    MMM-AssistantMk2
    421 Posts 61 Posters 779.4k Views 57 Watching
    • O
      otto @Guest
      @Sean said in MMM-AssistantMk2:
      gcc -v
      gcc version 7.3.0 (Raspbian 7.3.0-19) then i guess ist just electron-rebuild left to do
        A Former User @otto
        @otto said in MMM-AssistantMk2:
        right. jump to adventure. :D
        • O
          otto @Guest
          @Sean yepp i hope this will go better then last time, i was trying
            A Former User @otto
            @otto
            It will take 10~30 minutes to complete. Keep the power and network connection during rebuilding. Wish you a good luck!
            • O
              otto @Guest
              @Sean works lika a charm,
              2 thing i whant to make changes on.
              1. hava a other word like mirror mirror on the wall to activiet it
              2. Now i have 2 icon in the top corner, on is flasing, gussing its looking for word to activet. can i hide them?
                A Former User @otto
                @otto
                1. Make your own hotword model with trainer included in MMM-Hotword. Read the docs.
                2. For MMM-Hotword, set useDisplay:false
                  For MMM-AssistantMk2, sorry, not supported. I’m building a new updates about it but not finished yet. (nowadays I have not enough time to focus that module.)
                • O
                  otto @Guest
                  @otto
                  okej so i need to creaat a trainer.sh to change the wakeup work, now its smart mirror,
                  i am using home assistent an a google hub… and i works so good. i can tell my mirror to turnigen on all light… i am in love:D
                  GREAT JOB and thanks for al the help
                    raedonlpa @Guest
                    set pauseOnYoutube:false.
                    Hello.
                    -Where do I set this parameter? “set pauseOnYoutube:false”
                    • T
                      teitlebot
                      @Sean
                      Is there anyway to have a Google home show its results on the magic mirror?
                        A Former User @teitlebot
                        @teitlebot
                        do you mean real google home? In other words, you have already a real google home, and you can command it by voice, and you want to display the result from your google home to MagicMirror. right?
                        Sorry, it is not possible.
                        If you make some specific command for your google Home through IFTTT or google Action, in that case, your result could be transferred to MagicMirror(and be shown).
                        But the usual and random commands - like “What time is it?”, “My next schedule”,… couldn’t
                        • T
                          teitlebot @Guest
                          @Sean thanks for responding. I assume this is a limitation on Google ends? Also how would I tell ifttt to show on magic mirror?
                            @teitlebot
                            There are several posts in this forum. search “ifttt” and read them
                              @teitlebot
                              https://forum.magicmirror.builders/topic/10917/guide-control-mm-via-google-home
                              • T
                                teitlebot @Guest
                                @Sean thanks that looks awesome. Going to save it for a rainy day to install.
                                • W
                                  wellwhatever
                                  Hello @Sean I’ve successfully rebuild the module but when I tried to activate it in the config, the module doesn’t load. The log says ‘No helper found for module: MMM-AssistantMk2’ (pretty sure the file is there inside the module folder). Have any idea whats the cause of this problem?
                                  Thanks in advance!
                                    A Former User @wellwhatever
                                    @wellwhatever
                                    Never seen that kind. Loading node_helper.js is MM’s job itself. If there is the file, regardless it has some errors or not, MM should try to load that file. (And if it has an error, it would spit out the error)
                                    • W
                                      wellwhatever @Guest
                                      • A
                                        acimail01
                                        How can I stop a video?
                                        config is
                                        youtubeAutoplay	: true,
                                        pauseOnYoutube : false,
                                        But it does not help.
                                          A Former User @acimail01
                                          @acimail01
                                          with these options, you can re activate hotword again, and then, the current YT player will stop and be hidden.
                                          Anyway, I’ll remove YT related feature on next updates.
                                          • K
                                            Keith
                                            I’m trying to create a recipe that with a single command will hide “module A” and show “module B”. Another command will reverse this action. I can hide and show single modules or all modules but I can’t figure out hide one and show another. Any suggestions would be appreciated.
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 18 / 22
