    [Guide] Control MM via Google Home
    24 Posts 6 Posters 12.4k Views 6 Watching
      sgarg15
      Ok so i got it to work with MMM-Remote-Control, So now i am wondering how can you have multiple commands, like send multiple notifications to for ex. turn on and off the monitor? Any ideas? @Sean
        MilkShake
        Hi, Thanks for the guide. I got it working as IFTTT actually sends a webrequest to my mirror. I am having trouble with the syntax of NotificationTrigger. I already use that module to turn on my Mirror if my gate button is pushed and display an alert.
        I would like to execute a script when the trigger OPEN_GATE is received. Here is my current config:
        module: "MMM-NotificationTrigger",
                  triggers:[
                    trigger: "PLAY_SOUND",
                    fires: [
                        fire:"USER_PRESENCE",
                        payload: function(payload) {
                          return false
                        fire:"SHOW_ALERT",
                          return {
                            type: "notification",
                            title: "Porten",
                            message: "Der er nogen ved porten!"
        Can anyone help with the syntax to add a trigger for “OPEN_GATE” notification that fires a script?
          MilkShake @MilkShake
          @MilkShake
          Got it to work using:
               useWebhook:true,
          	 triggers:[
          		  fires: [
          			fire: "USER_PRESENCE",
                            return false
          	    trigger: "OPEN_GATE",
          		fires: [
          		   fire: "OPENING_THE_GATE",
          		   exec: "sudo python /home/pi/open_gate.py"
            mopedmann
            Hi guys,
            thanks for the great guide @sean.
            I am currently using it with MMM-Carousel w/ Slide Navigation and it works fine.
            I am struggling to execute a command for another project. https://community.spiceworks.com/how_to/123787-raspberry-pi-powered-surveillance-camera-monitoring-display
            The command is /etc/init.d/displaycameras {start|stop|repair}.
            How can I execute the command via webhook?
            I would be delighted to hear from you.
            With kind regards
            mopedmann
