    Mirror goes black after hours
    11 Posts 3 Posters 5.1k Views 4 Watching
      sdetweil @tbs86
      @tbs86 ia this on a pi?
      I had to do this
      https://wpitchoune.net/tricks/raspberry_pi3_increase_swap_size.html
      and reboot
      to stop my frequent black screens.
      then I added this module to record more info
      https://github.com/shbatm/MMM-Logging
      T 2 Replies Last reply Reply Quote 0
      • T Offline
        tbs86 @sdetweil
        Yes pi3 will try once i am home thanks for the help
        • T Offline
          tbs86 @sdetweil
          @sdetweil did what you said pie ran over night. Went to work and it was blank again. I think it’s something do to with one of my modules Google maps. I saw the command prompt and saw a error I believe.
            sdetweil @tbs86
            @tbs86 ok, one step in the right direction
            • T Offline
              tbs86 @sdetweil
              @sdetweil anyway to confirm its the module?
                sdetweil @tbs86
                @tbs86 are you using pm2?
                if so, look in the ~/.pm2/logs folder MagicMirror.error.log
                also the heavy way.
                edit the config and add
                disabled: true,
                to the module you think it is, and then restart
                • T Offline
                  tbs86
                  Sorry still new to this. Disable the module and see if this fixed the issue?
                    sdetweil @tbs86
                    @tbs86 yes, that is another way…
                    • T Offline
                      tbs86
                      Ok will try and report back
                      • buzzkcB Offline
                        buzzkc
                        If it was the MMM-GoogleMapsTraffic module that you’re seeing errors with, I had to comment out the console.log line noted in this commit, which fixed the black screen issue I was having. https://github.com/vicmora/MMM-GoogleMapsTraffic/pull/24/commits/90f51f6f7a155241a4371106ea3ca899b20a7380
                        Darren
                        My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
