    [Guide] Control MM via Google Home
    24 Posts 6 Posters 13.2k Views 6 Watching
      sgarg15
      @Sean So i followed all the steps and looked at the conversation you had with smackenzie, but i still cant get my monitor to turn off, here my
      config.js
          			module: 'MMM-OnScreenMenu',
          			position: 'bottom_right',
          module: "MMM-NotificationTrigger",
            useWebhook: true,
            triggers: [
                trigger: "MONITOR_OFF_FROM_IFTTT",
                fires: [
                    fire: "ONSCREENMENU_PROCESS_ACTION",
                    payload: {"actionName": "monitorOff"}
      IFTTT request
      { "notification": "MONITOR_OFF_FROM_IFTTT", "payload": null }
      and here the log when i say Magic (the keyword)
      reqpost? { notification: 'MONITOR_OFF_FROM_IFTTT', payload: null }
        sdetweil @sgarg15
        @sgarg15 if you open the developers window console, you should see the notifications being sent
          sgarg15
          @sdetweil the notification is being but it isnt doing anything to the monitor
            sdetweil @sgarg15
            @sgarg15 so, the onscreen module should be configured to receive and process this, right?
              @sdetweil these control modules are just so complex to setup.
                sgarg15 @sdetweil
                @sdetweil Idk some people got this too work, and i have been looking for something like this for a long time,
                @Sean When you get time please do have a look
                Thanks and sorry for multiple pings
                  sgarg15
                  Any ideas anyone?
                    sgarg15
                    its not the this module its MMM-OnScreenMenu, because when i click the turn the monitor off button on the menu, nothing happens
                    Any ideas how to fix this ?
                      sgarg15
                      Ok so i got it to work with MMM-Remote-Control, So now i am wondering how can you have multiple commands, like send multiple notifications to for ex. turn on and off the monitor? Any ideas? @Sean
                        MilkShake
                        Hi, Thanks for the guide. I got it working as IFTTT actually sends a webrequest to my mirror. I am having trouble with the syntax of NotificationTrigger. I already use that module to turn on my Mirror if my gate button is pushed and display an alert.
                        I would like to execute a script when the trigger OPEN_GATE is received. Here is my current config:
                                  triggers:[
                                    trigger: "PLAY_SOUND",
                                    fires: [
                                        fire:"USER_PRESENCE",
                                        payload: function(payload) {
                                          return false
                                        fire:"SHOW_ALERT",
                                          return {
                                            type: "notification",
                                            title: "Porten",
                                            message: "Der er nogen ved porten!"
                        Can anyone help with the syntax to add a trigger for “OPEN_GATE” notification that fires a script?
                        M 1 Reply Last reply
                          MilkShake @MilkShake
                          @MilkShake
                          Got it to work using:
                               useWebhook:true,
                          	 triggers:[
                          		  fires: [
                          			fire: "USER_PRESENCE",
                                            return false
                          	    trigger: "OPEN_GATE",
                          		fires: [
                          		   fire: "OPENING_THE_GATE",
                          		   exec: "sudo python /home/pi/open_gate.py"
                            mopedmann
                            Hi guys,
                            thanks for the great guide @sean.
                            I am currently using it with MMM-Carousel w/ Slide Navigation and it works fine.
                            I am struggling to execute a command for another project. https://community.spiceworks.com/how_to/123787-raspberry-pi-powered-surveillance-camera-monitoring-display
                            The command is /etc/init.d/displaycameras {start|stop|repair}.
                            How can I execute the command via webhook?
                            I would be delighted to hear from you.
                            With kind regards
                            mopedmann
