    [Guide] Control MM via Google Home
    24 Posts 6 Posters 12.9k Views 6 Watching
    • ? Offline
      A Former User
      Voice command-able with Google Home + IFTTT + dataplicity.io + nginx for MagicMirror
      Notice;
      • This topic is not about how to embed Google Assistant on MagicMirror (e.g:MMM-AssistantMk2)
      • The target of this guide is for whom wants to control his MM via his existing Google Home
      Basic Concept;
      If your MM has public and static URL being accessible from outside of home network (We’ll make it with dataplicity.io & nginx), you can make IFTTT can hook the command for Google Home to send own custom message for your MagicMirror.
      It’s easier than making difficult Action for Assistant for your MM. The only downside of this method is, not so easy to make dynamic responses. (I’ll describe about it later)
      Requirements;
      • MagicMirror (connected to internet)
      • IFTTT account
      • dataplicity.io account (Free version is enough)
      • Google Home(mini) or any other Google Assistant implements. (You can also use MMM-AssistantMk2)
      Why do I use dataplicity.io instead of DDNS or ngrok?
      • Easier to maintain.
      • You don’t need to re-modify the setting when the location of MM is changed.
      Step by Step
      1. Give the public and static URL to your MM with dataplicity.io
      Alternately, you can use DDNS or ngrok or Real static IP/Domain. If you can handle them by yourself, skip step 1 & 2.
      1. Go to dataplicity.io and enter your email address. Then you can get some shell command text for your Raspberry.
      It will similar with this. (abcd1234.py will be different per user)
      curl https://www.dataplicity.com/abcd1234.py | sudo python
      Then, execute that command on your Raspberry shell terminal. dataplicity will be installed.
      1. Enable wormhole on dataplicity site.
        After installing, you need to email verification and signing. Then, you can see your device on your account page.
        The detailed layout could be different with mine. (I’m using pro account and using new interface beta.)
      Anyway, you can find Wormhole enabling switch. Enable it and you can see the wormhole URL below the button. Remember the URL.
      2. Install nginx
      Basically wormhole URL of free account is using port 80 but our MagicMirror usually uses higher port like 8080 or 8000. Unfortunately free dataplicity account coudn’t handle those higher ports.
      So you need to install nginx to transfer port 80 to 8080.
      Follow these instructions,
      sudo apt-get install nginx
      sudo rm /etc/nginx/sites-enabled/default
      sudo nano /etc/nginx/sites-available/mm
      Then, copy these and paste, and modify server_name, then save it.
      server {
          listen 80;
          server_name eouia-rpi4-device.dataplicity.io;
          location / {
              proxy_set_header   X-Forwarded-For $remote_addr;
              proxy_set_header   Host $http_host;
              proxy_pass         "http://127.0.0.1:8080";
      Change eouia-rpi4-device.dataplicity.io to your wormhole URL. (don’t prepend https://)
      If your MagicMirror is using other port instead of 8080, modify it also.
      After save, follow remains;
      sudo ln -s /etc/nginx/sites-available/mm /etc/nginx/sites-enabled/mm
      sudo service nginx restart
      To verify all settings being right, Test these;
      cd ~/MagicMirror
      node serveronly
      Then, open any browser (you can test it in other computer also), navigate to your wormhole URL. If MagicMirror screen is displayed, it works!
      3. Install MMM-NotificationTrigger
      You can use MMM-Remote-Control module to receive IFTTT messages. (There could be more modules which can do this stuff). But in this topic, MMM-NotificationTrigger will be used.
      Installation is easy.
      cd ~/MagicMirror/modules
      git clone https://github.com/eouia/MMM-NotificationTrigger
      Then open config/config.js and add configuration.
        module: "MMM-NotificationTrigger",
          useWebhook:true,
          triggers:[
              trigger: "IFTTT_TEST",
              fires: [
                  fire:"SHOW_ALERT",
                  payload: (payload) => {return payload}
      4. Make an IFTTT service.
      Go to IFTTT site and sign in.
      Then make a new service.
      1. Set THIS
      2. Search and select Google Assistant
      3. Select simple phrase (You can make more complex phrase but this is just tutorial)
      4. Fill the fields
      5. Now the turn of THAT
      6. Search and select webhooks
      7. Go on
      8. Fill the fields
      For Action fields; put these values;
      • URL : "https://" + Your wormhole URL + "/webhook"
      • Method : POST
      • Content Type : application/json
      • Body :
        "sender": {
          "name":"IFTTT"
        "notification": "IFTTT_TEST",
        "payload":{
          "title": "From IFTTT",
          "message": "Test IFTTT on {{CreatedAt}}",
          "timer":5000
      Then finish it.
      Now you can activate Google home by commanding “Ok Google, this is test”
      Bingo!
      Real Usage
      • You can add wildcard for number or text to IFTTT command (e.g: “Hide module $ of mirror” or “Set volume to $”)
      • MMM-NotificationTrigger can handle notification, shell command or script and methods of specific module directly. Read the docs of MMM-NotificationTrigger
      • To make rich response; You should use TTS solution (MMM-TTS or MMM-GoogleTTS) and modify modules to speak rich response by itself instead of Google Home
        smackenzie5
        @Sean
        I’m having trouble with Step 2 - Installing nginx.
        I was able to follow Step 1 and have a wormhole URL from Dataplicity. However, I get the following error messages when running the line “sudo apt-get install nginx”
        pi@raspberrypi:~ $ sudo apt-get install nginx
        Reading package lists... Done
        Building dependency tree
        Reading state information... Done
        The following packages were automatically installed and are no longer required:
          libc-ares2 libhttp-parser2.8 libuv1 nodejs-doc realpath
        Use 'sudo apt autoremove' to remove them.
        The following additional packages will be installed:
          libnginx-mod-http-auth-pam libnginx-mod-http-dav-ext libnginx-mod-http-echo
          libnginx-mod-http-geoip libnginx-mod-http-image-filter
          libnginx-mod-http-subs-filter libnginx-mod-http-upstream-fair
          libnginx-mod-http-xslt-filter libnginx-mod-mail libnginx-mod-stream
          nginx-common nginx-full
        Suggested packages:
          fcgiwrap nginx-doc ssl-cert
        The following NEW packages will be installed:
          libnginx-mod-http-xslt-filter libnginx-mod-mail libnginx-mod-stream nginx
        0 upgraded, 13 newly installed, 0 to remove and 39 not upgraded.
        Need to get 1,505 kB of archives.
        After this operation, 2,563 kB of additional disk space will be used.
        Do you want to continue? [Y/n] Y
        Err:1 http://raspbian.raspberrypi.org/raspbian stretch/main armhf nginx-common all 1.10.3-1+deb9u2
          404  Not Found [IP: 93.93.128.193 80]
        Err:2 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-auth-pam armhf 1.10.3-1+deb9u2
        Err:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-dav-ext armhf 1.10.3-1+deb9u2
        Err:4 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-echo armhf 1.10.3-1+deb9u2
        Err:5 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-geoip armhf 1.10.3-1+deb9u2
        Err:6 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-image-filter armhf 1.10.3-1+deb9u2
        Err:7 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-subs-filter armhf 1.10.3-1+deb9u2
        Err:8 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-upstream-fair armhf 1.10.3-1+deb9u2
        Err:9 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-xslt-filter armhf 1.10.3-1+deb9u2
        Err:10 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-mail armhf 1.10.3-1+deb9u2
        Err:11 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-stream armhf 1.10.3-1+deb9u2
        Err:12 http://raspbian.raspberrypi.org/raspbian stretch/main armhf nginx-full armhf 1.10.3-1+deb9u2
        Err:13 http://raspbian.raspberrypi.org/raspbian stretch/main armhf nginx all 1.10.3-1+deb9u2
        E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/nginx-common_1.10.3-1+deb9u2_all.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-auth-pam_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-dav-ext_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-echo_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-geoip_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-image-filter_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-subs-filter_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-upstream-fair_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-xslt-filter_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-mail_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-stream_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/nginx-full_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/nginx_1.10.3-1+deb9u2_all.deb  404  Not Found [IP: 93.93.128.193 80]
        E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
        I tried continuing with the other lines but just got error messages that the files were missing.
        Thoughts?
        Thanks,
        Scott
        • ? Offline
          A Former User @smackenzie5
          @smackenzie5 said in [Guide] Control MM via Google Home:
          Hmmm. Sometimes, Repositories could not be reached by accident. (Due to Network problem, DNS mismatch, Server maintenance, or any other reasons. Who knows.) Try again later.
          Before that; try this;
          sudo apt-get update
          suod apt-get upgrade
            smackenzie5 @Guest
            @Sean
            Can you read through the code below and determine where the error is?
            First, updating like you said did the trick. After updating/upgrading I was able to download everything and complete Step 2. Went on to complete Steps 3 & 4 and the IFTTT test worked.
            Now, I’m trying to use the format of your test code and rewrite it to turn my monitor off using OnScreenMenu. I get the following error message:
            pi@raspberrypi:~ $ cd MagicMirror
            pi@raspberrypi:~/MagicMirror $ sudo npm start
            > magicmirror@2.7.1 start /home/pi/MagicMirror
            > sh run-start.sh
            Starting MagicMirror: v2.7.1
            Loading config ...
            Loading module helpers ...
            No helper found for module: MMM-google-route.
            Module helper loaded: MMM-OnScreenMenu
            Module helper loaded: MMM-NotificationTrigger
            All module helpers loaded.
            Server started ...
            Connecting socket for: MMM-OnScreenMenu
            Connecting socket for: MMM-NotificationTrigger
            Launching application.
            Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxx/basic.ics - Interval: 300000
            SyntaxError: Unexpected token a in JSON at position 96
                at JSON.parse (<anonymous>)
                at parse (/home/pi/MagicMirror/node_modules/body-parser/lib/types/json.js:89:19)
                at /home/pi/MagicMirror/node_modules/body-parser/lib/read.js:121:18
                at invokeCallback (/home/pi/MagicMirror/node_modules/body-parser/node_modules/raw-body/index.js:224:16)
                at done (/home/pi/MagicMirror/node_modules/body-parser/node_modules/raw-body/index.js:213:7)
                at IncomingMessage.onEnd (/home/pi/MagicMirror/node_modules/body-parser/node_modules/raw-body/index.js:273:7)
                at IncomingMessage.emit (events.js:182:13)
                at endReadableNT (_stream_readable.js:1090:12)
                at process._tickCallback (internal/process/next_tick.js:63:19)
            My config.js is here:
                			module: 'MMM-OnScreenMenu',
                			position: 'bottom_right',
            			    useWebhook:true,
            			    triggers:[
             		       		trigger: "ONSCREENMENU_PROCESS_ACTION",
             		       		fires: [
             		           		fire:"notificationReceived",
            My IFTTT is here:
             "sender":{
              "name":"IFTTT"
             "notification":"ONSCREENMENU_PROCESS_ACTION",
             "payload":{actionName: 'monitorOff'
            Thoughts?
            Thanks,
            Scott
            • ? Offline
              “sender”:{
              “name”:“IFTTT”
              “notification”:“ONSCREENMENU_PROCESS_ACTION”,
              “payload”:{actionName: ‘monitorOff’
              JSON syntax is somehow strict than usual JS convention.
                "sender":{
                  "name":"IFTTT"
                "payload":{
                    "actionName": "monitorOff"
              will work. you have failed/missed on using double-quotation marks.
                smackenzie5
                @Sean
                Thanks - that fixed the error message however it still doesn’t turn the monitor off.
                I’m not sure what else to look at now. Below is what I’m seeing but with no error message, kind of hard to tell what to work on.
                I’m considering installing Remote-Control and seeing if I can get that to work unless you’ve got another thought.
                Thanks,
                Scott
                > sh run-start.sh
                Loading config ...
                Server started ...
                reqpost? { sender: { name: 'IFTTT' },
                  notification: 'ONSCREENMENU_PROCESS_ACTION',
                  payload: { actionName: 'monitorOff' } }
                • ? Offline
                  @smackenzie5
                  I don’t know anything about OnScreenMenu. Have you any link to inspect?
                  I think your “fire” would be wrong. “NotificationReceived” is not usual type of notification conventions. Anyway if i see how Onscreenmenu works I may tell you more.
                    smackenzie5 @Guest
                    @Sean
                    OnScreenMenu is one of the 3rd Party modules here:
                    https://github.com/shbatm/MMM-OnScreenMenu
                    I used notificationReceived because it was similar to your example of SHOW_ALERT.
                    From alert.js - show_alert: function(params, sender) {
                    From MMM-NotificationTrigger.js - notificationReceived: function (notification, payload, sender) {
                    Maybe not correct but that’s why I did it.
                    Here’s where I got the example used for the content of notification and payload:
                    https://github.com/shbatm/MMM-AlexaOnOff/blob/master/README.md
                    Again, maybe not correct but that’s why I did it.
                        module: 'MMM-AlexaOnOff',
                            devices: [{
                                  on: {
                                    notification: "ONSCREENMENU_PROCESS_ACTION",
                                    payload: { actionName:'monitorOn' }
                                  off: {
                                    payload: { actionName:'monitorOff' }
                    Thoughts?
                    Thanks,
                    Scott
                    • ? Offline
                      @smackenzie5
                      As far as I read OnScreenMenu module,
                      it needs notification like this;
                      • notification : ONSCREENMENU_PROCESS_ACTION
                      • payload:
                        • “actionName” : “monitorOn”
                      So you can make your IFTTT & NotificationTrigger recipe like this;
                      IFTTT recipe
                        "notification": "MONITOR_ON_FROM_IFTTT",
                        "payload": null
                        useWebhook: true,
                        triggers: [
                            trigger: "MONITOR_ON_FROM_IFTTT",
                            fires: [
                                fire: "ONSCREENMENU_PROCESS_ACTION",
                                payload: {"actionName": "monitorOn"}
                      I didn’t test those codes on real machine so there could be some syntax error, but I believe you can understand the concept
                        smackenzie5 @Guest
                        @Sean
                        You sir, are a freakin’ genius - it works perfectly.
                        Thanks again for all the effort.
                          sgarg15
                          @Sean If possible could you give an example of how our config file should look like if we wanted to use the google home to turn on and off the monitor?
                            sgarg15
                            Also if i were using MMM-Remote-Control besides MMM-OnScreenMenu, how would it work?
                              sgarg15
                              @Sean So i followed all the steps and looked at the conversation you had with smackenzie, but i still cant get my monitor to turn off, here my
                              config.js
                                    useWebhook: true,
                                    triggers: [
                                        trigger: "MONITOR_OFF_FROM_IFTTT",
                                        fires: [
                                            payload: {"actionName": "monitorOff"}
                              IFTTT request
                              { "notification": "MONITOR_OFF_FROM_IFTTT", "payload": null }
                              and here the log when i say Magic (the keyword)
                              reqpost? { notification: 'MONITOR_OFF_FROM_IFTTT', payload: null }
                                sdetweil @sgarg15
                                @sgarg15 if you open the developers window console, you should see the notifications being sent
                                  sgarg15
                                  @sdetweil the notification is being but it isnt doing anything to the monitor
                                    sdetweil @sgarg15
                                    @sgarg15 so, the onscreen module should be configured to receive and process this, right?
                                      @sdetweil these control modules are just so complex to setup.
                                        sgarg15 @sdetweil
                                        @sdetweil Idk some people got this too work, and i have been looking for something like this for a long time,
                                        @Sean When you get time please do have a look
                                        Thanks and sorry for multiple pings
                                          sgarg15
                                          Any ideas anyone?
                                            sgarg15
                                            its not the this module its MMM-OnScreenMenu, because when i click the turn the monitor off button on the menu, nothing happens
                                            Any ideas how to fix this ?
