    MMM-Domoticz Cannot read property '0' of undefined
    15 Posts 3 Posters 6.5k Views 3 Watching
      @MisterT said in MMM-Domoticz Cannot read property '0' of undefined:
        	var sensor = this.sensors[c];
      this is not set correctly if called in the domoRequest.onreadystatechange = function() {}
      u should be using self… ‘this’ is context sensitive, means ‘inside this function’
        MisterT
        @sdetweil said in MMM-Domoticz Cannot read property '0' of undefined:
        hi @sdetweil, i replace conole.log by Log.log and now i have error in the console
        Could not load data.
        refered to line 131.
        Sorry but i don’t unerstand your last post about this and self. Can you show me the good syntax or do you need the entire program?
        thanks for your help
          sdetweil @MisterT
          @MisterT change this line
          Log.error(self.name + ": Could not load data.");
          to this
          Log.error(self.name + ": Could not load data. request status="+this.status);
          this will show the error return code on the api url request for the data
            MisterT
            hi @sdetweil , sorry for this late answer, i’m very busy at this moment
            I applied your programe line and now, in the console i have:
            :8080/modules/fabio/domoticz//domoticz.js:142 Uncaught TypeError: Cannot read property ‘0’ of undefined
            at Class.processJson (:8080/modules/fabio/domoticz//domoticz.js:142)
            at XMLHttpRequest.domoRequest.onreadystatechange (:8080/modules/fabio/domoticz//domoticz.js:128)
            and this:
            at Class.processJson (domoticz.js:142)
            at XMLHttpRequest.domoRequest.onreadystatechange (domoticz.js:128)
            processJson @ domoticz.js:142
            domoRequest.onreadystatechange @ domoticz.js:128
            XMLHttpRequest.send (async)
            updateDomo @ domoticz.js:136
            (anonymous) @ domoticz.js:170
            and the js script below
            /* global Module */
            /* Magic Mirror
             * Module: Domoticz
             * By Mathias Arvidsson
            Module.register("domoticz",{
            	defaults: {
            		units: config.units,
            		updateInterval: 50,
            		animationSpeed: 0,
            		timeFormat: config.timeFormat,
            		lang: config.language,
            		initialLoadDelay: 0,
            		retryDelay: 2500,
            		apiBase: "http://1xx.1xx.x.xx", // IP domoticz
            		apiPort: "xxxx",				 // Port
            		sensors: [
            				idx: "1",
            				symbolon: "fa fa-user",
            				symboloff: "fa fa-user-o",
            				hiddenon: false,
            				hiddenoff: false,
            				customTitle: "",
            	firstEvent: false,
            	getStyles: function() {
            	    return ['font-awesome.css'];
            	// Define required scripts.
            	getScripts: function() {
            		return ["moment.js"];
            	// Define start sequence.
            	start: function() {
            		// Set locale.
            		moment.locale(config.language);
            		this.loaded = false;
            		this.status1 = false;
            		this.title = "Loading...";
            		this.scheduleUpdate(this.config.initialLoadDelay);
            		this.sensors = [];
            		for (var c in this.config.sensors) {
            			var sensor = this.config.sensors[c];
            			var newSensor = {idx:sensor.idx, symbolon:sensor.symbolon, symboloff:sensor.symboloff, hiddenon:sensor.hiddenon, hiddenoff:sensor.hiddenoff, customTitle:sensor.customTitle, status:"", sname:"",type:""};
            			Log.log(sensor.idx);
            			this.sensors.push(newSensor);
            Log.log(this.sensors);
            	// Override dom generator.
            	getDom: function() {
            		if (!this.loaded) {
            			wrapper.innerHTML = "Loading...";
            			wrapper.className = "dimmed light small";
            			return wrapper;
            		var tableWrap = document.createElement("table");
            		tableWrap.className = "small";
            		for (var c in this.sensors) {
            			if((sensor.status=="On" && sensor.hiddenon)||(sensor.status=="Off" && sensor.hiddenoff)) continue;
            			var sensorWrapper = document.createElement("tr");
            			sensorWrapper.className = "normal";
            			var symbolTD = document.createElement('td');
            			symbolTD.className = "symbol";
            			var symbol = document.createElement('i');
            			var symbolClass = sensor.symboloff
            			if(sensor.status=="On") symbolClass = sensor.symbolon
            			symbol.className = symbolClass;
            			symbolTD.appendChild(symbol);
            			sensorWrapper.appendChild(symbolTD);
            			var titleTD = document.createElement('td');
            			titleTD.className = "title bright";
            			if(sensor.status=="Off") titleTD.className = "title light";
            			titleTD.innerHTML = sensor.sname;
            			if(typeof sensor.customTitle !== 'undefined') titleTD.innerHTML = sensor.customTitle;
            			sensorWrapper.appendChild(titleTD);
            			var statusTD = document.createElement('td');
            			statusTD.className = "time light";
            			statusTD.innerHTML = sensor.status;
            			sensorWrapper.appendChild(statusTD);
            			tableWrap.appendChild(sensorWrapper);
            		wrapper.appendChild(tableWrap);
            		return wrapper;
            	updateDomo: function() {
            		var i = 0;
            			Log.log("this is c: " + c);
            			var url = this.config.apiBase + ":" + this.config.apiPort + "/json.htm?type=devices&rid="  + sensor.idx;
            			var self = this;
            			var domoRequest = new XMLHttpRequest();
            			domoRequest.open("GET", url, true);
            				if (this.readyState === 4) {
            					if (this.status === 200) {
            						self.processJson(JSON.parse(this.response));
            						Log.log("Loaded data");
            					} else {
            						Log.log("Did not load data");
            			domoRequest.send();
            			i++;
            	processJson: function(data) {
            		Log.log("****Parsing data: " + c + " " + data.result[0].Name);
            		if (!data) {
            			// Did not receive usable new data.
            			// Maybe this needs a better check?
            			return;
            			if(sensor.idx == data.result[0].idx){
            				this.sensors[c].sname = data.result[0].Name;
            				this.sensors[c].status = data.result[0].Data;
            				this.sensors[c].type = data.result[0].Type;
            		this.loaded = true;
            		this.updateDom(this.config.animationSpeed);
            	scheduleUpdate: function(delay) {
            		Log.log("Updating..");
            		var nextLoad = this.config.updateInterval;
            		if (typeof delay !== "undefined" && delay >= 0) {
            			nextLoad = delay;
            		var self = this;
            		setInterval(function() {
            			self.updateDomo();
            		}, 500 );
            for your information, the module seems to work but i have this error.
            Have you a solution?
            thanks a lot
            S N 2 Replies Last reply
              sdetweil @MisterT
              @MisterT could you email the module config (from config.js) to my email same userid as here on gmail…
              S M 2 Replies Last reply
                @sdetweil there is also a newer module (2 months) same name from another user
                https://github.com/SpoturDeal/MMM-Domoticz
                this module (M-Arvidsson) hasn’t been updated in 3 yrs
                • N
                  Nilnik Project Sponsor @MisterT
                  @MisterT I have the same module domoticz (M.Arvidsson) and it works fine for me. I can seei n your domoticz.js that ievery row with log.log … , I have console.log. Maybe thats the problem.
                    MisterT @sdetweil
                    @sdetweil i send you a personal mail with my domoticz module and config.js.
                    Thanks for your help
                    N S 2 Replies Last reply
                    • N
                      @MisterT Hello again, I noticed that have changed the row “setInterval(function() {” to
                      “setTimeout(function() {”
                        sdetweil @MisterT
                        @MisterT sent response via email
                          MisterT
                          Hi, I come back again because @sdetweil send me a MMM-Domoticz module. This module works with user and password of domoticz. So if you want see your domoticz devices on your MM you can use this code below.
                          Just copy it on text editor and save it as domoticz.js in your MM module folder and in a domoticz folder
                          /* global Module */
                          /* Magic Mirror
                           * Module: Domoticz
                           * By Mathias Arvidsson  & editing by sdetewell
                          	defaults: {
                          		units: 0,
                          		updateInterval: 2000,
                          		animationSpeed: 1000,
                          		timeFormat: "HH:MM:ss",
                          		lang: "en",
                          		retryDelay: 2500,
                                  apiBase: "http://xxx.xxx.x.xx",
                          		apiUser: "xxxxx",
                          		apiPw: "xxxxxxxxx",
                          		sensors: [
                          				idx: "1",
                          				hiddenon: false,
                          				hiddenoff: false,
                          				customTitle: "",
                          	keyStr : "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=",
                          		// sample data for parse testing
                          	foo:'{ "result": [\
                             {"Name":"test1", "Data":"foobar1","type":"something1"},\
                          	  {"Name":"test2", "Data":"foobar2","type":"something2"},\
                          		 {"Name":"test3", "Data":"foobar3","type":"something3"},\
                          		  {"Name":"test4", "Data":"foobar4","type":"something4"}\
                          	firstEvent: false,
                            Base64_encode : function(input) {
                              var output = "";
                              var chr1, chr2, chr3, enc1, enc2, enc3, enc4;
                              var i = 0;
                              input = this.Base64_utf8_encode(input);
                              while (i < input.length) {
                                chr1 = input.charCodeAt(i++);
                                chr2 = input.charCodeAt(i++);
                                chr3 = input.charCodeAt(i++);
                                enc1 = chr1 >> 2;
                                enc2 = ((chr1 & 3) << 4) | (chr2 >> 4);
                                enc3 = ((chr2 & 15) << 2) | (chr3 >> 6);
                                enc4 = chr3 & 63;
                                if (isNaN(chr2)) {
                                  enc3 = enc4 = 64;
                                } else if (isNaN(chr3)) {
                                  enc4 = 64;
                                output = output + this.keyStr.charAt(enc1) + this.keyStr.charAt(enc2) + this.keyStr.charAt(enc3) + this.keyStr.charAt(enc4);
                              return output;
                            Base64_decode : function(input) {
                              var output = "";
                              var chr1, chr2, chr3;
                              var enc1, enc2, enc3, enc4;
                              var i = 0;
                              input = input.replace(/[^A-Za-z0-9\+\/\=]/g, "");
                                enc1 = this.keyStr.indexOf(input.charAt(i++));
                                enc2 = this.keyStr.indexOf(input.charAt(i++));
                                enc3 = this.keyStr.indexOf(input.charAt(i++));
                                enc4 = this.keyStr.indexOf(input.charAt(i++));
                                chr1 = (enc1 << 2) | (enc2 >> 4);
                                chr2 = ((enc2 & 15) << 4) | (enc3 >> 2);
                                chr3 = ((enc3 & 3) << 6) | enc4;
                                output = output + String.fromCharCode(chr1);
                                if (enc3 != 64) {
                                  output = output + String.fromCharCode(chr2);
                                if (enc4 != 64) {
                                  output = output + String.fromCharCode(chr3);
                              output = this.Base64_utf8_decode(output);
                              return output;
                            Base64_utf8_encode : function(string) {
                              string = string.replace(/\r\n/g, "\n");
                              var utftext = "";
                              for (var n = 0; n < string.length; n++) {
                                var c = string.charCodeAt(n);
                                if (c < 128) {
                                  utftext += String.fromCharCode(c);
                                } else if ((c > 127) && (c < 2048)) {
                                  utftext += String.fromCharCode((c >> 6) | 192);
                                  utftext += String.fromCharCode((c & 63) | 128);
                                } else {
                                  utftext += String.fromCharCode((c >> 12) | 224);
                                  utftext += String.fromCharCode(((c >> 6) & 63) | 128);
                              return utftext;
                            Base64_utf8_decode : function(utftext) {
                              var string = "";
                              var i = 0;
                              var c = 0,
                                c1 = 0,
                                c2 = 0,
                                c3 = 0;
                              while (i < utftext.length) {
                                c = utftext.charCodeAt(i);
                                if (c < 128) {
                                  string += String.fromCharCode(c);
                                  i++;
                                } else if ((c > 191) && (c < 224)) {
                                  c2 = utftext.charCodeAt(i + 1);
                                  string += String.fromCharCode(((c & 31) << 6) | (c2 & 63));
                                  i += 2;
                                } else {
                                  c3 = utftext.charCodeAt(i + 2);
                                  string += String.fromCharCode(((c & 15) << 12) | ((c2 & 63) << 6) | (c3 & 63));
                                  i += 3;
                              return string;
                          	start: function() {
                          		// Set locale.
                          		this.scheduleUpdate(this.config.updateInterval);//this.scheduleUpdate(this.config.initialLoadDelay);
                          		this.sensors = [];
                          Log.log(JSON.stringify(this.sensors));
                          		if (!this.loaded) {
                          			return wrapper;
                          		return wrapper;
                          		var i = 0;
                          		var self = this
                          		let userid= this.Base64_encode(this.config.apiUser)
                          		let password=this.Base64_encode(this.config.apiPw)
                          		for (var sensor of this.sensors) {
                          			var url =  this.config.apiBase + ":" + this.config.apiPort + "/json.htm?username="+userid + "&password=" +password + "&type=devices&rid="  + sensor.idx;
                          			let domoRequest = new XMLHttpRequest();
                          					// if the api response return code is 200 (ok)
                          						// if there was data returned
                          						// example https://github.com/driverdan/node-XMLHttpRequest/blob/master/example/demo.js
                          						// uses this.responseText , not this.response
                          						// this.response is an object
                          						if(this.responseText && this.responseText.length>0){
                          							// process it
                          							self.processJson(JSON.parse(this.responseText));
                          						else {
                          							 // oops, no data returned
                          						   Log.error(self.name + ": no data returned.");
                          					} else {
                          						// dummy call to verify parse works ok
                          						// even where there are no devices
                          						self.processJson(JSON.parse(self.foo));
                          			// watch out having multiple requests in progress at the same time.
                          			// onreadystatechange doesn't happen til LONG time after send..
                          			// for loop starts another request immediately
                          			domoRequest.send();
                          			i++;
                          		if (!data) {
                          			return;
                          		Log.log("data="+data);
                          		  // moved log entry here, as c is not set until start of for loop
                          			// watch out if data does not contain "result":[] array
                          			if( data.result !=='undefined' && typeof data.result ==='object' && data.result.length >0) {
                          		this.loaded = true;
                          			nextLoad = delay;
                          		//var self = this;
                          		setInterval(() => {
                          			this.updateDomo();
                          		}, nextLoad);
                          After this in your config.js just add for exemple:
                          			module: 'domoticz',
                                			position: 'top_right',
                                			header: 'Températures',
                                      				apiPort: "xx",
                          					apiUser: "xxx",
                          					apiPw: "xxxxxx",
                                      			sensors: [
                          					idx: "183",
                          					symbolon: "fa fa-thermometer-half",
                          					symboloff: "fa fa-thermometer-half",
                          					customTitle: "Cuisine",
                          					idx: "5",
                          					customTitle: "Raspberry Domotique",
                          And it works
                          Thanks @sdetweil for your help
                          M 1 Reply Last reply
                            MisterT @MisterT
                            Hi, everybody
                            I used this old thread because i have a other problem with this module. I update my magic mirror to 2.8 and now this module doesn’t work properly. the error is:
                            Domoticz.js:260 GET http://1xx.1xx1.3x:xxxx/json.htm?username=RmFiaWVu&password=ZmwwNjA2ODVEb21vdGljeg==&type=devices&rid=334 net::ERR_FAILED
                            updateDomo @ domoticz.js:260
                            (anonymous) @ domoticz.js:299
                            0.0.0.0/:1 Access to XMLHttpRequest at 'http://1xx.1xx1.3x:xxxx/json.htm?username=RmFiaWVu&password=ZmwwNjA2ODVEb21vdGljeg==&type=devices&rid=336' from origin 'http://0.0.0.0:8080' has been blocked by CORS policy: The request client is not a secure context and the resource is in more-private address space `private`.
                            domoticz.js:249 domoticz: Could not load data.
                            domoRequest.onreadystatechange @ domoticz.js:249
                            domoticz.js:250 Did not load data
                            domoticz.js:271 data=[object Object]
                            domoticz.js:276 ****Parsing data: 0 test1
                            domoticz.js:276 ****Parsing data: 1 test1
                            domoticz.js:276 ****Parsing data: 2 test1
                            domoticz.js:276 ****Parsing data: 3 test1
                            domoticz.js:276 ****Parsing data: 4 test1
                            domoticz.js:276 ****Parsing data: 5 test1
                            domoticz.js:276 ****Parsing data: 6 test1
                            domoticz.js:260 GET http://1xx.1xx1.3x:xxxx/json.htm?username=RmFiaWVu&password=ZmwwNjA2ODVEb21vdGljeg==&type=devices&rid=336 net::ERR_FAILED
                            I think the json request doesn’t match with the good domoticz request
                            ip and port are good but all these after are bad.
                            @sdetweil is the most contributor of this code. have you an idea?
                            i use the same code that the code is above this post
                              sdetweil @MisterT
                              @mistert electron is enforcing more things than before…
                              see this post for a possible workaround
                              https://forum.magicmirror.builders/topic/16384/node-helper-access-control-allow-origin/2?_=1645457720236
                              • M MisterT referenced this topic on
