    MagicMirror wont start after failed update
    6 Posts 2 Posters 1.1k Views 2 Watching
    • U Offline
      unknownuser26
      I have not worked with the MagicMirror for too long.
      I did an updaet a few days ago and had a power outage at that very moment :umbrella_with_rain_drops: . Although there are backup but unfortunately these are already a few months old :confounded_face: .
      Since the power failure Magicmirror does not start anymore. I have again executed the command git pull && npm install without success.
      Here’s the npm log:
      0 info it worked with it ends with ok
      1 verbose cli [‘/ usr / bin / node’, ‘/ usr / bin / npm’, ‘start’]
      2 info using npm@6.11.3
      3 info using node@v10.16.3
      4 verbose run-script [‘prestart’, ‘start’, ‘poststart’]
      5 info lifecycle magicmirror@2.9.0~prestart: magicmirror@2.9.0
      6 info lifecycle magicmirror@2.9.0~start: magicmirror@2.9.0
      7 verbose lifecycle magicmirror@2.9.0~start: unsafe-perm in lifecycle true
      8 verbose lifecycle magicmirror@2.9.0~start: PATH: /usr/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local / sbin: / usr / local / bin: / usr / sbin: / usr / bin: / sbin: / bin: / usr / local / games / usr / games
      9 verbose lifecycle magicmirror@2.9.0~start: CWD: / home / pi / MagicMirror
      10 silly lifecycle magicmirror@2.9.0~start: Args: [‘-c’, ‘sh run-start.sh’]
      11 silly lifecycle magicmirror@2.9.0~start: Returned: code: 1 signal: zero
      12 info lifecycle magicmirror@2.9.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.9.0 start: sh run-start.sh
      13 verbose stack Exit status 1
      13 verbose stack at EventEmitter. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:332:16)
      13 verbose stack at EventEmitter.emit (events.js: 198: 13)
      13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
      13 verbose stack at ChildProcess.emit (events.js: 198: 13)
      13 verbose stack at maybeClose (internal / child_process.js: 982: 16)
      13 verbose stack at Process.ChildProcess._handle.onexit (internal / child_process.js: 259: 5)
      14 verbose pkgid magicmirror@2.9.0
      15 verbose cwd / home / pi / MagicMirror
      16 verbose Linux 4.19.66-v7 +
      17 verbose argv “/ usr / bin / node” “/ usr / bin / npm” “start”
      18 verbose node v10.16.3
      19 verbose npm v6.11.3
      20 error code ELIFECYCLE
      21 error errno 1
      22 error magicmirror@2.9.0 start: sh run-start.sh
      22 error Exit status 1
      23 error Failed at the magicmirror@2.9.0 start script.
      23 error This is probably not a problem with npm. There is likely additional logging output above.
      24 verbose exit [1, true]
      I hope someone can help me.
        sdetweil @unknownuser26
        @unknownuser26 always fun when the lights go out!
        do
        rm -rf node_modules
        npm install
        that should get you back to working
        • U Offline
          unknownuser26
          Thanks alot. The Magic Mirror starts again.
          Unfortunately, I still get this message when I run npm install. Can you ignore the warnings? The instruction npm audit fix could not solve the problem either
          pi@magicmirror:~/MagicMirror $ npm install
          npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
          electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
           node ./download-chromedriver.js
          successfully dowloaded and extracted!
           electron@3.0.13 postinstall /home/pi/MagicMirror/node_modules/electron
           node install.js
          Downloading tmp-11791-1-SHASUMS256.txt-3.0.13
          [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
          > magicmirror@2.9.0 install /home/pi/MagicMirror
          > cd vendor && npm install
          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          audited 220 packages in 6.3s
          found 5 vulnerabilities (4 low, 1 high)
            run `npm audit fix` to fix them, or `npm audit` for details
           magicmirror@2.9.0 postinstall /home/pi/MagicMirror
           sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
          MagicMirror installation successful!
          magicmirror@2.9.0 install-fonts /home/pi/MagicMirror
          cd fonts && npm install
          audited 1 package in 1.49s
          found 0 vulnerabilities
          npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
          npm WARN acorn-jsx@5.0.2 requires a peer of acorn@^6.0.0 || ^7.0.0 but none is installed. You must install peer dependencies yourself.
          added 1044 packages from 1317 contributors and audited 3477 packages in 351.357s
            @unknownuser26 yes, they added checking for hacker vulnerabilities…
            one cannot fix them all… so, run audit fix once, and ignore the rest… they are just warnings
            • U Offline
              unknownuser26
              @sdetweil said in MagicMirror wont start after failed update:
              one cannot fix them all… so, run audir fix once, and ignore the rest… they are just warnings
              Thank you for your help
                @unknownuser26 my pleasure
