    After adding MMM-CalendarExt to a class (MMM-ProfileSwitcher) it doesn't show up on the mirror
    12 Posts 3 Posters 4.3k Views 3 Watching
    • T Offline
      tomXGames
      Hi!
      It’s all in the title…
      Here’s my config:
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "de",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
          			classes: "default everyone"
      			module: "updatenotification",
      			position: "top_bar",
      			module: "clock",
      			module: "newsfeed",
      			position: "bottom_bar",
      			classes: "default everyone",
      				feeds: [
      						title: "Neue Zürcher Zeitung",
      						url: "https://www.nzz.ch/recent.rss"
      				showSourceTitle: true,
      				showPublishDate: true,
      				broadcastNewsFeeds: true,
      				broadcastNewsUpdates: true
            			module: "MMM-CalendarExt",
              		system: {
                				show: ["daily"],
                				locale: 'de',
                				redrawInterval:60000,
              			views: {
                				daily: {
                  						position:'lower_third',
                  						counts:7,
              			defaultCalendar: {
                						maxEntries:50,
                						maxDays:180,
                						interval: 1000*60*5,
              			calendars :[
                  						url: "https://calendar.google.com/calendar/ical/123/basic.ics",
      							profiles: ['Tom'],
                  						url: "https://www.ferienwiki.ch/exports/ferien/2019/ch/basel-stadt",
      							profiles: ['default'],
              		module: 'MMM-ProfileSwitcher',
      		            module: "currentweather",
      				classes: "default",
      		              locationID: "6458763",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      		              appid: "1234"
      	            module: "weatherforecast",
      	            header: "Weather Forecast",
      	              appid: "12345"
      		   	module: 'MMM-GPIO-Notifications',
      			        '17': {
      			          gpio_state: 1,
      			          gpio_debounce: 10,
      			          notifications: [
      					// see https://github.com/tosti007/MMM-ProfileSwitcher
      					// Switching Profiles
      					// this.sendNotification('CURRENT_PROFILE', 'DESIRED_PROFILE_NAME_HERE');
      			              notification: 'CURRENT_PROFILE',
      			              payload:  'Tom'
      Thanks!
        A Former User @tomXGames
        @tomXGames
        Sorry, there was a bug hidden. So I patched it now.
        • T Offline
          tomXGames @Guest
          @Sean Thanks! How can I update it?
            @tomXGames
            Go to MMM-CalendarExt directory then git pull
            • T Offline
              tomXGames @Guest
              @Sean Thanks!
              I have another problem with MMM-Buttons… When I connect the two pins (pin 9 and pin 11 / Ground & GPIO 17) it doesn’t change the profile…
              Can you help out here? That would be great!
               * MIT Licensed.
              var config = {
              	port: 8080,
              	language: "de",
              	timeFormat: 24,
              	units: "metric",
              			module: "alert",
              			module: "clock",
              			module: "newsfeed",
              			classes: "default",
              				feeds: [
                      		system: {
                        				show: ["daily"],
                        				locale: 'de',
                      			views: {
                        				daily: {
                          						counts:7,
                      			defaultCalendar: {
                        						maxEntries:50,
                        						maxDays:180,
                      			calendars :[
                          						url: "https://calendar.google.com/calendar/ical/tommaso.peduzzi%40gmx.ch/private-088063fff967db8474e57b3a7cdf176a/basic.ics",
              							profiles: ['Tom'],
              				classes: "default",
              		              appid: "4a58442ce61f6ae3de20fcfdecdb0327"
              			        '17': {
              			          gpio_state: 1,
              			          gpio_debounce: 10,
              			          notifications: [
              			              payload:  'Tom'
              			    module: 'MMM-Buttons',
              			        buttons: [
              			                pin: 17,
              			                shortPress: {
              			                    notification: "CURRENT_PROFILE",
              			                    payload: "Tom"
                @tomXGames
                Sorry those(Button and ProfileSwitcher) are not mine. You’d better ask the creator about it on their github issue board.
                T 2 Replies Last reply Reply Quote 0
                • T Offline
                  tomXGames @Guest
                  @Sean Ok, thanks anyways for the help!
                  • T Offline
                    tomXGames @Guest
                    @Sean I have another question… Where can I see the notifications?
                      @tomXGames
                      What notification??? more detail, please.
                      • T Offline
                        tomXGames @Guest
                        @Sean The ones sent with this.sendNotification()
                        ? S 2 Replies Last reply Reply Quote 0
                          @tomXGames
                          Inside of module, notificationReceived(noti, payload, sender) will be called when a notification arrives.
                            sdetweil @tomXGames
                            @tomXGames you can see the notifications happening in the developers console…
                            ctrl-shift-i, then selec tthe tab labeled ‘console’… then scroll up to see in the past…
                            u can also filter by module , by putting part of the module name in the filter field
