    After adding MMM-GPIO-Notifications, config.js doesn't work...
    13 Posts 3 Posters 4.3k Views 3 Watching
    • T Offline
      tomXGames
      Hi!
      My config.js has an error in it and I’m not able to solve it. Here it is:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "de",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "Neue Zürcher Zeitung",
      						url: "https://www.nzz.ch/recent.rss"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
            			module: "MMM-CalendarExt",
              		system: {
                				show: ["daily"],
                				locale: 'de',
                				redrawInterval:60000,
              			views: {
                				daily: {
                  						position:'lower_third',
                  						counts:7,
              			defaultCalendar: {
                						maxEntries:50,
                						maxDays:180,
                						interval: 1000*60*5,
              			calendars :[
                  						url: "https://calendar.google.com/calendar/ical/tommaso.peduzzi%40gmx.ch/private-088063fff967db8474e57b3a7cdf176a/basic.ics",
      							profiles: ['Tom'],
                  						url: "https://www.ferienwiki.ch/exports/ferien/2019/ch/basel-stadt",
      							profiles: ['default'],
              		module: 'MMM-ProfileSwitcher',
                  module: "currentweather",
                    locationID: "6458763",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                    appid: "123"
                  module: "weatherforecast",
                  header: "Weather Forecast",
                    appid: "123"
      			    module: 'MMM-GPIO-Notifications',
      			        '17': {
      			          gpio_state: 1,
      			          gpio_debounce: 10,
      			          notifications: [
      			              notification: "'CURRENT_PROFILE', 'Tom'",
      			              payload: { true }
      			              notification: 'SCREEN_ON',
      			              payload: { 'forced': false }
      			        '4': {
      			          gpio_state: 1,
      			          gpio_debounce: 20,
      			          notifications: [
      			              'notification': 'SCREEN_TOGGLE',
      			              'payload': { 'forced': true }
      Can anybody help me here?
      tomXGames
      S mumblebajM 3 Replies Last reply Reply Quote 0
        sdetweil @tomXGames
        @tomXGames run
        npm check:config
        Fix errors top down
        • T Offline
          tomXGames
          @sdetweil said in After adding MMM-GPIO-Notifications, config.js doesn't work...:
          npm check:config
          It says, that there is no such command… I’m running it in the MagicMirror directory…
            sdetweil @tomXGames
            @tomXGames sorry,
            npm config:check
            See list of npm enabled commands in package.json
            • T Offline
              tomXGames @sdetweil
              @sdetweil The command still doesn’t work and after adding a comma, nothing is even shown. What am i doing wrong?
                sdetweil @tomXGames
                @tomXGames you do this command in the MagicMirror folder
                • T Offline
                  tomXGames @sdetweil
                  @sdetweil Yeah that’s what I did
                  • mumblebajM Offline
                    mumblebaj Module Developer @tomXGames
                    @tomXGames THis certainly doesn’t look right:
                      sdetweil @tomXGames
                      @tomXGames what do u mean by doesn’t work?
                      Black screen could indicate another problem
                      Are u using pm2?
                      If so, pm2 logs to see what the output is.
                      Also, dev mode
                      pm2 stop 0
                      npm start dev
                        @tomXGames IF not mistaken, the “,” after the last module should not be there either.
