    MM won't run, blank screen with cursor showing after updating
    81 Posts 2 Posters 47.7k Views 2 Watching
      jmartin1009 @sdetweil
      @sdetweil done, will try now.
        jmartin1009 @jmartin1009
        @sdetweil same error, should a corsair headset mic work to check it? I’m currently using a blue yeti but the connection is a bit iffy, but it appears to be working. Just don’t know what the issue is here.
          sdetweil @jmartin1009
          @jmartin1009 but it should say hw:1,0 can’t be opened
            @sdetweil what? I’m not sure what you’re referring to
              @jmartin1009 the error in the log is can’t open plughw:1,0
              But we changed it… To force hw:1,0
                What does the debug log say
                  @sdetweil oh sorry, here is the new debug.log
                  INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params
                  Current configuration:
                  [NAME]			[DEFLT]		[VALUE]
                  -agc			none		none
                  -agcthresh		2.0		2.000000e+00
                  -allphone
                  -allphone_ci		yes		yes
                  -alpha			0.97		9.700000e-01
                  -ascale			20.0		2.000000e+01
                  -aw			1		1
                  -backtrace		no		no
                  -beam			1e-48		1.000000e-48
                  -bestpath		yes		yes
                  -bestpathlw		9.5		9.500000e+00
                  -ceplen			13		13
                  -cmn			live		batch
                  -cmninit		40,3,-1		41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
                  -compallsen		no		no
                  -dict					modules/MMM-voice/MMM-voice.dic
                  -dictcase		no		no
                  -dither			no		no
                  -doublebw		no		no
                  -ds			1		1
                  -fdict
                  -feat			1s_c_d_dd	1s_c_d_dd
                  -featparams
                  -fillprob		1e-8		1.000000e-08
                  -frate			100		100
                  -fsg
                  -fsgusealtpron		yes		yes
                  -fsgusefiller		yes		yes
                  -fwdflat		yes		yes
                  -fwdflatbeam		1e-64		1.000000e-64
                  -fwdflatefwid		4		4
                  -fwdflatlw		8.5		8.500000e+00
                  -fwdflatsfwin		25		25
                  -fwdflatwbeam		7e-29		7.000000e-29
                  -fwdtree		yes		yes
                  -hmm					/usr/local/share/pocketsphinx/model/en-us/en-us
                  -input_endian		little		little
                  -jsgf
                  -keyphrase
                  -kws
                  -kws_delay		10		10
                  -kws_plp		1e-1		1.000000e-01
                  -kws_threshold		1e-30		1.000000e-30
                  -latsize		5000		5000
                  -lda
                  -ldadim			0		0
                  -lifter			0		22
                  -lm					modules/MMM-voice/MMM-voice.lm
                  -lmctl
                  -lmname
                  -logbase		1.0001		1.000100e+00
                  -logfn
                  -logspec		no		no
                  -lowerf			133.33334	1.300000e+02
                  -lpbeam			1e-40		1.000000e-40
                  -lponlybeam		7e-29		7.000000e-29
                  -lw			6.5		6.500000e+00
                  -maxhmmpf		30000		30000
                  -maxwpf			-1		-1
                  -mdef
                  -mean
                  -mfclogdir
                  -min_endfr		0		0
                  -mixw
                  -mixwfloor		0.0000001	1.000000e-07
                  -mllr
                  -mmap			yes		yes
                  -ncep			13		13
                  -nfft			512		512
                  -nfilt			40		25
                  -nwpen			1.0		1.000000e+00
                  -pbeam			1e-48		1.000000e-48
                  -pip			1.0		1.000000e+00
                  -pl_beam		1e-10		1.000000e-10
                  -pl_pbeam		1e-10		1.000000e-10
                  -pl_pip			1.0		1.000000e+00
                  -pl_weight		3.0		3.000000e+00
                  -pl_window		5		5
                  -rawlogdir
                  -remove_dc		no		no
                  -remove_noise		yes		yes
                  -remove_silence		yes		yes
                  -round_filters		yes		yes
                  -samprate		16000		1.600000e+04
                  -seed			-1		-1
                  -sendump
                  -senlogdir
                  -senmgau
                  -silprob		0.005		5.000000e-03
                  -smoothspec		no		no
                  -svspec					0-12/13-25/26-38
                  -tmat
                  -tmatfloor		0.0001		1.000000e-04
                  -topn			4		4
                  -topn_beam		0		0
                  -toprule
                  -transform		legacy		dct
                  -unit_area		yes		yes
                  -upperf			6855.4976	6.800000e+03
                  -uw			1.0		1.000000e+00
                  -vad_postspeech		50		50
                  -vad_prespeech		20		20
                  -vad_startspeech	10		10
                  -vad_threshold		3.0		3.000000e+00
                  -var
                  -varfloor		0.0001		1.000000e-04
                  -varnorm		no		no
                  -verbose		no		no
                  -warp_params
                  -warp_type		inverse_linear	inverse_linear
                  -wbeam			7e-29		7.000000e-29
                  -wip			0.65		6.500000e-01
                  -wlen			0.025625	2.562500e-02
                  INFO: feat.c(715): Initializing feature stream to type: '1s_c_d_dd', ceplen=13, CMN='batch', VARNORM='no', AGC='none'
                  INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38
                  INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                  INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
                  INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                  INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
                  INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices
                  INFO: acmod.c(113): Attempting to use PTM computation module
                  INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means
                  INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
                  INFO: ms_gauden.c(244):  128x13
                  INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances
                  INFO: ms_gauden.c(304): 222 variance values floored
                  INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump
                  INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION
                  INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126
                  INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones
                  INFO: ptm_mgau.c(837): Maximum top-N: 4
                  INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
                  INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries
                  INFO: dict.c(333): Reading main dictionary: modules/MMM-voice/MMM-voice.dic
                  INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones
                  INFO: dict.c(336): 29 words read
                  INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict
                  INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
                  INFO: dict.c(361): 5 words read
                  INFO: dict2pid.c(396): Building PID tables for dictionary
                  INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
                  INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones
                  INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones
                  INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
                  INFO: ngram_model_trie.c(365): Header doesn't match
                  INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
                  INFO: ngram_model_trie.c(193): LM of order 3
                  INFO: ngram_model_trie.c(195): #1-grams: 25
                  INFO: ngram_model_trie.c(195): #2-grams: 46
                  INFO: ngram_model_trie.c(195): #3-grams: 23
                  INFO: lm_trie.c(474): Training quantizer
                  INFO: lm_trie.c(482): Building LM trie
                  INFO: ngram_search_fwdtree.c(74): Initializing search tree
                  INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
                  INFO: ngram_search_fwdtree.c(186): Creating search channels
                  INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
                  INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
                  INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                  INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41
                  Error opening audio device plughw:1 for capture: Invalid argument
                  FATAL: "continuous.c", line 245: Failed to open audio device
                  -agc			none		none
                  -allphone
                  -aw			1		1
                  -backtrace		no		no
                  -bestpath		yes		yes
                  -ceplen			13		13
                  -cmn			live		batch
                  -compallsen		no		no
                  -dictcase		no		no
                  -dither			no		no
                  -doublebw		no		no
                  -ds			1		1
                  -fdict
                  -featparams
                  -frate			100		100
                  -fsg
                  -fwdflat		yes		yes
                  -fwdflatefwid		4		4
                  -fwdflatsfwin		25		25
                  -fwdtree		yes		yes
                  -jsgf
                  -keyphrase
                  -kws
                  -kws_delay		10		10
                  -latsize		5000		5000
                  -lda
                  -ldadim			0		0
                  -lifter			0		22
                  -lmctl
                  -lmname
                  -logfn
                  -logspec		no		no
                  -maxwpf			-1		-1
                  -mdef
                  -mean
                  -mfclogdir
                  -min_endfr		0		0
                  -mixw
                  -mllr
                  -mmap			yes		yes
                  -ncep			13		13
                  -nfft			512		512
                  -nfilt			40		25
                  -pl_window		5		5
                  -rawlogdir
                  -remove_dc		no		no
                  -seed			-1		-1
                  -sendump
                  -senlogdir
                  -senmgau
                  -smoothspec		no		no
                  -tmat
                  -topn			4		4
                  -topn_beam		0		0
                  -toprule
                  -unit_area		yes		yes
                  -var
                  -varnorm		no		no
                  -verbose		no		no
                  -warp_params
                  Error opening audio device plughw:1,0 for capture: Invalid argument
                  -agc			none		none
                  -allphone
                  -aw			1		1
                  -backtrace		no		no
                  -bestpath		yes		yes
                  -ceplen			13		13
                  -cmn			live		batch
                  -compallsen		no		no
                  -dictcase		no		no
                  -dither			no		no
                  -doublebw		no		no
                  -ds			1		1
                  -fdict
                  -featparams
                  -frate			100		100
                  -fsg
                  -fwdflat		yes		yes
                  -fwdflatefwid		4		4
                  -fwdflatsfwin		25		25
                  -fwdtree		yes		yes
                  -jsgf
                  -keyphrase
                  -kws
                  -kws_delay		10		10
                  -latsize		5000		5000
                  -lda
                  -ldadim			0		0
                  -lifter			0		22
                  -lmctl
                  -lmname
                  -logfn
                  -logspec		no		no
                  -maxwpf			-1		-1
                  -mdef
                  -mean
                  -mfclogdir
                  -min_endfr		0		0
                  -mixw
                  -mllr
                  -mmap			yes		yes
                  -ncep			13		13
                  -nfft			512		512
                  -nfilt			40		25
                  -pl_window		5		5
                  -rawlogdir
                  -remove_dc		no		no
                  -seed			-1		-1
                  -sendump
                  -senlogdir
                  -senmgau
                  -smoothspec		no		no
                  -tmat
                  -topn			4		4
                  -topn_beam		0		0
                  -toprule
                  -unit_area		yes		yes
                  -var
                  -varnorm		no		no
                  -verbose		no		no
                  -warp_params
                  -agc			none		none
                  -allphone
                  -aw			1		1
                  -backtrace		no		no
                  -bestpath		yes		yes
                  -ceplen			13		13
                  -cmn			live		batch
                  -compallsen		no		no
                  -dictcase		no		no
                  -dither			no		no
                  -doublebw		no		no
                  -ds			1		1
                  -fdict
                  -featparams
                  -frate			100		100
                  -fsg
                  -fwdflat		yes		yes
                  -fwdflatefwid		4		4
                  -fwdflatsfwin		25		25
                  -fwdtree		yes		yes
                  -jsgf
                  -keyphrase
                  -kws
                  -kws_delay		10		10
                  -latsize		5000		5000
                  -lda
                  -ldadim			0		0
                  -lifter			0		22
                  -lmctl
                  -lmname
                  -logfn
                  -logspec		no		no
                  -maxwpf			-1		-1
                  -mdef
                  -mean
                  -mfclogdir
                  -min_endfr		0		0
                  -mixw
                  -mllr
                  -mmap			yes		yes
                  -ncep			13		13
                  -nfft			512		512
                  -nfilt			40		25
                  -pl_window		5		5
                  -rawlogdir
                  -remove_dc		no		no
                  -seed			-1		-1
                  -sendump
                  -senlogdir
                  -senmgau
                  -smoothspec		no		no
                  -tmat
                  -topn			4		4
                  -topn_beam		0		0
                  -toprule
                  -unit_area		yes		yes
                  -var
                  -varnorm		no		no
                  -verbose		no		no
                  -warp_params
                  Error opening audio device hw:1,0 for capture: Invalid argument
                  -agc			none		none
                  -allphone
                  -aw			1		1
                  -backtrace		no		no
                  -bestpath		yes		yes
                  -ceplen			13		13
                  -cmn			live		batch
                  -compallsen		no		no
                  -dictcase		no		no
                  -dither			no		no
                  -doublebw		no		no
                  -ds			1		1
                  -fdict
                  -featparams
                  -frate			100		100
                  -fsg
                  -fwdflat		yes		yes
                  -fwdflatefwid		4		4
                  -fwdflatsfwin		25		25
                  -fwdtree		yes		yes
                  -jsgf
                  -keyphrase
                  -kws
                  -kws_delay		10		10
                  -latsize		5000		5000
                  -lda
                  -ldadim			0		0
                  -lifter			0		22
                  -lmctl
                  -lmname
                  -logfn
                  -logspec		no		no
                  -maxwpf			-1		-1
                  -mdef
                  -mean
                  -mfclogdir
                  -min_endfr		0		0
                  -mixw
                  -mllr
                  -mmap			yes		yes
                  -ncep			13		13
                  -nfft			512		512
                  -nfilt			40		25
                  -pl_window		5		5
                  -rawlogdir
                  -remove_dc		no		no
                  -seed			-1		-1
                  -sendump
                  -senlogdir
                  -senmgau
                  -smoothspec		no		no
                  -tmat
                  -topn			4		4
                  -topn_beam		0		0
                  -toprule
                  -unit_area		yes		yes
                  -var
                  -varnorm		no		no
                  -verbose		no		no
                  -warp_params
                    @jmartin1009 ok, tried to open right device.
                    No idea what the parm error is
                    S J 2 Replies Last reply Reply Quote 0
                      @sdetweil try arecord -D plughw:1,0 test.wav
                        @sdetweil i wish i had a fix for this lol ive had issues with every voice control module ive tried so far, just want one for closing the screen and stuff, don’t need an assistant or anything
                          @jmartin1009 yeh, all I use it for too. Sleep and wake up
                            @sdetweil the plughw record test worked!! where do we go now?
                              @jmartin1009 edit that file back. But… I don’t know how to fix the root problem
                                @sdetweil edited the file back, and changed it in config too, but stil showing error when MM runs :/
                                  @jmartin1009 yes, it has the invalid parameter
                                    @sdetweil any more ideas?
                                      @jmartin1009 do
                                      pocketsphinx_continuous --help
                                        @sdetweil in which folder, like cd what
                                          @jmartin1009 it should be in the path, so right where u are
                                            pi@raspberrypi:~/MagicMirror $ pocketsphinx_continuous --help
                                            ERROR: "cmd_ln.c", line 607: Unknown argument name '--help'
                                            ERROR: "cmd_ln.c", line 704: Failed to parse arguments list
                                            INFO: continuous.c(295): Specify '-infile <file.wav>' to recognize from file or '-inmic yes' to recognize from microphone.
                                            • 3 / 5
