    Mirror goes black after hours
    11 Posts 3 Posters 4.4k Views 4 Watching
    • T Offline
      tbs86 @sdetweil
      @sdetweil did what you said pie ran over night. Went to work and it was blank again. I think it’s something do to with one of my modules Google maps. I saw the command prompt and saw a error I believe.
        sdetweil @tbs86
        @tbs86 ok, one step in the right direction
        • T Offline
          tbs86 @sdetweil
          @sdetweil anyway to confirm its the module?
            sdetweil @tbs86
            @tbs86 are you using pm2?
            if so, look in the ~/.pm2/logs folder MagicMirror.error.log
            also the heavy way.
            edit the config and add
            disabled: true,
            to the module you think it is, and then restart
            • T Offline
              tbs86
              Sorry still new to this. Disable the module and see if this fixed the issue?
                sdetweil @tbs86
                @tbs86 yes, that is another way…
                • T Offline
                  tbs86
                  Ok will try and report back
                  • buzzkcB Offline
                    buzzkc
                    If it was the MMM-GoogleMapsTraffic module that you’re seeing errors with, I had to comment out the console.log line noted in this commit, which fixed the black screen issue I was having. https://github.com/vicmora/MMM-GoogleMapsTraffic/pull/24/commits/90f51f6f7a155241a4371106ea3ca899b20a7380
                    Darren
                    My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
