    build MMM-AssistantMk2 Rebuild Failed
    10 Posts 3 Posters 2.1k Views 3 Watching
      marion001
      Hi everybody! I had problems building MMM-AssistantMk2 in MagicMirror version 2.9.0 using: ./node_modules/.bin/electron-rebuild
      Who could possibly eat
      In previous versions there was no error
      full error: https://pastebin.com/raw/P9dZyBUn
      An unhandled error occurred inside electron-rebuild
      gyp info it worked if it ends with ok
      gyp info using node-gyp@5.0.4
      gyp info using node@10.16.3 | linux | arm64
      gyp info find Python using Python version 2.7.15 found at “/usr/bin/python”
      gyp http GET https://electronjs.org/headers/v3.0.13/iojs-v3.0.13-headers.tar.gz
      gyp http 200 https://electronjs.org/headers/v3.0.13/iojs-v3.0.13-headers.tar.gz
      gyp http GET https://electronjs.org/headers/v3.0.13/SHASUMS256.txt
      gyp http 200 https://electronjs.org/headers/v3.0.13/SHASUMS256.txt
      gyp info spawn /usr/bin/python
      gyp info spawn args [ ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/gyp/gyp_main.py’,
      gyp info spawn args ‘binding.gyp’,
      gyp info spawn args ‘-f’,
      gyp info spawn args ‘make’,
      gyp info spawn args ‘-I’,
      gyp info spawn args ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build/config.gypi’,
      gyp info spawn args ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/addon.gypi’,
      gyp info spawn args ‘/home/pi/.electron-gyp/iojs-3.0.13/common.gypi’,
      gyp info spawn args ‘-Dlibrary=shared_library’,
      gyp info spawn args ‘-Dvisibility=default’,
      gyp info spawn args ‘-Dnode_root_dir=/home/pi/.electron-gyp/iojs-3.0.13’,
      gyp info spawn args ‘-Dnode_gyp_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp’,
      gyp info spawn args ‘-Dnode_lib_file=/home/pi/.electron-gyp/iojs-3.0.13/<(target_arch)/iojs.lib’,
      gyp info spawn args ‘-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc’,
      gyp info spawn args ‘-Dnode_engine=v8’,
      gyp info spawn args ‘–depth=.’,
      gyp info spawn args ‘–no-parallel’,
      gyp info spawn args ‘–generator-output’,
      gyp info spawn args ‘build’,
      gyp info spawn args ‘-Goutput_dir=.’ ]
      gyp info spawn make
      gyp info spawn args [ ‘BUILDTYPE=Release’, ‘-C’, ‘build’ ]
      make: Entering directory ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build’
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/init.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/avl/avl.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/backoff/backoff.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_args.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_stack.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_stack_builder.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channel_trace.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channelz.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/channelz_registry.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/connected_channel.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/handshaker.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/handshaker_registry.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/channel/status_util.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/compression.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/compression_args.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/compression_internal.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/message_compress.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/stream_compression.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/stream_compression_gzip.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/compression/stream_compression_identity.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/debug/stats.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/debug/stats_data.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/http/format_request.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/http/httpcli.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/http/parser.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/buffer_list.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/call_combiner.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/cfstream_handle.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/combiner.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint_cfstream.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint_pair_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint_pair_uv.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/endpoint_pair_windows.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/error.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/error_cfstream.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_epoll1_linux.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_epollex_linux.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_poll_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/ev_windows.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/exec_ctx.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/executor.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/executor/mpmcqueue.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/executor/threadpool.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/fork_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/fork_windows.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/gethostname_fallback.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/gethostname_host_name_max.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/gethostname_sysconf.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/grpc_if_nametoindex_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/grpc_if_nametoindex_unsupported.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/internal_errqueue.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iocp_windows.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr_custom.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr_internal.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr_posix_cfstream.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr_uv.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/iomgr_windows.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/is_epollexclusive_available.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/load_file.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/lockfree_event.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/polling_entity.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/pollset.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/pollset_custom.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/pollset_set.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/pollset_set_custom.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/pollset_set_windows.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/pollset_uv.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/pollset_windows.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/resolve_address.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/resolve_address_custom.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/resolve_address_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/resolve_address_windows.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/resource_quota.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/sockaddr_utils.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/socket_factory_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/socket_mutator.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/socket_utils_common_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/socket_utils_linux.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/socket_utils_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/socket_utils_uv.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/socket_utils_windows.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/socket_windows.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_client.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_client_cfstream.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_client_custom.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_client_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_client_windows.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_custom.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_server.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_server_custom.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_server_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_server_utils_posix_common.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_server_utils_posix_ifaddrs.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_server_utils_posix_noifaddrs.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_server_windows.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_uv.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/tcp_windows.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/time_averaged_stats.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/timer.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/timer_custom.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/timer_generic.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/timer_heap.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/timer_manager.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/timer_uv.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/udp_server.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/unix_sockets_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/unix_sockets_posix_noop.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/wakeup_fd_eventfd.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/wakeup_fd_nospecial.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/wakeup_fd_pipe.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/iomgr/wakeup_fd_posix.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/json/json.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/json/json_reader.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/json/json_string.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/json/json_writer.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/slice/b64.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/slice/percent_encoding.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/slice/slice.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/slice/slice_buffer.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/slice/slice_intern.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/slice/slice_string_helpers.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/api_trace.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/byte_buffer.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/byte_buffer_reader.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/call.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/call_details.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/call_log_batch.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/channel.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/channel_init.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/channel_ping.o
      Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/parsing.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/http/httpcli_security_connector.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/security/context/security_context.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/security/credentials/alts/alts_credentials.o
      In file included from …/deps/grpc/third_party/upb/upb/msg.h:14:0,
      from …/deps/grpc/third_party/upb/upb/generated_util.h:10,
      from …/deps/grpc/src/core/ext/upb-generated/src/proto/grpc/gcp/transport_security_common.upb.h:12,
      from …/deps/grpc/src/core/tsi/alts/handshaker/transport_security_common_api.h:29,
      from …/deps/grpc/src/core/lib/security/credentials/alts/grpc_alts_credentials_options.h:26,
      from …/deps/grpc/src/core/lib/security/credentials/alts/alts_credentials.h:26,
      from …/deps/grpc/src/core/lib/security/credentials/alts/alts_credentials.cc:21:
      …/deps/grpc/third_party/upb/upb/upb.h:27:10: fatal error: upb/port_def.inc: No such file or directory
      #include “upb/port_def.inc”
      compilation terminated.
      grpc.target.mk:531: recipe for target ‘Release/obj.target/grpc/deps/grpc/src/core/lib/security/credentials/alts/alts_credentials.o’ failed
      make: Leaving directory ‘/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/build’
      make: *** [Release/obj.target/grpc/deps/grpc/src/core/lib/security/credentials/alts/alts_credentials.o] Error 1
      gyp ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2
      gyp ERR! stack at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 5.1.15-aml-s905
      gyp ERR! command “/usr/bin/node” “/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp” “rebuild” “–target=3.0.13” “–arch=arm64” “–dist-url=https://electronjs.org/headers” “–build-from-source” “–module_name=grpc_node” “–module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_binary/electron-v3.0-linux-arm64-glibc” “–host=https://node-precompiled-binaries.grpc.io/” “–remote_path={name}/v1.24.0” “–package_name=electron-v3.0-linux-arm64-glibc.tar.gz”
      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc
      gyp ERR! node -v v10.16.3
      gyp ERR! node-gyp -v v5.0.4
      gyp ERR! not ok
      Failed with exit code: 1
      Error: gyp info it worked if it ends with ok
      gyp info spawn make
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/channel_stack_type.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/completion_queue.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/completion_queue_factory.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/event_string.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/lame_client.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/metadata_array.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/server.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/validate_metadata.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/surface/version.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/transport/bdp_estimator.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/transport/byte_stream.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/transport/connectivity_state.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/transport/error_utils.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/transport/metadata.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/transport/metadata_batch.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/transport/pid_controller.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/transport/static_metadata.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/transport/status_conversion.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/transport/status_metadata.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/transport/timeout_encoding.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/transport/transport.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/transport/transport_op_string.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/uri/uri_parser.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/lib/debug/trace.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/server/secure/server_secure_chttp2.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/bin_decoder.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/bin_encoder.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/chttp2_plugin.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/chttp2_transport.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/context_list.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/flow_control.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/frame_data.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/frame_goaway.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/frame_ping.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/frame_rst_stream.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/frame_settings.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/frame_window_update.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/hpack_encoder.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/hpack_parser.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/hpack_table.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/http2_settings.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/huffsyms.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/incoming_metadata.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/parsing.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/stream_lists.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/stream_map.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/varint.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/transport/writing.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/transport/chttp2/alpn/alpn.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/filters/http/client/http_client_filter.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/filters/http/http_filters_plugin.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/filters/http/message_compress/message_compress_filter.o
      CXX(target) Release/obj.target/grpc/deps/grpc/src/core/ext/filters/http/server/http_server_filter.o
      gyp ERR! not ok
      at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:267:84)
      at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:205:16)
      at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:156:26)
      at Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
      at Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
      at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
      at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
      at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:242:65)
      at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:143:22)
        sdetweil @marion001
        @marion001 see the issue here
        https://github.com/grpc/grpc-node/issues/1057
        need to downlevel gprc
        do
        npm uninstall gprc
        npm install gpc@1.23.3
        npm install
        maybe electron-rebuild
          marion001 @sdetweil
          thank you! I have followed you to downgrade grpc to version 1.23.3 and build successfully
          cd ~/MagicMirror/modules
          sudo rm -rf MMM-AssistantMk2/
          git clone https://github.com/eouia/MMM-AssistantMk2.git
          cd MMM-AssistantMk2
          sudo npm uninstall grpc
          sudo npm install sudo npm install grpc@1.23.3
          sudo npm install --save-dev electron-rebuild
          sudo npm install
          sudo ./node_modules/.bin/electron-rebuild
          S H 2 Replies Last reply Reply Quote 0
            sdetweil @marion001
            @marion001 great… but you should NOT use sudo
            so, can u fix the sudo problem, so u don’t use sudo anymore
            ~/MagicMirror
            sudo chown -R ???? ~/.npm
            sudo chown -R ???? ./
            where ??? is the current userid , most likely pi
            but you can get the userid from the command
            whoami
              marion001 @sdetweil
              I installed the magicmirror on androibox which has flash room armbian, I installed on the user should use sudo for full rights
              pi@MagicMirror: ~ $ id
              uid = 1000 (pi) gid = 1000 (pi) groups = 1000 (pi), 5 (tty), 6 (disk), 20 (dialout), 27 (sudo), 29 (audio), 44 (video), 46 (plugdev), 60 (games), 100 (users), 101 (systemd-journal), 104 (input), 108 (netdev), 111 (ssh), 112 (bluetooth)
              pi@MagicMirror: ~ $ whoami
              pi
              pi@MagicMirror:~$ uname -a
              Linux MagicMirror 5.1.15-aml-s905 #5.91 SMP PREEMPT Wed Jul 10 15:44:57 MSK 2019 aarch64 aarch64 aarch64 GNU/Linux
                sdetweil @marion001
                @marion001 said in build MMM-AssistantMk2 Rebuild Failed:
                but the user pi doesn’t need root to run MagicMirror
                next time you install a module, and don’t use sudo, things will break…
                best to fix it now…
                  marion001 @sdetweil
                  Yes, I’ll fix it next time, thank you. (Y)
                    sdetweil @marion001
                    @marion001 cool… can u mark this issue resolved? 3 dots to the right of the message
                    • H Offline
                      harrycool25 @marion001
                      @marion001 Uhhhhhh… I followed your steps to rebuild the thing in order for the module to work, but now it’s stuck at ‘Building module: grpc, Completed: 0’, and stays like that forever until I cancel the procedure with Ctrl+C. How can I resolve this? I really want Google Assistant to work but this is a hindrance that I want to remove.
                      • H Offline
                        harrycool25
