Unsolved Mirror goes black after hours
@tbs86 ia this on a pi?
I had to do this
https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html
and reboot
to stop my frequent black screens.
then I added this module to record more info
https://github.com/shbatm/MMM-Logging
Yes pi3 will try once i am home thanks for the help
@sdetweil did what you said pie ran over night. Went to work and it was blank again. I think it’s something do to with one of my modules Google maps. I saw the command prompt and saw a error I believe.
@tbs86 ok, one step in the right direction
@sdetweil anyway to confirm its the module?
@tbs86 are you using pm2?
if so, look in the ~/.pm2/logs folder MagicMirror.error.log
also the heavy way.
edit the config and add
disabled: true,to the module you think it is, and then restart
Sorry still new to this. Disable the module and see if this fixed the issue?
@tbs86 yes, that is another way…
Ok will try and report back
If it was the MMM-GoogleMapsTraffic module that you’re seeing errors with, I had to comment out the console.log line noted in this commit, which fixed the black screen issue I was having. https://github.com/vicmora/MMM-GoogleMapsTraffic/pull/24/commits/90f51f6f7a155241a4371106ea3ca899b20a7380
