    MMM-AssistantMk2
    421 Posts 61 Posters 797.0k Views 57 Watching
    • O
      otto @Guest
      @Sean
      just to be sure i havent miss understanding the guide,
      sudo apt-get install gcc-5 #or gcc-7 what sholde i have 5 or 7 i am running the latest Raspbian Buster 2019-07-10
      ? 2 Replies Last reply
        A Former User @otto
        @otto
        Raspbian Buster has gcc8 as default. Unfortunately with gcc8, grpc wouldn’t be compiled easily. so You need to downgrade to gcc7
          A Former User @otto
          @otto
          sudo apt-get install gcc-7
          sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 10
          sudo update-alternatives --config gcc
          This may work to change current gcc version to 7.
          O 1 Reply Last reply
          • O
            otto @Guest
            @Sean
            pi@raspberrypi:~ $ sudo update-alternatives --install /usr/bin/gcc gcc /usr/bin/gcc-7 10
            pi@raspberrypi:~ $ sudo update-alternatives --config gcc
            There is only one option in the gcc link group (provides / usr / bin / gcc): / usr / bin / gcc-7
            Nothing to configure.
            i using google translate
            ? 1 Reply Last reply
              A Former User @otto
              @otto
              In that case your gcc be version 7. check it with gcc -v (You probably downgraded global gcc to 7 already)
              • O
                otto @Guest
                @Sean said in MMM-AssistantMk2:
                gcc -v
                gcc version 7.3.0 (Raspbian 7.3.0-19) then i guess ist just electron-rebuild left to do
                  A Former User @otto
                  @otto said in MMM-AssistantMk2:
                  right. jump to adventure. :D
                  • O
                    otto @Guest
                    @Sean yepp i hope this will go better then last time, i was trying
                      A Former User @otto
                      @otto
                      It will take 10~30 minutes to complete. Keep the power and network connection during rebuilding. Wish you a good luck!
                      • O
                        otto @Guest
                        @Sean works lika a charm,
                        2 thing i whant to make changes on.
                        1. hava a other word like mirror mirror on the wall to activiet it
                        2. Now i have 2 icon in the top corner, on is flasing, gussing its looking for word to activet. can i hide them?
                          A Former User @otto
                          @otto
                          1. Make your own hotword model with trainer included in MMM-Hotword. Read the docs.
                          2. For MMM-Hotword, set useDisplay:false
                            For MMM-AssistantMk2, sorry, not supported. I’m building a new updates about it but not finished yet. (nowadays I have not enough time to focus that module.)
                          • O
                            otto @Guest
                            @otto
                            okej so i need to creaat a trainer.sh to change the wakeup work, now its smart mirror,
                            i am using home assistent an a google hub… and i works so good. i can tell my mirror to turnigen on all light… i am in love:D
                            GREAT JOB and thanks for al the help
                              raedonlpa @Guest
                              set pauseOnYoutube:false.
                              Hello.
                              -Where do I set this parameter? “set pauseOnYoutube:false”
                              • T
                                teitlebot
                                @Sean
                                Is there anyway to have a Google home show its results on the magic mirror?
                                  A Former User @teitlebot
                                  @teitlebot
                                  do you mean real google home? In other words, you have already a real google home, and you can command it by voice, and you want to display the result from your google home to MagicMirror. right?
                                  Sorry, it is not possible.
                                  If you make some specific command for your google Home through IFTTT or google Action, in that case, your result could be transferred to MagicMirror(and be shown).
                                  But the usual and random commands - like “What time is it?”, “My next schedule”,… couldn’t
                                  T 1 Reply Last reply
                                  • T
                                    teitlebot @Guest
                                    @Sean thanks for responding. I assume this is a limitation on Google ends? Also how would I tell ifttt to show on magic mirror?
                                      @teitlebot
                                      There are several posts in this forum. search “ifttt” and read them
                                        @teitlebot
                                        https://forum.magicmirror.builders/topic/10917/guide-control-mm-via-google-home
                                        • T
                                          teitlebot @Guest
                                          @Sean thanks that looks awesome. Going to save it for a rainy day to install.
                                          • W
                                            wellwhatever
                                            Hello @Sean I’ve successfully rebuild the module but when I tried to activate it in the config, the module doesn’t load. The log says ‘No helper found for module: MMM-AssistantMk2’ (pretty sure the file is there inside the module folder). Have any idea whats the cause of this problem?
                                            Thanks in advance!
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 18 / 22
