    [Guide] Control MM via Google Home
    24 Posts 6 Posters 10.9k Views 6 Watching
      smackenzie5
      @Sean
      I’m having trouble with Step 2 - Installing nginx.
      I was able to follow Step 1 and have a wormhole URL from Dataplicity. However, I get the following error messages when running the line “sudo apt-get install nginx”
      pi@raspberrypi:~ $ sudo apt-get install nginx
      Reading package lists... Done
      Building dependency tree
        libc-ares2 libhttp-parser2.8 libuv1 nodejs-doc realpath
      Use 'sudo apt autoremove' to remove them.
      The following additional packages will be installed:
        libnginx-mod-http-auth-pam libnginx-mod-http-dav-ext libnginx-mod-http-echo
        libnginx-mod-http-geoip libnginx-mod-http-image-filter
        libnginx-mod-http-subs-filter libnginx-mod-http-upstream-fair
        libnginx-mod-http-xslt-filter libnginx-mod-mail libnginx-mod-stream
        nginx-common nginx-full
      Suggested packages:
        fcgiwrap nginx-doc ssl-cert
      The following NEW packages will be installed:
        libnginx-mod-http-xslt-filter libnginx-mod-mail libnginx-mod-stream nginx
      0 upgraded, 13 newly installed, 0 to remove and 39 not upgraded.
      Need to get 1,505 kB of archives.
      After this operation, 2,563 kB of additional disk space will be used.
      Do you want to continue? [Y/n] Y
      Err:1 http://raspbian.raspberrypi.org/raspbian stretch/main armhf nginx-common all 1.10.3-1+deb9u2
        404  Not Found [IP: 93.93.128.193 80]
      Err:2 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-auth-pam armhf 1.10.3-1+deb9u2
      Err:3 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-dav-ext armhf 1.10.3-1+deb9u2
      Err:4 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-echo armhf 1.10.3-1+deb9u2
      Err:5 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-geoip armhf 1.10.3-1+deb9u2
      Err:6 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-image-filter armhf 1.10.3-1+deb9u2
      Err:7 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-subs-filter armhf 1.10.3-1+deb9u2
      Err:8 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-upstream-fair armhf 1.10.3-1+deb9u2
      Err:9 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-http-xslt-filter armhf 1.10.3-1+deb9u2
      Err:10 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-mail armhf 1.10.3-1+deb9u2
      Err:11 http://raspbian.raspberrypi.org/raspbian stretch/main armhf libnginx-mod-stream armhf 1.10.3-1+deb9u2
      Err:12 http://raspbian.raspberrypi.org/raspbian stretch/main armhf nginx-full armhf 1.10.3-1+deb9u2
      Err:13 http://raspbian.raspberrypi.org/raspbian stretch/main armhf nginx all 1.10.3-1+deb9u2
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/nginx-common_1.10.3-1+deb9u2_all.deb  404  Not Found [IP: 93.93.128.193 80]
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-auth-pam_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-dav-ext_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-echo_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-geoip_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-image-filter_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-subs-filter_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-upstream-fair_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-http-xslt-filter_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-mail_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/libnginx-mod-stream_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/nginx-full_1.10.3-1+deb9u2_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
      E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/n/nginx/nginx_1.10.3-1+deb9u2_all.deb  404  Not Found [IP: 93.93.128.193 80]
      E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
      I tried continuing with the other lines but just got error messages that the files were missing.
      Thoughts?
      Thanks,
      Scott
        A Former User @smackenzie5
        @smackenzie5 said in [Guide] Control MM via Google Home:
        Hmmm. Sometimes, Repositories could not be reached by accident. (Due to Network problem, DNS mismatch, Server maintenance, or any other reasons. Who knows.) Try again later.
        Before that; try this;
        sudo apt-get update
        suod apt-get upgrade
          smackenzie5 @Guest
          @Sean
          Can you read through the code below and determine where the error is?
          First, updating like you said did the trick. After updating/upgrading I was able to download everything and complete Step 2. Went on to complete Steps 3 & 4 and the IFTTT test worked.
          Now, I’m trying to use the format of your test code and rewrite it to turn my monitor off using OnScreenMenu. I get the following error message:
          pi@raspberrypi:~ $ cd MagicMirror
          pi@raspberrypi:~/MagicMirror $ sudo npm start
          > magicmirror@2.7.1 start /home/pi/MagicMirror
          > sh run-start.sh
          Starting MagicMirror: v2.7.1
          Loading config ...
          Loading module helpers ...
          No helper found for module: MMM-google-route.
          Module helper loaded: MMM-OnScreenMenu
          Module helper loaded: MMM-NotificationTrigger
          All module helpers loaded.
          Server started ...
          Connecting socket for: MMM-OnScreenMenu
          Connecting socket for: MMM-NotificationTrigger
          Launching application.
          Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxx/basic.ics - Interval: 300000
          SyntaxError: Unexpected token a in JSON at position 96
              at JSON.parse (<anonymous>)
              at parse (/home/pi/MagicMirror/node_modules/body-parser/lib/types/json.js:89:19)
              at /home/pi/MagicMirror/node_modules/body-parser/lib/read.js:121:18
              at invokeCallback (/home/pi/MagicMirror/node_modules/body-parser/node_modules/raw-body/index.js:224:16)
              at done (/home/pi/MagicMirror/node_modules/body-parser/node_modules/raw-body/index.js:213:7)
              at IncomingMessage.onEnd (/home/pi/MagicMirror/node_modules/body-parser/node_modules/raw-body/index.js:273:7)
              at IncomingMessage.emit (events.js:182:13)
              at endReadableNT (_stream_readable.js:1090:12)
              at process._tickCallback (internal/process/next_tick.js:63:19)
          My config.js is here:
              			module: 'MMM-OnScreenMenu',
              			position: 'bottom_right',
            			module: "MMM-NotificationTrigger",
          			    useWebhook:true,
          			    triggers:[
           		       		trigger: "ONSCREENMENU_PROCESS_ACTION",
           		       		fires: [
           		           		fire:"notificationReceived",
           		           		payload: (payload) => {return payload}
          My IFTTT is here:
           "sender":{
            "name":"IFTTT"
           "notification":"ONSCREENMENU_PROCESS_ACTION",
           "payload":{actionName: 'monitorOff'
          Thoughts?
          Thanks,
          Scott
            “sender”:{
            “name”:“IFTTT”
            “notification”:“ONSCREENMENU_PROCESS_ACTION”,
            “payload”:{actionName: ‘monitorOff’
            JSON syntax is somehow strict than usual JS convention.
              "sender":{
                "name":"IFTTT"
              "payload":{
                  "actionName": "monitorOff"
            will work. you have failed/missed on using double-quotation marks.
              smackenzie5
              @Sean
              Thanks - that fixed the error message however it still doesn’t turn the monitor off.
              I’m not sure what else to look at now. Below is what I’m seeing but with no error message, kind of hard to tell what to work on.
              I’m considering installing Remote-Control and seeing if I can get that to work unless you’ve got another thought.
              Thanks,
              Scott
              > sh run-start.sh
              Loading config ...
              Server started ...
              reqpost? { sender: { name: 'IFTTT' },
                notification: 'ONSCREENMENU_PROCESS_ACTION',
                payload: { actionName: 'monitorOff' } }
                @smackenzie5
                I don’t know anything about OnScreenMenu. Have you any link to inspect?
                I think your “fire” would be wrong. “NotificationReceived” is not usual type of notification conventions. Anyway if i see how Onscreenmenu works I may tell you more.
                  smackenzie5 @Guest
                  @Sean
                  OnScreenMenu is one of the 3rd Party modules here:
                  https://github.com/shbatm/MMM-OnScreenMenu
                  I used notificationReceived because it was similar to your example of SHOW_ALERT.
                  From alert.js - show_alert: function(params, sender) {
                  From MMM-NotificationTrigger.js - notificationReceived: function (notification, payload, sender) {
                  Maybe not correct but that’s why I did it.
                  Here’s where I got the example used for the content of notification and payload:
                  https://github.com/shbatm/MMM-AlexaOnOff/blob/master/README.md
                  Again, maybe not correct but that’s why I did it.
                      module: 'MMM-AlexaOnOff',
                          devices: [{
                                on: {
                                  notification: "ONSCREENMENU_PROCESS_ACTION",
                                  payload: { actionName:'monitorOn' }
                                off: {
                                  payload: { actionName:'monitorOff' }
                  Thoughts?
                  Thanks,
                  Scott
                    @smackenzie5
                    As far as I read OnScreenMenu module,
                    it needs notification like this;
                    • notification : ONSCREENMENU_PROCESS_ACTION
                    • payload:
                      • “actionName” : “monitorOn”
                    So you can make your IFTTT & NotificationTrigger recipe like this;
                    IFTTT recipe
                      "notification": "MONITOR_ON_FROM_IFTTT",
                      "payload": null
                      useWebhook: true,
                      triggers: [
                          trigger: "MONITOR_ON_FROM_IFTTT",
                          fires: [
                              fire: "ONSCREENMENU_PROCESS_ACTION",
                              payload: {"actionName": "monitorOn"}
                    I didn’t test those codes on real machine so there could be some syntax error, but I believe you can understand the concept
                      smackenzie5 @Guest
                      @Sean
                      You sir, are a freakin’ genius - it works perfectly.
                      Thanks again for all the effort.
                        sgarg15
                        @Sean If possible could you give an example of how our config file should look like if we wanted to use the google home to turn on and off the monitor?
