    Change MMM-Page page using MMM-PIR
    5 Posts 3 Posters 2.3k Views 2 Watching
      aunrea
      How can I change the page for MMM-Page using MMM-PIR I have MMM-PIR and I want it to change the page when the senor doesn’t detect movement and then change it back when it does. Is there a way to do this?
        sdetweil @aunrea
        @aunrea i don’t think MMM-PIR can do that…
        I think you might be able to use pages, or remotecontrol or profile (all mmm- leading chars) to do that tho
          AxLed Module Developer
          @aunrea
          Your request should be possible, check the following module MMM-NotificationTrigger.
          As MMM-PIR uses USER_PRESENCEwith values true and false, you can convert the notifications with MMM-NotificationTrigger to control MMM-Page.
          AxLED
            aunrea @AxLed
            @AxLed said in Change MMM-Page page using MMM-PIR:
            USER_PRESENCE
            I am not sure how to configure the config file to make that happen. There isn’t any documentation for the MMM-NotificationTrigger module, just examples that don’t really fit my needs.
              aunrea
              I switched to MMM-PIR-Sensor and I am using MMM-NotificationTrigger to let MMM-PIR-Sensor communicate with MMM-Page. I am using the following in my config:
              	module: 'MMM-PIR-Sensor',
              		sensorPin: 4,
              		sensorState: 1,
              		powerSaving: false,
              		powerSavingDelay: 60 * 10,
              		relayPin: false,
              		relayState: 1,
              		alwaysOnPin: false,
              		alwaysOnState: 1,
              		alwaysOffPin: false,
              		alwaysOffState: 1,
                module: 'MMM-NotificationTrigger',
                  triggers:[
                      trigger: "USER_PRESENCE",
                      fires: [
                          fire:"PAGE_CHANGED",
                          payload: (payload) => {
                            if (payload == false) {
                              return 1
                            } else {
                              return 0
              I can’t get this to work. If I turn powerSaving: true, I can get the screen to turn off when the sensor doesn’t detect movement for 10 minutes. I just can’t get the page to change. Am I doing something wrong?
