    MM won't run, blank screen with cursor showing after updating
    81 Posts 2 Posters 53.3k Views 2 Watching
      sdetweil @jmartin1009
      @jmartin1009 it should be in the path, so right where u are
      J 1 Reply Last reply
        jmartin1009 @sdetweil
        pi@raspberrypi:~/MagicMirror $ pocketsphinx_continuous --help
        ERROR: "cmd_ln.c", line 607: Unknown argument name '--help'
        ERROR: "cmd_ln.c", line 704: Failed to parse arguments list
        INFO: continuous.c(295): Specify '-infile <file.wav>' to recognize from file or '-inmic yes' to recognize from microphone.
          @jmartin1009 try -v instead of --help
            ERROR: "cmd_ln.c", line 607: Unknown argument name '-v'
              @jmartin1009 grrr. Programmers
                @sdetweil as a programmer in college right now, i relate lmao any leads or ideas about it?
                  @jmartin1009 if you give it NO parms, it dumps them out…
                  SO, pocketsphinx_continuous 2>somefile
                  to get the list of possible parms
                  J S 2 Replies Last reply
                    ERROR: "cmd_ln.c", line 682: No arguments given, available options are:
                    Arguments list definition:
                    [NAME]			[DEFLT]		[DESCR]
                    -adcdev					Name of audio device to use for input.
                    -agc			none		Automatic gain control for c0 ('max', 'emax', 'noise', or 'none')
                    -agcthresh		2.0		Initial threshold for automatic gain control
                    -allphone				Perform phoneme decoding with phonetic lm
                    -allphone_ci		yes		Perform phoneme decoding with phonetic lm and context-independent units only
                    -alpha			0.97		Preemphasis parameter
                    -argfile				Argument file giving extra arguments.
                    -ascale			20.0		Inverse of acoustic model scale for confidence score calculation
                    -aw			1		Inverse weight applied to acoustic scores.
                    -backtrace		no		Print results and backtraces to log.
                    -beam			1e-48		Beam width applied to every frame in Viterbi search (smaller values mean wider beam)
                    -bestpath		yes		Run bestpath (Dijkstra) search over word lattice (3rd pass)
                    -bestpathlw		9.5		Language model probability weight for bestpath search
                    -ceplen			13		Number of components in the input feature vector
                    -cmn			live		Cepstral mean normalization scheme ('live', 'batch', or 'none')
                    -cmninit		40,3,-1		Initial values (comma-separated) for cepstral mean when 'live' is used
                    -compallsen		no		Compute all senone scores in every frame (can be faster when there are many senones)
                    -dict					Main pronunciation dictionary (lexicon) input file
                    -dictcase		no		Dictionary is case sensitive (NOTE: case insensitivity applies to ASCII characters only)
                    -dither			no		Add 1/2-bit noise
                    -doublebw		no		Use double bandwidth filters (same center freq)
                    -ds			1		Frame GMM computation downsampling ratio
                    -fdict					Noise word pronunciation dictionary input file
                    -feat			1s_c_d_dd	Feature stream type, depends on the acoustic model
                    -featparams				File containing feature extraction parameters.
                    -fillprob		1e-8		Filler word transition probability
                    -frate			100		Frame rate
                    -fsg					Sphinx format finite state grammar file
                    -fsgusealtpron		yes		Add alternate pronunciations to FSG
                    -fsgusefiller		yes		Insert filler words at each state.
                    -fwdflat		yes		Run forward flat-lexicon search over word lattice (2nd pass)
                    -fwdflatbeam		1e-64		Beam width applied to every frame in second-pass flat search
                    -fwdflatefwid		4		Minimum number of end frames for a word to be searched in fwdflat search
                    -fwdflatlw		8.5		Language model probability weight for flat lexicon (2nd pass) decoding
                    -fwdflatsfwin		25		Window of frames in lattice to search for successor words in fwdflat search
                    -fwdflatwbeam		7e-29		Beam width applied to word exits in second-pass flat search
                    -fwdtree		yes		Run forward lexicon-tree search (1st pass)
                    -hmm					Directory containing acoustic model files.
                    -infile					Audio file to transcribe.
                    -inmic			no		Transcribe audio from microphone.
                    -input_endian		little		Endianness of input data, big or little, ignored if NIST or MS Wav
                    -jsgf					JSGF grammar file
                    -keyphrase				Keyphrase to spot
                    -kws					A file with keyphrases to spot, one per line
                    -kws_delay		10		Delay to wait for best detection score
                    -kws_plp		1e-1		Phone loop probability for keyphrase spotting
                    -kws_threshold		1e-30		Threshold for p(hyp)/p(alternatives) ratio
                    -latsize		5000		Initial backpointer table size
                    -lda					File containing transformation matrix to be applied to features (single-stream features only)
                    -ldadim			0		Dimensionality of output of feature transformation (0 to use entire matrix)
                    -lifter			0		Length of sin-curve for liftering, or 0 for no liftering.
                    -lm					Word trigram language model input file
                    -lmctl					Specify a set of language model
                    -lmname					Which language model in -lmctl to use by default
                    -logbase		1.0001		Base in which all log-likelihoods calculated
                    -logfn					File to write log messages in
                    -logspec		no		Write out logspectral files instead of cepstra
                    -lowerf			133.33334	Lower edge of filters
                    -lpbeam			1e-40		Beam width applied to last phone in words
                    -lponlybeam		7e-29		Beam width applied to last phone in single-phone words
                    -lw			6.5		Language model probability weight
                    -maxhmmpf		30000		Maximum number of active HMMs to maintain at each frame (or -1 for no pruning)
                    -maxwpf			-1		Maximum number of distinct word exits at each frame (or -1 for no pruning)
                    -mdef					Model definition input file
                    -mean					Mixture gaussian means input file
                    -mfclogdir				Directory to log feature files to
                    -min_endfr		0		Nodes ignored in lattice construction if they persist for fewer than N frames
                    -mixw					Senone mixture weights input file (uncompressed)
                    -mixwfloor		0.0000001	Senone mixture weights floor (applied to data from -mixw file)
                    -mllr					MLLR transformation to apply to means and variances
                    -mmap			yes		Use memory-mapped I/O (if possible) for model files
                    -ncep			13		Number of cep coefficients
                    -nfft			512		Size of FFT
                    -nfilt			40		Number of filter banks
                    -nwpen			1.0		New word transition penalty
                    -pbeam			1e-48		Beam width applied to phone transitions
                    -pip			1.0		Phone insertion penalty
                    -pl_beam		1e-10		Beam width applied to phone loop search for lookahead
                    -pl_pbeam		1e-10		Beam width applied to phone loop transitions for lookahead
                    -pl_pip			1.0		Phone insertion penalty for phone loop
                    -pl_weight		3.0		Weight for phoneme lookahead penalties
                    -pl_window		5		Phoneme lookahead window size, in frames
                    -rawlogdir				Directory to log raw audio files to
                    -remove_dc		no		Remove DC offset from each frame
                    -remove_noise		yes		Remove noise with spectral subtraction in mel-energies
                    -remove_silence		yes		Enables VAD, removes silence frames from processing
                    -round_filters		yes		Round mel filter frequencies to DFT points
                    -samprate		16000		Sampling rate
                    -seed			-1		Seed for random number generator; if less than zero, pick our own
                    -sendump				Senone dump (compressed mixture weights) input file
                    -senlogdir				Directory to log senone score files to
                    -senmgau				Senone to codebook mapping input file (usually not needed)
                    -silprob		0.005		Silence word transition probability
                    -smoothspec		no		Write out cepstral-smoothed logspectral files
                    -svspec					Subvector specification (e.g., 24,0-11/25,12-23/26-38 or 0-12/13-25/26-38)
                    -time			no		Print word times in file transcription.
                    -tmat					HMM state transition matrix input file
                    -tmatfloor		0.0001		HMM state transition probability floor (applied to -tmat file)
                    -topn			4		Maximum number of top Gaussians to use in scoring.
                    -topn_beam		0		Beam width used to determine top-N Gaussians (or a list, per-feature)
                    -toprule				Start rule for JSGF (first public rule is default)
                    -transform		legacy		Which type of transform to use to calculate cepstra (legacy, dct, or htk)
                    -unit_area		yes		Normalize mel filters to unit area
                    -upperf			6855.4976	Upper edge of filters
                    -uw			1.0		Unigram weight
                    -vad_postspeech		50		Num of silence frames to keep after from speech to silence.
                    -vad_prespeech		20		Num of speech frames to keep before silence to speech.
                    -vad_startspeech	10		Num of speech frames to trigger vad from silence to speech.
                    -vad_threshold		3.0		Threshold for decision between noise and silence frames. Log-ratio between signal level and noise level.
                    -var					Mixture gaussian variances input file
                    -varfloor		0.0001		Mixture gaussian variance floor (applied to data from -var file)
                    -varnorm		no		Variance normalize each utterance (only if CMN == current)
                    -verbose		no		Show input filenames
                    -warp_params				Parameters defining the warping function
                    -warp_type		inverse_linear	Warping function type (or shape)
                    -wbeam			7e-29		Beam width applied to word exits
                    -wip			0.65		Word insertion penalty
                    -wlen			0.025625	Hamming window length
                      @sdetweil also, in the node_modules/pocketsphinx_continuous/index.js
                      show me this
                       var pc = spawn('pocketsphinx_continuous', [
                          '-adcdev',
                          'plughw:' + this.microphone,
                          '-inmic',
                          'yes',
                          '-lm',
                          'modules/MMM-voice/' + this.setId + '.lm',
                          '-dict',
                          'modules/MMM-voice/' + this.setId + '.dic'
                      also check for the two files in the mmm-voice folder MMM-voice.lm and MMM-voice.dic
                        @sdetweil this is the entire index file, didn’t see that anywhere
                        const spawn = require('child_process').spawn;
                        const EventEmitter = require('events').EventEmitter;
                        const util = require('util');
                        const reservedEvents = {
                          close: true,
                          error: true,
                          data: true,
                          end: true,
                          readable: true,
                          drain: true,
                          finish: true,
                          pipe: true,
                          unpipe: true
                        function PocketSphinxContinuous(config) {
                          this.setId = config.setId;
                          this.verbose = config.verbose;
                          this.microphone = config.microphone;
                          this.autostart = config.autostart;
                          if (!config.hasOwnProperty('autostart') || config.autostart === true) {
                            this.start();
                          EventEmitter.call(this);
                        PocketSphinxContinuous.prototype.start = function() {
                          if (!this.isListening()) {
                            let mic = this.microphone;
                            // if name starts with number
                            if (typeof this.microphone === 'number' || this.microphone.match(/^\d/)) {
                              mic = `plughw:${this.microphone}`;
                            this._psc = spawn('pocketsphinx_continuous', [
                              '-adcdev',
                              mic,
                              '-inmic',
                              'yes',
                              '-lm',
                              `modules/${this.setId}/${this.setId}.lm`,
                              '-dict',
                              `modules/${this.setId}/${this.setId}.dic`
                            this._psc.stdout.on('data', data => {
                              const output = data.toString().trim();
                              if (output) {
                                this.emit('data', output);
                              // Also try to emit an event for the actual data, unless of course the
                              // event is a reserved one.
                              const eventName = output.toLowerCase();
                              if (!reservedEvents[eventName]) {
                                this.emit(eventName, output);
                            this._psc.stderr.on('data', data => {
                              if (this.verbose && output) {
                                this.emit('debug', data);
                            this._psc.on('close', code => {
                              this.emit('error', code);
                            this._psc.on('error', err => {
                              this.emit('error', err);
                        PocketSphinxContinuous.prototype.stop = function() {
                          if (this.isListening()) {
                            this._psc.kill();
                        PocketSphinxContinuous.prototype.isListening = function() {
                          return this._psc && !this._psc.killed;
                        util.inherits(PocketSphinxContinuous, EventEmitter);
                        module.exports = PocketSphinxContinuous;
                        also, both of those files are there.
                          @jmartin1009 said in MM won't run, blank screen with cursor showing after updating:
                          from your response
                          >       '-adcdev',
                          >       mic,
                          >       '-inmic',
                          >       'yes',
                          >       '-lm',
                          >       '-dict',
                          so, only the path to the files can be wrong…
                          so, change them to (assume u are running as user pi)
                                 '-adcdev',
                                 mic,
                                 '-inmic',
                                 'yes',
                                 '-lm',
                                 `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.lm`,
                                 '-dict',
                                 `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.dic`
                            @jmartin1009 you have the file with my fixes in it… btw
                              @sdetweil which file? and i’ll go change those right now
                                @jmartin1009
                                ~/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx_continuous/index.js
                                same file u just showed me
                                J 2 Replies Last reply
                                  @sdetweil oh yeah, im going to change the file paths in it right now in the one you sent last.
                                    @sdetweil just changed those file paths, tried running MM, still getting “ERROR undefined” next to the little microphone
                                      @jmartin1009 yeh, only care about the debug log
                                        @sdetweil ```
                                        INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params
                                        Current configuration:
                                        [NAME] [DEFLT] [VALUE]
                                        -agc none none
                                        -agcthresh 2.0 2.000000e+00
                                        -allphone
                                        -allphone_ci yes yes
                                        -alpha 0.97 9.700000e-01
                                        -ascale 20.0 2.000000e+01
                                        -aw 1 1
                                        -backtrace no no
                                        -beam 1e-48 1.000000e-48
                                        -bestpath yes yes
                                        -bestpathlw 9.5 9.500000e+00
                                        -ceplen 13 13
                                        -cmn live batch
                                        -cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
                                        -compallsen no no
                                        -dict /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic
                                        -dictcase no no
                                        -dither no no
                                        -doublebw no no
                                        -ds 1 1
                                        -fdict
                                        -feat 1s_c_d_dd 1s_c_d_dd
                                        -featparams
                                        -fillprob 1e-8 1.000000e-08
                                        -frate 100 100
                                        -fsg
                                        -fsgusealtpron yes yes
                                        -fsgusefiller yes yes
                                        -fwdflat yes yes
                                        -fwdflatbeam 1e-64 1.000000e-64
                                        -fwdflatefwid 4 4
                                        -fwdflatlw 8.5 8.500000e+00
                                        -fwdflatsfwin 25 25
                                        -fwdflatwbeam 7e-29 7.000000e-29
                                        -fwdtree yes yes
                                        -hmm /usr/local/share/pocketsphinx/model/en-us/en-us
                                        -input_endian little little
                                        -jsgf
                                        -keyphrase
                                        -kws
                                        -kws_delay 10 10
                                        -kws_plp 1e-1 1.000000e-01
                                        -kws_threshold 1e-30 1.000000e-30
                                        -latsize 5000 5000
                                        -lda
                                        -ldadim 0 0
                                        -lifter 0 22
                                        -lm /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.lm
                                        -lmctl
                                        -lmname
                                        -logbase 1.0001 1.000100e+00
                                        -logfn
                                        -logspec no no
                                        -lowerf 133.33334 1.300000e+02
                                        -lpbeam 1e-40 1.000000e-40
                                        -lponlybeam 7e-29 7.000000e-29
                                        -lw 6.5 6.500000e+00
                                        -maxhmmpf 30000 30000
                                        -maxwpf -1 -1
                                        -mdef
                                        -mean
                                        -mfclogdir
                                        -min_endfr 0 0
                                        -mixw
                                        -mixwfloor 0.0000001 1.000000e-07
                                        -mllr
                                        -mmap yes yes
                                        -ncep 13 13
                                        -nfft 512 512
                                        -nfilt 40 25
                                        -nwpen 1.0 1.000000e+00
                                        -pbeam 1e-48 1.000000e-48
                                        -pip 1.0 1.000000e+00
                                        -pl_beam 1e-10 1.000000e-10
                                        -pl_pbeam 1e-10 1.000000e-10
                                        -pl_pip 1.0 1.000000e+00
                                        -pl_weight 3.0 3.000000e+00
                                        -pl_window 5 5
                                        -rawlogdir
                                        -remove_dc no no
                                        -remove_noise yes yes
                                        -remove_silence yes yes
                                        -round_filters yes yes
                                        -samprate 16000 1.600000e+04
                                        -seed -1 -1
                                        -sendump
                                        -senlogdir
                                        -senmgau
                                        -silprob 0.005 5.000000e-03
                                        -smoothspec no no
                                        -svspec 0-12/13-25/26-38
                                        -tmat
                                        -tmatfloor 0.0001 1.000000e-04
                                        -topn 4 4
                                        -topn_beam 0 0
                                        -toprule
                                        -transform legacy dct
                                        -unit_area yes yes
                                        -upperf 6855.4976 6.800000e+03
                                        -uw 1.0 1.000000e+00
                                        -vad_postspeech 50 50
                                        -vad_prespeech 20 20
                                        -vad_startspeech 10 10
                                        -vad_threshold 3.0 3.000000e+00
                                        -var
                                        -varfloor 0.0001 1.000000e-04
                                        -varnorm no no
                                        -verbose no no
                                        -warp_params
                                        -warp_type inverse_linear inverse_linear
                                        -wbeam 7e-29 7.000000e-29
                                        -wip 0.65 6.500000e-01
                                        -wlen 0.025625 2.562500e-02
                                        INFO: feat.c(715): Initializing feature stream to type: ‘1s_c_d_dd’, ceplen=13, CMN=‘batch’, VARNORM=‘no’, AGC=‘none’
                                        INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38
                                        INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                                        INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
                                        INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                                        INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
                                        INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices
                                        INFO: acmod.c(113): Attempting to use PTM computation module
                                        INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means
                                        INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
                                        INFO: ms_gauden.c(244): 128x13
                                        INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances
                                        INFO: ms_gauden.c(304): 222 variance values floored
                                        INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump
                                        INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION
                                        INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126
                                        INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones
                                        INFO: ptm_mgau.c(837): Maximum top-N: 4
                                        INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
                                        INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries
                                        INFO: dict.c(333): Reading main dictionary: /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic
                                        INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones
                                        INFO: dict.c(336): 29 words read
                                        INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict
                                        INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
                                        INFO: dict.c(361): 5 words read
                                        INFO: dict2pid.c(396): Building PID tables for dictionary
                                        INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
                                        INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones
                                        INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones
                                        INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
                                        INFO: ngram_model_trie.c(365): Header doesn’t match
                                        INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
                                        INFO: ngram_model_trie.c(193): LM of order 3
                                        INFO: ngram_model_trie.c(195): #1-grams: 25
                                        INFO: ngram_model_trie.c(195): #2-grams: 46
                                        INFO: ngram_model_trie.c(195): #3-grams: 23
                                        INFO: lm_trie.c(474): Training quantizer
                                        INFO: lm_trie.c(482): Building LM trie
                                        INFO: ngram_search_fwdtree.c(74): Initializing search tree
                                        INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
                                        INFO: ngram_search_fwdtree.c(186): Creating search channels
                                        INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
                                        INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
                                        INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                                        INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41
                                        Error opening audio device plughw:1,0 for capture: Invalid argument
                                        FATAL: “continuous.c”, line 245: Failed to open audio device
                                          I don’t know…
                                          i would open an issue on the MMM-voice github repo, with the log file and ask for help .
                                            @sdetweil done, thank you for all of your help, I appreciate you taking time out of your day to troubleshoot this with me, you’ve helped me with a ton of stuff and i really appreciate it.
                                            • 4 / 5
