    MM won't run, blank screen with cursor showing after updating
    81 Posts 2 Posters 53.3k Views 2 Watching
      sdetweil @jmartin1009
      @jmartin1009 try -v instead of --help
      J 1 Reply Last reply
        jmartin1009 @sdetweil
        ERROR: "cmd_ln.c", line 607: Unknown argument name '-v'
        ERROR: "cmd_ln.c", line 704: Failed to parse arguments list
        INFO: continuous.c(295): Specify '-infile <file.wav>' to recognize from file or '-inmic yes' to recognize from microphone.
          @jmartin1009 grrr. Programmers
            @sdetweil as a programmer in college right now, i relate lmao any leads or ideas about it?
              @jmartin1009 if you give it NO parms, it dumps them out…
              SO, pocketsphinx_continuous 2>somefile
              to get the list of possible parms
              J S 2 Replies Last reply
                ERROR: "cmd_ln.c", line 682: No arguments given, available options are:
                Arguments list definition:
                [NAME]			[DEFLT]		[DESCR]
                -adcdev					Name of audio device to use for input.
                -agc			none		Automatic gain control for c0 ('max', 'emax', 'noise', or 'none')
                -agcthresh		2.0		Initial threshold for automatic gain control
                -allphone				Perform phoneme decoding with phonetic lm
                -allphone_ci		yes		Perform phoneme decoding with phonetic lm and context-independent units only
                -alpha			0.97		Preemphasis parameter
                -argfile				Argument file giving extra arguments.
                -ascale			20.0		Inverse of acoustic model scale for confidence score calculation
                -aw			1		Inverse weight applied to acoustic scores.
                -backtrace		no		Print results and backtraces to log.
                -beam			1e-48		Beam width applied to every frame in Viterbi search (smaller values mean wider beam)
                -bestpath		yes		Run bestpath (Dijkstra) search over word lattice (3rd pass)
                -bestpathlw		9.5		Language model probability weight for bestpath search
                -ceplen			13		Number of components in the input feature vector
                -cmn			live		Cepstral mean normalization scheme ('live', 'batch', or 'none')
                -cmninit		40,3,-1		Initial values (comma-separated) for cepstral mean when 'live' is used
                -compallsen		no		Compute all senone scores in every frame (can be faster when there are many senones)
                -dict					Main pronunciation dictionary (lexicon) input file
                -dictcase		no		Dictionary is case sensitive (NOTE: case insensitivity applies to ASCII characters only)
                -dither			no		Add 1/2-bit noise
                -doublebw		no		Use double bandwidth filters (same center freq)
                -ds			1		Frame GMM computation downsampling ratio
                -fdict					Noise word pronunciation dictionary input file
                -feat			1s_c_d_dd	Feature stream type, depends on the acoustic model
                -featparams				File containing feature extraction parameters.
                -fillprob		1e-8		Filler word transition probability
                -frate			100		Frame rate
                -fsg					Sphinx format finite state grammar file
                -fsgusealtpron		yes		Add alternate pronunciations to FSG
                -fsgusefiller		yes		Insert filler words at each state.
                -fwdflat		yes		Run forward flat-lexicon search over word lattice (2nd pass)
                -fwdflatbeam		1e-64		Beam width applied to every frame in second-pass flat search
                -fwdflatefwid		4		Minimum number of end frames for a word to be searched in fwdflat search
                -fwdflatlw		8.5		Language model probability weight for flat lexicon (2nd pass) decoding
                -fwdflatsfwin		25		Window of frames in lattice to search for successor words in fwdflat search
                -fwdflatwbeam		7e-29		Beam width applied to word exits in second-pass flat search
                -fwdtree		yes		Run forward lexicon-tree search (1st pass)
                -hmm					Directory containing acoustic model files.
                -infile					Audio file to transcribe.
                -inmic			no		Transcribe audio from microphone.
                -input_endian		little		Endianness of input data, big or little, ignored if NIST or MS Wav
                -jsgf					JSGF grammar file
                -keyphrase				Keyphrase to spot
                -kws					A file with keyphrases to spot, one per line
                -kws_delay		10		Delay to wait for best detection score
                -kws_plp		1e-1		Phone loop probability for keyphrase spotting
                -kws_threshold		1e-30		Threshold for p(hyp)/p(alternatives) ratio
                -latsize		5000		Initial backpointer table size
                -lda					File containing transformation matrix to be applied to features (single-stream features only)
                -ldadim			0		Dimensionality of output of feature transformation (0 to use entire matrix)
                -lifter			0		Length of sin-curve for liftering, or 0 for no liftering.
                -lm					Word trigram language model input file
                -lmctl					Specify a set of language model
                -lmname					Which language model in -lmctl to use by default
                -logbase		1.0001		Base in which all log-likelihoods calculated
                -logfn					File to write log messages in
                -logspec		no		Write out logspectral files instead of cepstra
                -lowerf			133.33334	Lower edge of filters
                -lpbeam			1e-40		Beam width applied to last phone in words
                -lponlybeam		7e-29		Beam width applied to last phone in single-phone words
                -lw			6.5		Language model probability weight
                -maxhmmpf		30000		Maximum number of active HMMs to maintain at each frame (or -1 for no pruning)
                -maxwpf			-1		Maximum number of distinct word exits at each frame (or -1 for no pruning)
                -mdef					Model definition input file
                -mean					Mixture gaussian means input file
                -mfclogdir				Directory to log feature files to
                -min_endfr		0		Nodes ignored in lattice construction if they persist for fewer than N frames
                -mixw					Senone mixture weights input file (uncompressed)
                -mixwfloor		0.0000001	Senone mixture weights floor (applied to data from -mixw file)
                -mllr					MLLR transformation to apply to means and variances
                -mmap			yes		Use memory-mapped I/O (if possible) for model files
                -ncep			13		Number of cep coefficients
                -nfft			512		Size of FFT
                -nfilt			40		Number of filter banks
                -nwpen			1.0		New word transition penalty
                -pbeam			1e-48		Beam width applied to phone transitions
                -pip			1.0		Phone insertion penalty
                -pl_beam		1e-10		Beam width applied to phone loop search for lookahead
                -pl_pbeam		1e-10		Beam width applied to phone loop transitions for lookahead
                -pl_pip			1.0		Phone insertion penalty for phone loop
                -pl_weight		3.0		Weight for phoneme lookahead penalties
                -pl_window		5		Phoneme lookahead window size, in frames
                -rawlogdir				Directory to log raw audio files to
                -remove_dc		no		Remove DC offset from each frame
                -remove_noise		yes		Remove noise with spectral subtraction in mel-energies
                -remove_silence		yes		Enables VAD, removes silence frames from processing
                -round_filters		yes		Round mel filter frequencies to DFT points
                -samprate		16000		Sampling rate
                -seed			-1		Seed for random number generator; if less than zero, pick our own
                -sendump				Senone dump (compressed mixture weights) input file
                -senlogdir				Directory to log senone score files to
                -senmgau				Senone to codebook mapping input file (usually not needed)
                -silprob		0.005		Silence word transition probability
                -smoothspec		no		Write out cepstral-smoothed logspectral files
                -svspec					Subvector specification (e.g., 24,0-11/25,12-23/26-38 or 0-12/13-25/26-38)
                -time			no		Print word times in file transcription.
                -tmat					HMM state transition matrix input file
                -tmatfloor		0.0001		HMM state transition probability floor (applied to -tmat file)
                -topn			4		Maximum number of top Gaussians to use in scoring.
                -topn_beam		0		Beam width used to determine top-N Gaussians (or a list, per-feature)
                -toprule				Start rule for JSGF (first public rule is default)
                -transform		legacy		Which type of transform to use to calculate cepstra (legacy, dct, or htk)
                -unit_area		yes		Normalize mel filters to unit area
                -upperf			6855.4976	Upper edge of filters
                -uw			1.0		Unigram weight
                -vad_postspeech		50		Num of silence frames to keep after from speech to silence.
                -vad_prespeech		20		Num of speech frames to keep before silence to speech.
                -vad_startspeech	10		Num of speech frames to trigger vad from silence to speech.
                -vad_threshold		3.0		Threshold for decision between noise and silence frames. Log-ratio between signal level and noise level.
                -var					Mixture gaussian variances input file
                -varfloor		0.0001		Mixture gaussian variance floor (applied to data from -var file)
                -varnorm		no		Variance normalize each utterance (only if CMN == current)
                -verbose		no		Show input filenames
                -warp_params				Parameters defining the warping function
                -warp_type		inverse_linear	Warping function type (or shape)
                -wbeam			7e-29		Beam width applied to word exits
                -wip			0.65		Word insertion penalty
                -wlen			0.025625	Hamming window length
                  @sdetweil also, in the node_modules/pocketsphinx_continuous/index.js
                  show me this
                   var pc = spawn('pocketsphinx_continuous', [
                      '-adcdev',
                      'plughw:' + this.microphone,
                      '-inmic',
                      'yes',
                      '-lm',
                      'modules/MMM-voice/' + this.setId + '.lm',
                      '-dict',
                      'modules/MMM-voice/' + this.setId + '.dic'
                  also check for the two files in the mmm-voice folder MMM-voice.lm and MMM-voice.dic
                    @sdetweil this is the entire index file, didn’t see that anywhere
                    const spawn = require('child_process').spawn;
                    const EventEmitter = require('events').EventEmitter;
                    const util = require('util');
                    const reservedEvents = {
                      close: true,
                      error: true,
                      data: true,
                      end: true,
                      readable: true,
                      drain: true,
                      finish: true,
                      pipe: true,
                      unpipe: true
                    function PocketSphinxContinuous(config) {
                      this.setId = config.setId;
                      this.verbose = config.verbose;
                      this.microphone = config.microphone;
                      this.autostart = config.autostart;
                      if (!config.hasOwnProperty('autostart') || config.autostart === true) {
                        this.start();
                      EventEmitter.call(this);
                    PocketSphinxContinuous.prototype.start = function() {
                      if (!this.isListening()) {
                        let mic = this.microphone;
                        // if name starts with number
                        if (typeof this.microphone === 'number' || this.microphone.match(/^\d/)) {
                          mic = `plughw:${this.microphone}`;
                        this._psc = spawn('pocketsphinx_continuous', [
                          '-adcdev',
                          mic,
                          '-inmic',
                          'yes',
                          '-lm',
                          `modules/${this.setId}/${this.setId}.lm`,
                          '-dict',
                          `modules/${this.setId}/${this.setId}.dic`
                        this._psc.stdout.on('data', data => {
                          const output = data.toString().trim();
                          if (output) {
                            this.emit('data', output);
                          // Also try to emit an event for the actual data, unless of course the
                          // event is a reserved one.
                          const eventName = output.toLowerCase();
                          if (!reservedEvents[eventName]) {
                            this.emit(eventName, output);
                        this._psc.stderr.on('data', data => {
                          if (this.verbose && output) {
                            this.emit('debug', data);
                        this._psc.on('close', code => {
                          this.emit('error', code);
                        this._psc.on('error', err => {
                          this.emit('error', err);
                    PocketSphinxContinuous.prototype.stop = function() {
                      if (this.isListening()) {
                        this._psc.kill();
                    PocketSphinxContinuous.prototype.isListening = function() {
                      return this._psc && !this._psc.killed;
                    util.inherits(PocketSphinxContinuous, EventEmitter);
                    module.exports = PocketSphinxContinuous;
                    also, both of those files are there.
                      @jmartin1009 said in MM won't run, blank screen with cursor showing after updating:
                      from your response
                      >       '-adcdev',
                      >       mic,
                      >       '-inmic',
                      >       'yes',
                      >       '-lm',
                      >       '-dict',
                      so, only the path to the files can be wrong…
                      so, change them to (assume u are running as user pi)
                             '-adcdev',
                             mic,
                             '-inmic',
                             'yes',
                             '-lm',
                             `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.lm`,
                             '-dict',
                             `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.dic`
                        @jmartin1009 you have the file with my fixes in it… btw
                          @sdetweil which file? and i’ll go change those right now
                            @jmartin1009
                            ~/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx_continuous/index.js
                            same file u just showed me
                            J 2 Replies Last reply
                              @sdetweil oh yeah, im going to change the file paths in it right now in the one you sent last.
                                @sdetweil just changed those file paths, tried running MM, still getting “ERROR undefined” next to the little microphone
                                  @jmartin1009 yeh, only care about the debug log
                                    @sdetweil ```
                                    INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params
                                    Current configuration:
                                    [NAME] [DEFLT] [VALUE]
                                    -agc none none
                                    -agcthresh 2.0 2.000000e+00
                                    -allphone
                                    -allphone_ci yes yes
                                    -alpha 0.97 9.700000e-01
                                    -ascale 20.0 2.000000e+01
                                    -aw 1 1
                                    -backtrace no no
                                    -beam 1e-48 1.000000e-48
                                    -bestpath yes yes
                                    -bestpathlw 9.5 9.500000e+00
                                    -ceplen 13 13
                                    -cmn live batch
                                    -cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
                                    -compallsen no no
                                    -dict /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic
                                    -dictcase no no
                                    -dither no no
                                    -doublebw no no
                                    -ds 1 1
                                    -fdict
                                    -feat 1s_c_d_dd 1s_c_d_dd
                                    -featparams
                                    -fillprob 1e-8 1.000000e-08
                                    -frate 100 100
                                    -fsg
                                    -fsgusealtpron yes yes
                                    -fsgusefiller yes yes
                                    -fwdflat yes yes
                                    -fwdflatbeam 1e-64 1.000000e-64
                                    -fwdflatefwid 4 4
                                    -fwdflatlw 8.5 8.500000e+00
                                    -fwdflatsfwin 25 25
                                    -fwdflatwbeam 7e-29 7.000000e-29
                                    -fwdtree yes yes
                                    -hmm /usr/local/share/pocketsphinx/model/en-us/en-us
                                    -input_endian little little
                                    -jsgf
                                    -keyphrase
                                    -kws
                                    -kws_delay 10 10
                                    -kws_plp 1e-1 1.000000e-01
                                    -kws_threshold 1e-30 1.000000e-30
                                    -latsize 5000 5000
                                    -lda
                                    -ldadim 0 0
                                    -lifter 0 22
                                    -lm /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.lm
                                    -lmctl
                                    -lmname
                                    -logbase 1.0001 1.000100e+00
                                    -logfn
                                    -logspec no no
                                    -lowerf 133.33334 1.300000e+02
                                    -lpbeam 1e-40 1.000000e-40
                                    -lponlybeam 7e-29 7.000000e-29
                                    -lw 6.5 6.500000e+00
                                    -maxhmmpf 30000 30000
                                    -maxwpf -1 -1
                                    -mdef
                                    -mean
                                    -mfclogdir
                                    -min_endfr 0 0
                                    -mixw
                                    -mixwfloor 0.0000001 1.000000e-07
                                    -mllr
                                    -mmap yes yes
                                    -ncep 13 13
                                    -nfft 512 512
                                    -nfilt 40 25
                                    -nwpen 1.0 1.000000e+00
                                    -pbeam 1e-48 1.000000e-48
                                    -pip 1.0 1.000000e+00
                                    -pl_beam 1e-10 1.000000e-10
                                    -pl_pbeam 1e-10 1.000000e-10
                                    -pl_pip 1.0 1.000000e+00
                                    -pl_weight 3.0 3.000000e+00
                                    -pl_window 5 5
                                    -rawlogdir
                                    -remove_dc no no
                                    -remove_noise yes yes
                                    -remove_silence yes yes
                                    -round_filters yes yes
                                    -samprate 16000 1.600000e+04
                                    -seed -1 -1
                                    -sendump
                                    -senlogdir
                                    -senmgau
                                    -silprob 0.005 5.000000e-03
                                    -smoothspec no no
                                    -svspec 0-12/13-25/26-38
                                    -tmat
                                    -tmatfloor 0.0001 1.000000e-04
                                    -topn 4 4
                                    -topn_beam 0 0
                                    -toprule
                                    -transform legacy dct
                                    -unit_area yes yes
                                    -upperf 6855.4976 6.800000e+03
                                    -uw 1.0 1.000000e+00
                                    -vad_postspeech 50 50
                                    -vad_prespeech 20 20
                                    -vad_startspeech 10 10
                                    -vad_threshold 3.0 3.000000e+00
                                    -var
                                    -varfloor 0.0001 1.000000e-04
                                    -varnorm no no
                                    -verbose no no
                                    -warp_params
                                    -warp_type inverse_linear inverse_linear
                                    -wbeam 7e-29 7.000000e-29
                                    -wip 0.65 6.500000e-01
                                    -wlen 0.025625 2.562500e-02
                                    INFO: feat.c(715): Initializing feature stream to type: ‘1s_c_d_dd’, ceplen=13, CMN=‘batch’, VARNORM=‘no’, AGC=‘none’
                                    INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38
                                    INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                                    INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
                                    INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                                    INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
                                    INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices
                                    INFO: acmod.c(113): Attempting to use PTM computation module
                                    INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means
                                    INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
                                    INFO: ms_gauden.c(244): 128x13
                                    INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances
                                    INFO: ms_gauden.c(304): 222 variance values floored
                                    INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump
                                    INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION
                                    INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126
                                    INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones
                                    INFO: ptm_mgau.c(837): Maximum top-N: 4
                                    INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
                                    INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries
                                    INFO: dict.c(333): Reading main dictionary: /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic
                                    INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones
                                    INFO: dict.c(336): 29 words read
                                    INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict
                                    INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
                                    INFO: dict.c(361): 5 words read
                                    INFO: dict2pid.c(396): Building PID tables for dictionary
                                    INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
                                    INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones
                                    INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones
                                    INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
                                    INFO: ngram_model_trie.c(365): Header doesn’t match
                                    INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
                                    INFO: ngram_model_trie.c(193): LM of order 3
                                    INFO: ngram_model_trie.c(195): #1-grams: 25
                                    INFO: ngram_model_trie.c(195): #2-grams: 46
                                    INFO: ngram_model_trie.c(195): #3-grams: 23
                                    INFO: lm_trie.c(474): Training quantizer
                                    INFO: lm_trie.c(482): Building LM trie
                                    INFO: ngram_search_fwdtree.c(74): Initializing search tree
                                    INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
                                    INFO: ngram_search_fwdtree.c(186): Creating search channels
                                    INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
                                    INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
                                    INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                                    INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41
                                    Error opening audio device plughw:1,0 for capture: Invalid argument
                                    FATAL: “continuous.c”, line 245: Failed to open audio device
                                      I don’t know…
                                      i would open an issue on the MMM-voice github repo, with the log file and ask for help .
                                        @sdetweil done, thank you for all of your help, I appreciate you taking time out of your day to troubleshoot this with me, you’ve helped me with a ton of stuff and i really appreciate it.
                                          @jmartin1009 glad I could help… sorry we couldn’t push it over the line
                                            @sdetweil no worries! i wish i just could have found a voice control program that didn’t cause me to rip my hair out and give up and try another one by now haha i’ve tried a bunch and they always seem to fail for me.
                                            • 4 / 5
