    build MMM-AssistantMk2 Rebuild Failed
    10 Posts 3 Posters 2.1k Views 3 Watching
      sdetweil @marion001
      @marion001 see the issue here
      https://github.com/grpc/grpc-node/issues/1057
      need to downlevel gprc
      do
      npm uninstall gprc
      npm install gpc@1.23.3
      npm install
      maybe electron-rebuild
        marion001 @sdetweil
        thank you! I have followed you to downgrade grpc to version 1.23.3 and build successfully
        cd ~/MagicMirror/modules
        sudo rm -rf MMM-AssistantMk2/
        git clone https://github.com/eouia/MMM-AssistantMk2.git
        cd MMM-AssistantMk2
        sudo npm uninstall grpc
        sudo npm install sudo npm install grpc@1.23.3
        sudo npm install --save-dev electron-rebuild
        sudo npm install
        sudo ./node_modules/.bin/electron-rebuild
        S H 2 Replies Last reply Reply Quote 0
          sdetweil @marion001
          @marion001 great… but you should NOT use sudo
          so, can u fix the sudo problem, so u don’t use sudo anymore
          ~/MagicMirror
          sudo chown -R ???? ~/.npm
          sudo chown -R ???? ./
          where ??? is the current userid , most likely pi
          but you can get the userid from the command
          whoami
            marion001 @sdetweil
            I installed the magicmirror on androibox which has flash room armbian, I installed on the user should use sudo for full rights
            pi@MagicMirror: ~ $ id
            uid = 1000 (pi) gid = 1000 (pi) groups = 1000 (pi), 5 (tty), 6 (disk), 20 (dialout), 27 (sudo), 29 (audio), 44 (video), 46 (plugdev), 60 (games), 100 (users), 101 (systemd-journal), 104 (input), 108 (netdev), 111 (ssh), 112 (bluetooth)
            pi@MagicMirror: ~ $ whoami
            pi
            pi@MagicMirror:~$ uname -a
            Linux MagicMirror 5.1.15-aml-s905 #5.91 SMP PREEMPT Wed Jul 10 15:44:57 MSK 2019 aarch64 aarch64 aarch64 GNU/Linux
              sdetweil @marion001
              @marion001 said in build MMM-AssistantMk2 Rebuild Failed:
              but the user pi doesn’t need root to run MagicMirror
              next time you install a module, and don’t use sudo, things will break…
              best to fix it now…
                marion001 @sdetweil
                Yes, I’ll fix it next time, thank you. (Y)
                  sdetweil @marion001
                  @marion001 cool… can u mark this issue resolved? 3 dots to the right of the message
                  • H Offline
                    harrycool25 @marion001
                    @marion001 Uhhhhhh… I followed your steps to rebuild the thing in order for the module to work, but now it’s stuck at ‘Building module: grpc, Completed: 0’, and stays like that forever until I cancel the procedure with Ctrl+C. How can I resolve this? I really want Google Assistant to work but this is a hindrance that I want to remove.
                    • H Offline
                      harrycool25
