last reply
      • O
        otto @otto
        @otto said in MMM-AssistantMk2:
        i got this when i was trying to start it:
        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
        Expected directory: electron-v3.1-linux-arm-glibc
        Found: [node-v64-linux-arm-glibc]
        This problem can often be fixed by running “npm rebuild” on the current system
        Original error: Cannot find module ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.1-linux-arm-glibc/grpc_node.node’
        S ? 2 Replies Last reply
          sdetweil @otto
          @otto your node version is downlevel…
          please do
          node -v
          and
          npm -v
          O 1 Reply Last reply
            sdetweil @otto
            @otto after u fix the node problem above, then redo the npm install in the module folder…
            if there are still issues, then see the module installation instructions for the steps to resolve this problem
            • O
              otto @sdetweil
              @sdetweil said in MMM-AssistantMk2:
              node -v
              node:v10.16.3
              npm -V 6.11.2
                A Former User @otto
                This message means you’ve missed/failed electron-rebuild step. read the docs and do that step again carefully.
                • O
                  otto @Guest
                  @Sean do i need to reinstall it all, or can i just jump to electron-rebuild ?
                  ? 1 Reply Last reply
                    A Former User @otto
                    @otto
                    I think if there is no other issue, just doing electron-rebuild be enough.
                    • O
                      otto @Guest
                      @Sean
                      just to be sure i havent miss understanding the guide,
                      sudo apt-get install gcc-5 #or gcc-7 what sholde i have 5 or 7 i am running the latest Raspbian Buster 2019-07-10
                        A Former User @otto
                        @otto
                        Raspbian Buster has gcc8 as default. Unfortunately with gcc8, grpc wouldn’t be compiled easily. so You need to downgrade to gcc7
                          A Former User @otto
                          @otto
                          sudo apt-get install gcc-7
                          sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 10
                          sudo update-alternatives --config gcc
                          This may work to change current gcc version to 7.
                          • O
                            otto @Guest
                            @Sean
                            pi@raspberrypi:~ $ sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 10
                            pi@raspberrypi:~ $ sudo update-alternatives --config gcc
                            There is only one option in the gcc link group (provides / usr / bin / gcc): / usr / bin / gcc-7
                            Nothing to configure.
                            i using google translate
                              A Former User @otto
                              @otto
                              In that case your gcc be version 7. check it with gcc -v (You probably downgraded global gcc to 7 already)
                              • O
                                otto @Guest
                                @Sean said in MMM-AssistantMk2:
                                gcc -v
                                gcc version 7.3.0 (Raspbian 7.3.0-19) then i guess ist just electron-rebuild left to do
                                  A Former User @otto
                                  right. jump to adventure. :D
                                  • O
                                    otto @Guest
                                    @Sean yepp i hope this will go better then last time, i was trying
                                      A Former User @otto
                                      @otto
                                      It will take 10~30 minutes to complete. Keep the power and network connection during rebuilding. Wish you a good luck!
                                      • O
                                        otto @Guest
                                        @Sean works lika a charm,
                                        2 thing i whant to make changes on.
                                        1. hava a other word like mirror mirror on the wall to activiet it
                                        2. Now i have 2 icon in the top corner, on is flasing, gussing its looking for word to activet. can i hide them?
                                          A Former User @otto
                                          @otto
                                          1. Make your own hotword model with trainer included in MMM-Hotword. Read the docs.
                                          2. For MMM-Hotword, set useDisplay:false
                                            For MMM-AssistantMk2, sorry, not supported. I’m building a new updates about it but not finished yet. (nowadays I have not enough time to focus that module.)
                                          • O
                                            otto @Guest
                                            @otto
                                            okej so i need to creaat a trainer.sh to change the wakeup work, now its smart mirror,
                                            i am using home assistent an a google hub… and i works so good. i can tell my mirror to turnigen on all light… i am in love:D
                                            GREAT JOB and thanks for al the help
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 18 / 22
