    [Guide] Control MM via Google Home
    24 Posts 6 Posters 11.2k Views 6 Watching
      A Former User @smackenzie5
      @smackenzie5 said in [Guide] Control MM via Google Home:
      Err:1 http://raspbian.raspberrypi.org/raspbian stretch/main armhf nginx-common
      Hmmm. Sometimes, Repositories could not be reached by accident. (Due to Network problem, DNS mismatch, Server maintenance, or any other reasons. Who knows.) Try again later.
      Before that; try this;
      sudo apt-get update
      suod apt-get upgrade
        smackenzie5 @Guest
        @Sean
        Can you read through the code below and determine where the error is?
        First, updating like you said did the trick. After updating/upgrading I was able to download everything and complete Step 2. Went on to complete Steps 3 & 4 and the IFTTT test worked.
        Now, I’m trying to use the format of your test code and rewrite it to turn my monitor off using OnScreenMenu. I get the following error message:
        pi@raspberrypi:~ $ cd MagicMirror
        pi@raspberrypi:~/MagicMirror $ sudo npm start
        > magicmirror@2.7.1 start /home/pi/MagicMirror
        > sh run-start.sh
        Starting MagicMirror: v2.7.1
        Loading config ...
        Loading module helpers ...
        No helper found for module: MMM-google-route.
        Module helper loaded: MMM-OnScreenMenu
        Module helper loaded: MMM-NotificationTrigger
        All module helpers loaded.
        Server started ...
        Connecting socket for: MMM-OnScreenMenu
        Connecting socket for: MMM-NotificationTrigger
        Launching application.
        Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/xxx/basic.ics - Interval: 300000
        SyntaxError: Unexpected token a in JSON at position 96
            at JSON.parse (<anonymous>)
            at parse (/home/pi/MagicMirror/node_modules/body-parser/lib/types/json.js:89:19)
            at /home/pi/MagicMirror/node_modules/body-parser/lib/read.js:121:18
            at invokeCallback (/home/pi/MagicMirror/node_modules/body-parser/node_modules/raw-body/index.js:224:16)
            at done (/home/pi/MagicMirror/node_modules/body-parser/node_modules/raw-body/index.js:213:7)
            at IncomingMessage.onEnd (/home/pi/MagicMirror/node_modules/body-parser/node_modules/raw-body/index.js:273:7)
            at IncomingMessage.emit (events.js:182:13)
            at endReadableNT (_stream_readable.js:1090:12)
            at process._tickCallback (internal/process/next_tick.js:63:19)
        My config.js is here:
            			module: 'MMM-OnScreenMenu',
            			position: 'bottom_right',
          			module: "MMM-NotificationTrigger",
        			    useWebhook:true,
        			    triggers:[
         		       		trigger: "ONSCREENMENU_PROCESS_ACTION",
         		       		fires: [
         		           		fire:"notificationReceived",
         		           		payload: (payload) => {return payload}
        My IFTTT is here:
         "sender":{
          "name":"IFTTT"
         "notification":"ONSCREENMENU_PROCESS_ACTION",
         "payload":{actionName: 'monitorOff'
        Thoughts?
        Thanks,
        Scott
          “sender”:{
          “name”:“IFTTT”
          “notification”:“ONSCREENMENU_PROCESS_ACTION”,
          “payload”:{actionName: ‘monitorOff’
          JSON syntax is somehow strict than usual JS convention.
            "sender":{
              "name":"IFTTT"
            "payload":{
                "actionName": "monitorOff"
          will work. you have failed/missed on using double-quotation marks.
            smackenzie5
            @Sean
            Thanks - that fixed the error message however it still doesn’t turn the monitor off.
            I’m not sure what else to look at now. Below is what I’m seeing but with no error message, kind of hard to tell what to work on.
            I’m considering installing Remote-Control and seeing if I can get that to work unless you’ve got another thought.
            Thanks,
            Scott
            > sh run-start.sh
            Loading config ...
            Server started ...
            reqpost? { sender: { name: 'IFTTT' },
              notification: 'ONSCREENMENU_PROCESS_ACTION',
              payload: { actionName: 'monitorOff' } }
              @smackenzie5
              I don’t know anything about OnScreenMenu. Have you any link to inspect?
              I think your “fire” would be wrong. “NotificationReceived” is not usual type of notification conventions. Anyway if i see how Onscreenmenu works I may tell you more.
                smackenzie5 @Guest
                @Sean
                OnScreenMenu is one of the 3rd Party modules here:
                https://github.com/shbatm/MMM-OnScreenMenu
                I used notificationReceived because it was similar to your example of SHOW_ALERT.
                From alert.js - show_alert: function(params, sender) {
                From MMM-NotificationTrigger.js - notificationReceived: function (notification, payload, sender) {
                Maybe not correct but that’s why I did it.
                Here’s where I got the example used for the content of notification and payload:
                https://github.com/shbatm/MMM-AlexaOnOff/blob/master/README.md
                Again, maybe not correct but that’s why I did it.
                    module: 'MMM-AlexaOnOff',
                        devices: [{
                              on: {
                                notification: "ONSCREENMENU_PROCESS_ACTION",
                                payload: { actionName:'monitorOn' }
                              off: {
                                payload: { actionName:'monitorOff' }
                Thoughts?
                Thanks,
                Scott
                  @smackenzie5
                  As far as I read OnScreenMenu module,
                  it needs notification like this;
                  • notification : ONSCREENMENU_PROCESS_ACTION
                  • payload:
                    • “actionName” : “monitorOn”
                  So you can make your IFTTT & NotificationTrigger recipe like this;
                  IFTTT recipe
                    "notification": "MONITOR_ON_FROM_IFTTT",
                    "payload": null
                    useWebhook: true,
                    triggers: [
                        trigger: "MONITOR_ON_FROM_IFTTT",
                        fires: [
                            fire: "ONSCREENMENU_PROCESS_ACTION",
                            payload: {"actionName": "monitorOn"}
                  I didn’t test those codes on real machine so there could be some syntax error, but I believe you can understand the concept
                    smackenzie5 @Guest
                    @Sean
                    You sir, are a freakin’ genius - it works perfectly.
                    Thanks again for all the effort.
                      sgarg15
                      @Sean If possible could you give an example of how our config file should look like if we wanted to use the google home to turn on and off the monitor?
                        sgarg15
                        Also if i were using MMM-Remote-Control besides MMM-OnScreenMenu, how would it work?
