    electron:837): Gtk-WARNING **: cannot open display: 0:
    7 Posts 4 Posters 3.3k Views 4 Watching
    • Y Offline
      yohu12
      when run DISPLAY=0:0 npm start, i meet such error.
      root@raspberrypi:~/MagicMirror # DISPLAY=0:0 npm start
      > magicmirror@2.8.0 start /root/MagicMirror
      > sh run-start.sh
      (electron:837): Gtk-WARNING **: cannot open display: 0:0
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.8.0 start script.
      npm ERR!     /root/.npm/_logs/2019-08-01T14_29_27_057Z-debug.log
      I have update the raspi-config to start with command line and text boot.
      But error still here.
      Any one can help me???
      • Y Offline
        yohu12
        And I can run startx to show the desktop screen on the monitor. only npm start is not work.
          sdetweil @yohu12
          @yohu12 do it in two steps
          export DISPLAY=:0
          npm start
          • Y Offline
            yohu12 @sdetweil
            @sdetweil said in electron:837): Gtk-WARNING **: cannot open display: 0::
            export DISPLAY=:0
            It return same error
            (electron:1493): Gtk-WARNING **: cannot open display: :0
              sdetweil @yohu12
              @yohu12 this is the same as MagicMirror/installers/mm.sh
              Are u doing this over vpn?
              Also the operating system must have xwindows running…
              • _ Offline
                __willo__
                I saw this error because the raspi was set to Autologin as “pi” and I had created another user which could not take control of the display.
                • Corben DallasC Offline
                  Corben Dallas
                  I saw this just yesterday (followed by a few other warnings). Solution was to follow pretty much this ancient but still working how-to for jessie:
                  jessie-lite-installation-guide
                  (especially points describing “Install Xserver, LXDE-gui and lightdm” and missing packages)
                  Raspberry Pi 4
                  Raspbian Buster
                  MagicMirror² v2.8.0
