    A module that changes the text color of a Calender when the next event happens in a certain amount of time.
    Scheduled Pinned Locked Moved Unsolved Feature Requests
    11 Posts 2 Posters 3.7k Views 2 Watching
      A Former User @MerlijnAlmer
      @MerlijnAlmer
      Do you mean showing Description or Location of event?
        MerlijnAlmer
        yes just showing the discrition of a event.
        they make an event for that day and in the description part they fill in what they need the room for.
        so instead of seeing thier names on the screen they would like to see the description.
        location is not needed seen as the screens are at the room.
        thanks for all your help BTW.
        ~M
          @MerlijnAlmer
          If you are using MMM-CalendarExt2, you can transform title of an event by replacing with description field of event.
          views: [
              mode: "upcoming",
              position:"top_center",
              transform:(event) => {
                event.title = event.description
                if (event.startDate < ((Date.now()/1000 + 60*15))) {
                  event.className = "urgent"
                  event.icon = "flat-color-icons:alarm-clock"
                return event
          :D
            MerlijnAlmer
            okay i was just in the process of taking the screen apart to use calendarExt2 thank you for your quick and usefull help.
            ~M
              MerlijnAlmer
              @Sean i might seem to be a absolute knob head for you but when i put the codes in my .js file it breaks the file.
              or is the code supposed to go in to the .css file?
                @MerlijnAlmer
                show me your configuration. eouia0819@gmail.com
                  MerlijnAlmer
                  @sean i sent it
