    MM won't run, blank screen with cursor showing after updating
    81 Posts 2 Posters 53.3k Views 2 Watching
      jmartin1009 @sdetweil
      pi@raspberrypi:~/MagicMirror $ pocketsphinx_continuous --help
      ERROR: "cmd_ln.c", line 607: Unknown argument name '--help'
      ERROR: "cmd_ln.c", line 704: Failed to parse arguments list
      INFO: continuous.c(295): Specify '-infile <file.wav>' to recognize from file or '-inmic yes' to recognize from microphone.
        sdetweil @jmartin1009
        @jmartin1009 try -v instead of --help
        J 1 Reply Last reply
          ERROR: "cmd_ln.c", line 607: Unknown argument name '-v'
            @jmartin1009 grrr. Programmers
              @sdetweil as a programmer in college right now, i relate lmao any leads or ideas about it?
                @jmartin1009 if you give it NO parms, it dumps them out…
                SO, pocketsphinx_continuous 2>somefile
                to get the list of possible parms
                J S 2 Replies Last reply
                  ERROR: "cmd_ln.c", line 682: No arguments given, available options are:
                  Arguments list definition:
                  [NAME]			[DEFLT]		[DESCR]
                  -adcdev					Name of audio device to use for input.
                  -agc			none		Automatic gain control for c0 ('max', 'emax', 'noise', or 'none')
                  -agcthresh		2.0		Initial threshold for automatic gain control
                  -allphone				Perform phoneme decoding with phonetic lm
                  -allphone_ci		yes		Perform phoneme decoding with phonetic lm and context-independent units only
                  -alpha			0.97		Preemphasis parameter
                  -argfile				Argument file giving extra arguments.
                  -ascale			20.0		Inverse of acoustic model scale for confidence score calculation
                  -aw			1		Inverse weight applied to acoustic scores.
                  -backtrace		no		Print results and backtraces to log.
                  -beam			1e-48		Beam width applied to every frame in Viterbi search (smaller values mean wider beam)
                  -bestpath		yes		Run bestpath (Dijkstra) search over word lattice (3rd pass)
                  -bestpathlw		9.5		Language model probability weight for bestpath search
                  -ceplen			13		Number of components in the input feature vector
                  -cmn			live		Cepstral mean normalization scheme ('live', 'batch', or 'none')
                  -cmninit		40,3,-1		Initial values (comma-separated) for cepstral mean when 'live' is used
                  -compallsen		no		Compute all senone scores in every frame (can be faster when there are many senones)
                  -dict					Main pronunciation dictionary (lexicon) input file
                  -dictcase		no		Dictionary is case sensitive (NOTE: case insensitivity applies to ASCII characters only)
                  -dither			no		Add 1/2-bit noise
                  -doublebw		no		Use double bandwidth filters (same center freq)
                  -ds			1		Frame GMM computation downsampling ratio
                  -fdict					Noise word pronunciation dictionary input file
                  -feat			1s_c_d_dd	Feature stream type, depends on the acoustic model
                  -featparams				File containing feature extraction parameters.
                  -fillprob		1e-8		Filler word transition probability
                  -frate			100		Frame rate
                  -fsg					Sphinx format finite state grammar file
                  -fsgusealtpron		yes		Add alternate pronunciations to FSG
                  -fsgusefiller		yes		Insert filler words at each state.
                  -fwdflat		yes		Run forward flat-lexicon search over word lattice (2nd pass)
                  -fwdflatbeam		1e-64		Beam width applied to every frame in second-pass flat search
                  -fwdflatefwid		4		Minimum number of end frames for a word to be searched in fwdflat search
                  -fwdflatlw		8.5		Language model probability weight for flat lexicon (2nd pass) decoding
                  -fwdflatsfwin		25		Window of frames in lattice to search for successor words in fwdflat search
                  -fwdflatwbeam		7e-29		Beam width applied to word exits in second-pass flat search
                  -fwdtree		yes		Run forward lexicon-tree search (1st pass)
                  -hmm					Directory containing acoustic model files.
                  -infile					Audio file to transcribe.
                  -inmic			no		Transcribe audio from microphone.
                  -input_endian		little		Endianness of input data, big or little, ignored if NIST or MS Wav
                  -jsgf					JSGF grammar file
                  -keyphrase				Keyphrase to spot
                  -kws					A file with keyphrases to spot, one per line
                  -kws_delay		10		Delay to wait for best detection score
                  -kws_plp		1e-1		Phone loop probability for keyphrase spotting
                  -kws_threshold		1e-30		Threshold for p(hyp)/p(alternatives) ratio
                  -latsize		5000		Initial backpointer table size
                  -lda					File containing transformation matrix to be applied to features (single-stream features only)
                  -ldadim			0		Dimensionality of output of feature transformation (0 to use entire matrix)
                  -lifter			0		Length of sin-curve for liftering, or 0 for no liftering.
                  -lm					Word trigram language model input file
                  -lmctl					Specify a set of language model
                  -lmname					Which language model in -lmctl to use by default
                  -logbase		1.0001		Base in which all log-likelihoods calculated
                  -logfn					File to write log messages in
                  -logspec		no		Write out logspectral files instead of cepstra
                  -lowerf			133.33334	Lower edge of filters
                  -lpbeam			1e-40		Beam width applied to last phone in words
                  -lponlybeam		7e-29		Beam width applied to last phone in single-phone words
                  -lw			6.5		Language model probability weight
                  -maxhmmpf		30000		Maximum number of active HMMs to maintain at each frame (or -1 for no pruning)
                  -maxwpf			-1		Maximum number of distinct word exits at each frame (or -1 for no pruning)
                  -mdef					Model definition input file
                  -mean					Mixture gaussian means input file
                  -mfclogdir				Directory to log feature files to
                  -min_endfr		0		Nodes ignored in lattice construction if they persist for fewer than N frames
                  -mixw					Senone mixture weights input file (uncompressed)
                  -mixwfloor		0.0000001	Senone mixture weights floor (applied to data from -mixw file)
                  -mllr					MLLR transformation to apply to means and variances
                  -mmap			yes		Use memory-mapped I/O (if possible) for model files
                  -ncep			13		Number of cep coefficients
                  -nfft			512		Size of FFT
                  -nfilt			40		Number of filter banks
                  -nwpen			1.0		New word transition penalty
                  -pbeam			1e-48		Beam width applied to phone transitions
                  -pip			1.0		Phone insertion penalty
                  -pl_beam		1e-10		Beam width applied to phone loop search for lookahead
                  -pl_pbeam		1e-10		Beam width applied to phone loop transitions for lookahead
                  -pl_pip			1.0		Phone insertion penalty for phone loop
                  -pl_weight		3.0		Weight for phoneme lookahead penalties
                  -pl_window		5		Phoneme lookahead window size, in frames
                  -rawlogdir				Directory to log raw audio files to
                  -remove_dc		no		Remove DC offset from each frame
                  -remove_noise		yes		Remove noise with spectral subtraction in mel-energies
                  -remove_silence		yes		Enables VAD, removes silence frames from processing
                  -round_filters		yes		Round mel filter frequencies to DFT points
                  -samprate		16000		Sampling rate
                  -seed			-1		Seed for random number generator; if less than zero, pick our own
                  -sendump				Senone dump (compressed mixture weights) input file
                  -senlogdir				Directory to log senone score files to
                  -senmgau				Senone to codebook mapping input file (usually not needed)
                  -silprob		0.005		Silence word transition probability
                  -smoothspec		no		Write out cepstral-smoothed logspectral files
                  -svspec					Subvector specification (e.g., 24,0-11/25,12-23/26-38 or 0-12/13-25/26-38)
                  -time			no		Print word times in file transcription.
                  -tmat					HMM state transition matrix input file
                  -tmatfloor		0.0001		HMM state transition probability floor (applied to -tmat file)
                  -topn			4		Maximum number of top Gaussians to use in scoring.
                  -topn_beam		0		Beam width used to determine top-N Gaussians (or a list, per-feature)
                  -toprule				Start rule for JSGF (first public rule is default)
                  -transform		legacy		Which type of transform to use to calculate cepstra (legacy, dct, or htk)
                  -unit_area		yes		Normalize mel filters to unit area
                  -upperf			6855.4976	Upper edge of filters
                  -uw			1.0		Unigram weight
                  -vad_postspeech		50		Num of silence frames to keep after from speech to silence.
                  -vad_prespeech		20		Num of speech frames to keep before silence to speech.
                  -vad_startspeech	10		Num of speech frames to trigger vad from silence to speech.
                  -vad_threshold		3.0		Threshold for decision between noise and silence frames. Log-ratio between signal level and noise level.
                  -var					Mixture gaussian variances input file
                  -varfloor		0.0001		Mixture gaussian variance floor (applied to data from -var file)
                  -varnorm		no		Variance normalize each utterance (only if CMN == current)
                  -verbose		no		Show input filenames
                  -warp_params				Parameters defining the warping function
                  -warp_type		inverse_linear	Warping function type (or shape)
                  -wbeam			7e-29		Beam width applied to word exits
                  -wip			0.65		Word insertion penalty
                  -wlen			0.025625	Hamming window length
                    @sdetweil also, in the node_modules/pocketsphinx_continuous/index.js
                    show me this
                     var pc = spawn('pocketsphinx_continuous', [
                        '-adcdev',
                        'plughw:' + this.microphone,
                        '-inmic',
                        'yes',
                        '-lm',
                        'modules/MMM-voice/' + this.setId + '.lm',
                        '-dict',
                        'modules/MMM-voice/' + this.setId + '.dic'
                    also check for the two files in the mmm-voice folder MMM-voice.lm and MMM-voice.dic
                      @sdetweil this is the entire index file, didn’t see that anywhere
                      const spawn = require('child_process').spawn;
                      const EventEmitter = require('events').EventEmitter;
                      const util = require('util');
                      const reservedEvents = {
                        close: true,
                        error: true,
                        data: true,
                        end: true,
                        readable: true,
                        drain: true,
                        finish: true,
                        pipe: true,
                        unpipe: true
                      function PocketSphinxContinuous(config) {
                        this.setId = config.setId;
                        this.verbose = config.verbose;
                        this.microphone = config.microphone;
                        this.autostart = config.autostart;
                        if (!config.hasOwnProperty('autostart') || config.autostart === true) {
                          this.start();
                        EventEmitter.call(this);
                      PocketSphinxContinuous.prototype.start = function() {
                        if (!this.isListening()) {
                          let mic = this.microphone;
                          // if name starts with number
                          if (typeof this.microphone === 'number' || this.microphone.match(/^\d/)) {
                            mic = `plughw:${this.microphone}`;
                          this._psc = spawn('pocketsphinx_continuous', [
                            '-adcdev',
                            mic,
                            '-inmic',
                            'yes',
                            '-lm',
                            `modules/${this.setId}/${this.setId}.lm`,
                            '-dict',
                            `modules/${this.setId}/${this.setId}.dic`
                          this._psc.stdout.on('data', data => {
                            const output = data.toString().trim();
                            if (output) {
                              this.emit('data', output);
                            // Also try to emit an event for the actual data, unless of course the
                            // event is a reserved one.
                            const eventName = output.toLowerCase();
                            if (!reservedEvents[eventName]) {
                              this.emit(eventName, output);
                          this._psc.stderr.on('data', data => {
                            if (this.verbose && output) {
                              this.emit('debug', data);
                          this._psc.on('close', code => {
                            this.emit('error', code);
                          this._psc.on('error', err => {
                            this.emit('error', err);
                      PocketSphinxContinuous.prototype.stop = function() {
                        if (this.isListening()) {
                          this._psc.kill();
                      PocketSphinxContinuous.prototype.isListening = function() {
                        return this._psc && !this._psc.killed;
                      util.inherits(PocketSphinxContinuous, EventEmitter);
                      module.exports = PocketSphinxContinuous;
                      also, both of those files are there.
                        @jmartin1009 said in MM won't run, blank screen with cursor showing after updating:
                        from your response
                        >       '-adcdev',
                        >       mic,
                        >       '-inmic',
                        >       'yes',
                        >       '-lm',
                        >       '-dict',
                        so, only the path to the files can be wrong…
                        so, change them to (assume u are running as user pi)
                               '-adcdev',
                               mic,
                               '-inmic',
                               'yes',
                               '-lm',
                               `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.lm`,
                               '-dict',
                               `/home/pi/MagicMirror/modules/${this.setId}/${this.setId}.dic`
                          @jmartin1009 you have the file with my fixes in it… btw
                            @sdetweil which file? and i’ll go change those right now
                              @jmartin1009
                              ~/MagicMirror/modules/MMM-voice/node_modules/pocketsphinx_continuous/index.js
                              same file u just showed me
                              J 2 Replies Last reply
                                @sdetweil oh yeah, im going to change the file paths in it right now in the one you sent last.
                                  @sdetweil just changed those file paths, tried running MM, still getting “ERROR undefined” next to the little microphone
                                    @jmartin1009 yeh, only care about the debug log
                                      @sdetweil ```
                                      INFO: pocketsphinx.c(153): Parsed model-specific feature parameters from /usr/local/share/pocketsphinx/model/en-us/en-us/feat.params
                                      Current configuration:
                                      [NAME] [DEFLT] [VALUE]
                                      -agc none none
                                      -agcthresh 2.0 2.000000e+00
                                      -allphone
                                      -allphone_ci yes yes
                                      -alpha 0.97 9.700000e-01
                                      -ascale 20.0 2.000000e+01
                                      -aw 1 1
                                      -backtrace no no
                                      -beam 1e-48 1.000000e-48
                                      -bestpath yes yes
                                      -bestpathlw 9.5 9.500000e+00
                                      -ceplen 13 13
                                      -cmn live batch
                                      -cmninit 40,3,-1 41.00,-5.29,-0.12,5.09,2.48,-4.07,-1.37,-1.78,-5.08,-2.05,-6.45,-1.42,1.17
                                      -compallsen no no
                                      -dict /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic
                                      -dictcase no no
                                      -dither no no
                                      -doublebw no no
                                      -ds 1 1
                                      -fdict
                                      -feat 1s_c_d_dd 1s_c_d_dd
                                      -featparams
                                      -fillprob 1e-8 1.000000e-08
                                      -frate 100 100
                                      -fsg
                                      -fsgusealtpron yes yes
                                      -fsgusefiller yes yes
                                      -fwdflat yes yes
                                      -fwdflatbeam 1e-64 1.000000e-64
                                      -fwdflatefwid 4 4
                                      -fwdflatlw 8.5 8.500000e+00
                                      -fwdflatsfwin 25 25
                                      -fwdflatwbeam 7e-29 7.000000e-29
                                      -fwdtree yes yes
                                      -hmm /usr/local/share/pocketsphinx/model/en-us/en-us
                                      -input_endian little little
                                      -jsgf
                                      -keyphrase
                                      -kws
                                      -kws_delay 10 10
                                      -kws_plp 1e-1 1.000000e-01
                                      -kws_threshold 1e-30 1.000000e-30
                                      -latsize 5000 5000
                                      -lda
                                      -ldadim 0 0
                                      -lifter 0 22
                                      -lm /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.lm
                                      -lmctl
                                      -lmname
                                      -logbase 1.0001 1.000100e+00
                                      -logfn
                                      -logspec no no
                                      -lowerf 133.33334 1.300000e+02
                                      -lpbeam 1e-40 1.000000e-40
                                      -lponlybeam 7e-29 7.000000e-29
                                      -lw 6.5 6.500000e+00
                                      -maxhmmpf 30000 30000
                                      -maxwpf -1 -1
                                      -mdef
                                      -mean
                                      -mfclogdir
                                      -min_endfr 0 0
                                      -mixw
                                      -mixwfloor 0.0000001 1.000000e-07
                                      -mllr
                                      -mmap yes yes
                                      -ncep 13 13
                                      -nfft 512 512
                                      -nfilt 40 25
                                      -nwpen 1.0 1.000000e+00
                                      -pbeam 1e-48 1.000000e-48
                                      -pip 1.0 1.000000e+00
                                      -pl_beam 1e-10 1.000000e-10
                                      -pl_pbeam 1e-10 1.000000e-10
                                      -pl_pip 1.0 1.000000e+00
                                      -pl_weight 3.0 3.000000e+00
                                      -pl_window 5 5
                                      -rawlogdir
                                      -remove_dc no no
                                      -remove_noise yes yes
                                      -remove_silence yes yes
                                      -round_filters yes yes
                                      -samprate 16000 1.600000e+04
                                      -seed -1 -1
                                      -sendump
                                      -senlogdir
                                      -senmgau
                                      -silprob 0.005 5.000000e-03
                                      -smoothspec no no
                                      -svspec 0-12/13-25/26-38
                                      -tmat
                                      -tmatfloor 0.0001 1.000000e-04
                                      -topn 4 4
                                      -topn_beam 0 0
                                      -toprule
                                      -transform legacy dct
                                      -unit_area yes yes
                                      -upperf 6855.4976 6.800000e+03
                                      -uw 1.0 1.000000e+00
                                      -vad_postspeech 50 50
                                      -vad_prespeech 20 20
                                      -vad_startspeech 10 10
                                      -vad_threshold 3.0 3.000000e+00
                                      -var
                                      -varfloor 0.0001 1.000000e-04
                                      -varnorm no no
                                      -verbose no no
                                      -warp_params
                                      -warp_type inverse_linear inverse_linear
                                      -wbeam 7e-29 7.000000e-29
                                      -wip 0.65 6.500000e-01
                                      -wlen 0.025625 2.562500e-02
                                      INFO: feat.c(715): Initializing feature stream to type: ‘1s_c_d_dd’, ceplen=13, CMN=‘batch’, VARNORM=‘no’, AGC=‘none’
                                      INFO: acmod.c(162): Using subvector specification 0-12/13-25/26-38
                                      INFO: mdef.c(518): Reading model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                                      INFO: mdef.c(531): Found byte-order mark BMDF, assuming this is a binary mdef file
                                      INFO: bin_mdef.c(336): Reading binary model definition: /usr/local/share/pocketsphinx/model/en-us/en-us/mdef
                                      INFO: bin_mdef.c(516): 42 CI-phone, 137053 CD-phone, 3 emitstate/phone, 126 CI-sen, 5126 Sen, 29324 Sen-Seq
                                      INFO: tmat.c(149): Reading HMM transition probability matrices: /usr/local/share/pocketsphinx/model/en-us/en-us/transition_matrices
                                      INFO: acmod.c(113): Attempting to use PTM computation module
                                      INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/means
                                      INFO: ms_gauden.c(242): 42 codebook, 3 feature, size:
                                      INFO: ms_gauden.c(244): 128x13
                                      INFO: ms_gauden.c(127): Reading mixture gaussian parameter: /usr/local/share/pocketsphinx/model/en-us/en-us/variances
                                      INFO: ms_gauden.c(304): 222 variance values floored
                                      INFO: ptm_mgau.c(475): Loading senones from dump file /usr/local/share/pocketsphinx/model/en-us/en-us/sendump
                                      INFO: ptm_mgau.c(499): BEGIN FILE FORMAT DESCRIPTION
                                      INFO: ptm_mgau.c(562): Rows: 128, Columns: 5126
                                      INFO: ptm_mgau.c(594): Using memory-mapped I/O for senones
                                      INFO: ptm_mgau.c(837): Maximum top-N: 4
                                      INFO: phone_loop_search.c(114): State beam -225 Phone exit beam -225 Insertion penalty 0
                                      INFO: dict.c(320): Allocating 4130 * 20 bytes (80 KiB) for word entries
                                      INFO: dict.c(333): Reading main dictionary: /home/pi/MagicMirror/modules/MMM-voice/MMM-voice.dic
                                      INFO: dict.c(213): Dictionary size 29, allocated 0 KiB for strings, 0 KiB for phones
                                      INFO: dict.c(336): 29 words read
                                      INFO: dict.c(358): Reading filler dictionary: /usr/local/share/pocketsphinx/model/en-us/en-us/noisedict
                                      INFO: dict.c(213): Dictionary size 34, allocated 0 KiB for strings, 0 KiB for phones
                                      INFO: dict.c(361): 5 words read
                                      INFO: dict2pid.c(396): Building PID tables for dictionary
                                      INFO: dict2pid.c(406): Allocating 42^3 * 2 bytes (144 KiB) for word-initial triphones
                                      INFO: dict2pid.c(132): Allocated 21336 bytes (20 KiB) for word-final triphones
                                      INFO: dict2pid.c(196): Allocated 21336 bytes (20 KiB) for single-phone word triphones
                                      INFO: ngram_model_trie.c(354): Trying to read LM in trie binary format
                                      INFO: ngram_model_trie.c(365): Header doesn’t match
                                      INFO: ngram_model_trie.c(177): Trying to read LM in arpa format
                                      INFO: ngram_model_trie.c(193): LM of order 3
                                      INFO: ngram_model_trie.c(195): #1-grams: 25
                                      INFO: ngram_model_trie.c(195): #2-grams: 46
                                      INFO: ngram_model_trie.c(195): #3-grams: 23
                                      INFO: lm_trie.c(474): Training quantizer
                                      INFO: lm_trie.c(482): Building LM trie
                                      INFO: ngram_search_fwdtree.c(74): Initializing search tree
                                      INFO: ngram_search_fwdtree.c(101): 28 unique initial diphones
                                      INFO: ngram_search_fwdtree.c(186): Creating search channels
                                      INFO: ngram_search_fwdtree.c(323): Max nonroot chan increased to 157
                                      INFO: ngram_search_fwdtree.c(333): Created 28 root, 29 non-root channels, 5 single-phone words
                                      INFO: ngram_search_fwdflat.c(157): fwdflat: min_ef_width = 4, max_sf_win = 25
                                      INFO: continuous.c(307): pocketsphinx_continuous COMPILED ON: Sep 29 2019, AT: 15:24:41
                                      Error opening audio device plughw:1,0 for capture: Invalid argument
                                      FATAL: “continuous.c”, line 245: Failed to open audio device
                                        I don’t know…
                                        i would open an issue on the MMM-voice github repo, with the log file and ask for help .
                                          @sdetweil done, thank you for all of your help, I appreciate you taking time out of your day to troubleshoot this with me, you’ve helped me with a ton of stuff and i really appreciate it.
                                            @jmartin1009 glad I could help… sorry we couldn’t push it over the line
                                            • 4 / 5
