    MMM-AssistantMk2
    421 Posts 61 Posters 804.0k Views 57 Watching
      A Former User @otto
      @otto
      Raspbian Buster has gcc8 as default. Unfortunately with gcc8, grpc wouldn’t be compiled easily. so You need to downgrade to gcc7
        A Former User @otto
        @otto
        sudo apt-get install gcc-7
        sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 10
        sudo update-alternatives --config gcc
        This may work to change current gcc version to 7.
        O 1 Reply Last reply
        • O
          otto @Guest
          @Sean
          pi@raspberrypi:~ $ sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 10
          pi@raspberrypi:~ $ sudo update-alternatives --config gcc
          There is only one option in the gcc link group (provides / usr / bin / gcc): / usr / bin / gcc-7
          Nothing to configure.
          i using google translate
          ? 1 Reply Last reply
            A Former User @otto
            @otto
            In that case your gcc be version 7. check it with gcc -v (You probably downgraded global gcc to 7 already)
            • O
              otto @Guest
              @Sean said in MMM-AssistantMk2:
              gcc -v
              gcc version 7.3.0 (Raspbian 7.3.0-19) then i guess ist just electron-rebuild left to do
                A Former User @otto
                @otto said in MMM-AssistantMk2:
                right. jump to adventure. :D
                • O
                  otto @Guest
                  @Sean yepp i hope this will go better then last time, i was trying
                    A Former User @otto
                    @otto
                    It will take 10~30 minutes to complete. Keep the power and network connection during rebuilding. Wish you a good luck!
                    • O
                      otto @Guest
                      @Sean works lika a charm,
                      2 thing i whant to make changes on.
                      1. hava a other word like mirror mirror on the wall to activiet it
                      2. Now i have 2 icon in the top corner, on is flasing, gussing its looking for word to activet. can i hide them?
                        A Former User @otto
                        @otto
                        1. Make your own hotword model with trainer included in MMM-Hotword. Read the docs.
                        2. For MMM-Hotword, set useDisplay:false
                          For MMM-AssistantMk2, sorry, not supported. I’m building a new updates about it but not finished yet. (nowadays I have not enough time to focus that module.)
                        • O
                          otto @Guest
                          @otto
                          okej so i need to creaat a trainer.sh to change the wakeup work, now its smart mirror,
                          i am using home assistent an a google hub… and i works so good. i can tell my mirror to turnigen on all light… i am in love:D
                          GREAT JOB and thanks for al the help
                            raedonlpa @Guest
                            set pauseOnYoutube:false.
                            Hello.
                            -Where do I set this parameter? “set pauseOnYoutube:false”
                            • T
                              teitlebot
                              @Sean
                              Is there anyway to have a Google home show its results on the magic mirror?
                                A Former User @teitlebot
                                @teitlebot
                                do you mean real google home? In other words, you have already a real google home, and you can command it by voice, and you want to display the result from your google home to MagicMirror. right?
                                Sorry, it is not possible.
                                If you make some specific command for your google Home through IFTTT or google Action, in that case, your result could be transferred to MagicMirror(and be shown).
                                But the usual and random commands - like “What time is it?”, “My next schedule”,… couldn’t
                                T 1 Reply Last reply
                                • T
                                  teitlebot @Guest
                                  @Sean thanks for responding. I assume this is a limitation on Google ends? Also how would I tell ifttt to show on magic mirror?
                                  ? 2 Replies Last reply
                                    @teitlebot
                                    There are several posts in this forum. search “ifttt” and read them
                                      @teitlebot
                                      https://forum.magicmirror.builders/topic/10917/guide-control-mm-via-google-home
                                      • T
                                        teitlebot @Guest
                                        @Sean thanks that looks awesome. Going to save it for a rainy day to install.
                                        • W
                                          wellwhatever
                                          Hello @Sean I’ve successfully rebuild the module but when I tried to activate it in the config, the module doesn’t load. The log says ‘No helper found for module: MMM-AssistantMk2’ (pretty sure the file is there inside the module folder). Have any idea whats the cause of this problem?
                                          Thanks in advance!
                                            A Former User @wellwhatever
                                            @wellwhatever
                                            Never seen that kind. Loading node_helper.js is MM’s job itself. If there is the file, regardless it has some errors or not, MM should try to load that file. (And if it has an error, it would spit out the error)
                                            W 1 Reply Last reply
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 18 / 22
