    MMM-AssistantMk2
    421 Posts 61 Posters 712.7k Views 57 Watching
    • O Offline
      otto @sdetweil
      @sdetweil said in MMM-AssistantMk2:
      node -v
      node:v10.16.3
      npm -V 6.11.2
        A Former User @otto
        @otto said in MMM-AssistantMk2:
        WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
        Expected directory: electron-v3.1-linux-arm-glibc
        Found: [node-v64-linux-arm-glibc]
        This message means you’ve missed/failed electron-rebuild step. read the docs and do that step again carefully.
        • O Offline
          otto @Guest
          @Sean do i need to reinstall it all, or can i just jump to electron-rebuild ?
            A Former User @otto
            @otto
            I think if there is no other issue, just doing electron-rebuild be enough.
            • O Offline
              otto @Guest
              @Sean
              just to be sure i havent miss understanding the guide,
              sudo apt-get install gcc-5 #or gcc-7 what sholde i have 5 or 7 i am running the latest Raspbian Buster 2019-07-10
                A Former User @otto
                @otto
                Raspbian Buster has gcc8 as default. Unfortunately with gcc8, grpc wouldn’t be compiled easily. so You need to downgrade to gcc7
                  A Former User @otto
                  @otto
                  sudo apt-get install gcc-7
                  sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 10
                  sudo update-alternatives --config gcc
                  This may work to change current gcc version to 7.
                  • O Offline
                    otto @Guest
                    @Sean
                    pi@raspberrypi:~ $ sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 10
                    pi@raspberrypi:~ $ sudo update-alternatives --config gcc
                    There is only one option in the gcc link group (provides / usr / bin / gcc): / usr / bin / gcc-7
                    Nothing to configure.
                    i using google translate
                      A Former User @otto
                      @otto
                      In that case your gcc be version 7. check it with gcc -v (You probably downgraded global gcc to 7 already)
                      • O Offline
                        otto @Guest
                        @Sean said in MMM-AssistantMk2:
                        gcc -v
                        gcc version 7.3.0 (Raspbian 7.3.0-19) then i guess ist just electron-rebuild left to do
                          A Former User @otto
                          right. jump to adventure. :D
                          • O Offline
                            otto @Guest
                            @Sean yepp i hope this will go better then last time, i was trying
                              A Former User @otto
                              @otto
                              It will take 10~30 minutes to complete. Keep the power and network connection during rebuilding. Wish you a good luck!
                              • O Offline
                                otto @Guest
                                @Sean works lika a charm,
                                2 thing i whant to make changes on.
                                1. hava a other word like mirror mirror on the wall to activiet it
                                2. Now i have 2 icon in the top corner, on is flasing, gussing its looking for word to activet. can i hide them?
                                  A Former User @otto
                                  @otto
                                  1. Make your own hotword model with trainer included in MMM-Hotword. Read the docs.
                                  2. For MMM-Hotword, set useDisplay:false
                                    For MMM-AssistantMk2, sorry, not supported. I’m building a new updates about it but not finished yet. (nowadays I have not enough time to focus that module.)
                                  • O Offline
                                    otto @Guest
                                    @otto
                                    okej so i need to creaat a trainer.sh to change the wakeup work, now its smart mirror,
                                    i am using home assistent an a google hub… and i works so good. i can tell my mirror to turnigen on all light… i am in love:D
                                    GREAT JOB and thanks for al the help
                                      raedonlpa @Guest
                                      set pauseOnYoutube:false.
                                      Hello.
                                      -Where do I set this parameter? “set pauseOnYoutube:false”
                                      • T Offline
                                        teitlebot
                                        @Sean
                                        Is there anyway to have a Google home show its results on the magic mirror?
                                          A Former User @teitlebot
                                          @teitlebot
                                          do you mean real google home? In other words, you have already a real google home, and you can command it by voice, and you want to display the result from your google home to MagicMirror. right?
                                          Sorry, it is not possible.
                                          If you make some specific command for your google Home through IFTTT or google Action, in that case, your result could be transferred to MagicMirror(and be shown).
                                          But the usual and random commands - like “What time is it?”, “My next schedule”,… couldn’t
                                          • T Offline
                                            teitlebot @Guest
                                            @Sean thanks for responding. I assume this is a limitation on Google ends? Also how would I tell ifttt to show on magic mirror?
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 18 / 22
