Unsolved MMM-Domoticz Cannot read property '0' of undefined
@sdetweil there is also a newer module (2 months) same name from another user
https://github.com/SpoturDeal/MMM-Domoticz
this module (M-Arvidsson) hasn’t been updated in 3 yrs
@MisterT I have the same module domoticz (M.Arvidsson) and it works fine for me. I can seei n your domoticz.js that ievery row with log.log … , I have console.log. Maybe thats the problem.
@sdetweil i send you a personal mail with my domoticz module and config.js.
Thanks for your help -
@MisterT Hello again, I noticed that have changed the row “setInterval(function() {” to
“setTimeout(function() {” -
@MisterT sent response via email
Hi, I come back again because @sdetweil send me a MMM-Domoticz module. This module works with user and password of domoticz. So if you want see your domoticz devices on your MM you can use this code below.
Just copy it on text editor and save it as domoticz.js in your MM module folder and in a domoticz folder/* global Module */ /* Magic Mirror * Module: Domoticz * * By Mathias Arvidsson & editing by sdetewell */ Module.register("domoticz",{ defaults: { units: 0, updateInterval: 2000, animationSpeed: 1000, timeFormat: "HH:MM:ss", lang: "en", initialLoadDelay: 0, retryDelay: 2500, apiBase: "http://xxx.xxx.x.xx", apiUser: "xxxxx", apiPw: "xxxxxxxxx", sensors: [ { idx: "1", symbolon: "fa fa-user", symboloff: "fa fa-user-o", hiddenon: false, hiddenoff: false, customTitle: "", }, ], }, keyStr : "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=", // sample data for parse testing foo:'{ "result": [\ {"Name":"test1", "Data":"foobar1","type":"something1"},\ {"Name":"test2", "Data":"foobar2","type":"something2"},\ {"Name":"test3", "Data":"foobar3","type":"something3"},\ {"Name":"test4", "Data":"foobar4","type":"something4"}\ ]}', firstEvent: false, Base64_encode : function(input) { var output = ""; var chr1, chr2, chr3, enc1, enc2, enc3, enc4; var i = 0; input = this.Base64_utf8_encode(input); while (i < input.length) { chr1 = input.charCodeAt(i++); chr2 = input.charCodeAt(i++); chr3 = input.charCodeAt(i++); enc1 = chr1 >> 2; enc2 = ((chr1 & 3) << 4) | (chr2 >> 4); enc3 = ((chr2 & 15) << 2) | (chr3 >> 6); enc4 = chr3 & 63; if (isNaN(chr2)) { enc3 = enc4 = 64; } else if (isNaN(chr3)) { enc4 = 64; } output = output + this.keyStr.charAt(enc1) + this.keyStr.charAt(enc2) + this.keyStr.charAt(enc3) + this.keyStr.charAt(enc4); } return output; }, Base64_decode : function(input) { var output = ""; var chr1, chr2, chr3; var enc1, enc2, enc3, enc4; var i = 0; input = input.replace(/[^A-Za-z0-9\+\/\=]/g, ""); while (i < input.length) { enc1 = this.keyStr.indexOf(input.charAt(i++)); enc2 = this.keyStr.indexOf(input.charAt(i++)); enc3 = this.keyStr.indexOf(input.charAt(i++)); enc4 = this.keyStr.indexOf(input.charAt(i++)); chr1 = (enc1 << 2) | (enc2 >> 4); chr2 = ((enc2 & 15) << 4) | (enc3 >> 2); chr3 = ((enc3 & 3) << 6) | enc4; output = output + String.fromCharCode(chr1); if (enc3 != 64) { output = output + String.fromCharCode(chr2); } if (enc4 != 64) { output = output + String.fromCharCode(chr3); } } output = this.Base64_utf8_decode(output); return output; }, Base64_utf8_encode : function(string) { string = string.replace(/\r\n/g, "\n"); var utftext = ""; for (var n = 0; n < string.length; n++) { var c = string.charCodeAt(n); if (c < 128) { utftext += String.fromCharCode(c); } else if ((c > 127) && (c < 2048)) { utftext += String.fromCharCode((c >> 6) | 192); utftext += String.fromCharCode((c & 63) | 128); } else { utftext += String.fromCharCode((c >> 12) | 224); utftext += String.fromCharCode(((c >> 6) & 63) | 128); utftext += String.fromCharCode((c & 63) | 128); } } return utftext; }, Base64_utf8_decode : function(utftext) { var string = ""; var i = 0; var c = 0, c1 = 0, c2 = 0, c3 = 0; while (i < utftext.length) { c = utftext.charCodeAt(i); if (c < 128) { string += String.fromCharCode(c); i++; } else if ((c > 191) && (c < 224)) { c2 = utftext.charCodeAt(i + 1); string += String.fromCharCode(((c & 31) << 6) | (c2 & 63)); i += 2; } else { c2 = utftext.charCodeAt(i + 1); c3 = utftext.charCodeAt(i + 2); string += String.fromCharCode(((c & 15) << 12) | ((c2 & 63) << 6) | (c3 & 63)); i += 3; } } return string; }, getStyles: function() { return ['font-awesome.css']; }, // Define required scripts. getScripts: function() { return ["moment.js"]; }, // Define start sequence. start: function() { Log.info("Starting module: " + this.name); // Set locale. moment.locale(config.language); this.loaded = false; this.status1 = false; this.title = "Loading..."; this.scheduleUpdate(this.config.updateInterval);//this.scheduleUpdate(this.config.initialLoadDelay); this.sensors = []; for (var c in this.config.sensors) { var sensor = this.config.sensors[c]; var newSensor = {idx:sensor.idx, symbolon:sensor.symbolon, symboloff:sensor.symboloff, hiddenon:sensor.hiddenon, hiddenoff:sensor.hiddenoff, customTitle:sensor.customTitle, status:"", sname:"",type:""}; Log.log(sensor.idx); this.sensors.push(newSensor); } Log.log(JSON.stringify(this.sensors)); }, // Override dom generator. getDom: function() { var wrapper = document.createElement("div"); if (!this.loaded) { wrapper.innerHTML = "Loading..."; wrapper.className = "dimmed light small"; return wrapper; } var tableWrap = document.createElement("table"); tableWrap.className = "small"; for (var c in this.sensors) { var sensor = this.sensors[c]; if((sensor.status=="On" && sensor.hiddenon)||(sensor.status=="Off" && sensor.hiddenoff)) continue; var sensorWrapper = document.createElement("tr"); sensorWrapper.className = "normal"; var symbolTD = document.createElement('td'); symbolTD.className = "symbol"; var symbol = document.createElement('i'); var symbolClass = sensor.symboloff if(sensor.status=="On") symbolClass = sensor.symbolon symbol.className = symbolClass; symbolTD.appendChild(symbol); sensorWrapper.appendChild(symbolTD); var titleTD = document.createElement('td'); titleTD.className = "title bright"; if(sensor.status=="Off") titleTD.className = "title light"; titleTD.innerHTML = sensor.sname; if(typeof sensor.customTitle !== 'undefined') titleTD.innerHTML = sensor.customTitle; sensorWrapper.appendChild(titleTD); var statusTD = document.createElement('td'); statusTD.className = "time light"; statusTD.innerHTML = sensor.status; sensorWrapper.appendChild(statusTD); tableWrap.appendChild(sensorWrapper); } wrapper.appendChild(tableWrap); return wrapper; }, updateDomo: function() { var i = 0; var self = this let userid= this.Base64_encode(this.config.apiUser) let password=this.Base64_encode(this.config.apiPw) for (var sensor of this.sensors) { var url = this.config.apiBase + ":" + this.config.apiPort + "/json.htm?username="+userid + "&password=" +password + "&type=devices&rid=" + sensor.idx; let domoRequest = new XMLHttpRequest(); domoRequest.open("GET", url, true); domoRequest.onreadystatechange = function() { if (this.readyState === 4) { // if the api response return code is 200 (ok) if (this.status === 200) { // if there was data returned // example https://github.com/driverdan/node-XMLHttpRequest/blob/master/example/demo.js // uses this.responseText , not this.response // this.response is an object if(this.responseText && this.responseText.length>0){ // process it self.processJson(JSON.parse(this.responseText)); Log.log("Loaded data"); } else { // oops, no data returned Log.error(self.name + ": no data returned."); } } else { Log.error(self.name + ": Could not load data."); Log.log("Did not load data"); // dummy call to verify parse works ok // even where there are no devices self.processJson(JSON.parse(self.foo)); } } }; // watch out having multiple requests in progress at the same time. // onreadystatechange doesn't happen til LONG time after send.. // for loop starts another request immediately domoRequest.send(); i++; } }, processJson: function(data) { if (!data) { // Did not receive usable new data. // Maybe this needs a better check? return; } Log.log("data="+data); for (var c in this.sensors) { // moved log entry here, as c is not set until start of for loop // watch out if data does not contain "result":[] array if( data.result !=='undefined' && typeof data.result ==='object' && data.result.length >0) { Log.log("****Parsing data: " + c + " " + data.result[0].Name); var sensor = this.sensors[c]; if(sensor.idx == data.result[0].idx){ this.sensors[c].sname = data.result[0].Name; this.sensors[c].status = data.result[0].Data; this.sensors[c].type = data.result[0].Type; } } } this.loaded = true; this.updateDom(this.config.animationSpeed); }, scheduleUpdate: function(delay) { Log.log("Updating.."); var nextLoad = this.config.updateInterval; if (typeof delay !== "undefined" && delay >= 0) { nextLoad = delay; } //var self = this; setInterval(() => { this.updateDomo(); }, nextLoad); } });
After this in your config.js just add for exemple:
{ module: 'domoticz', position: 'top_right', header: 'Températures', config: { apiBase: "http://xxx.xxx.x.xx", apiPort: "xx", apiUser: "xxx", apiPw: "xxxxxx", sensors: [ { idx: "183", symbolon: "fa fa-thermometer-half", symboloff: "fa fa-thermometer-half", customTitle: "Cuisine", }, { idx: "5", symbolon: "fa fa-thermometer-half", symboloff: "fa fa-thermometer-half", customTitle: "Raspberry Domotique", }, ] } },
And it works
Thanks @sdetweil for your help -
Hi, everybody
I used this old thread because i have a other problem with this module. I update my magic mirror to 2.8 and now this module doesn’t work properly. the error is:Domoticz.js:260 GET http://1xx.1xx1.3x:xxxx/json.htm?username=RmFiaWVu&password=ZmwwNjA2ODVEb21vdGljeg==&type=devices&rid=334 net::ERR_FAILED updateDomo @ domoticz.js:260 (anonymous) @ domoticz.js:299 0.0.0.0/:1 Access to XMLHttpRequest at 'http://1xx.1xx1.3x:xxxx/json.htm?username=RmFiaWVu&password=ZmwwNjA2ODVEb21vdGljeg==&type=devices&rid=336' from origin 'http://0.0.0.0:8080' has been blocked by CORS policy: The request client is not a secure context and the resource is in more-private address space `private`. domoticz.js:249 domoticz: Could not load data. domoRequest.onreadystatechange @ domoticz.js:249 XMLHttpRequest.send (async) updateDomo @ domoticz.js:260 (anonymous) @ domoticz.js:299 domoticz.js:250 Did not load data domoticz.js:271 data=[object Object] domoticz.js:276 ****Parsing data: 0 test1 domoticz.js:276 ****Parsing data: 1 test1 domoticz.js:276 ****Parsing data: 2 test1 domoticz.js:276 ****Parsing data: 3 test1 domoticz.js:276 ****Parsing data: 4 test1 domoticz.js:276 ****Parsing data: 5 test1 domoticz.js:276 ****Parsing data: 6 test1 domoticz.js:260 GET http://1xx.1xx1.3x:xxxx/json.htm?username=RmFiaWVu&password=ZmwwNjA2ODVEb21vdGljeg==&type=devices&rid=336 net::ERR_FAILED
I think the json request doesn’t match with the good domoticz request
ip and port are good but all these after are bad.
@sdetweil is the most contributor of this code. have you an idea?
i use the same code that the code is above this postthanks for your help
@mistert electron is enforcing more things than before…
see this post for a possible workaround
