Solved MMM-Alexaonoff can’t find devices
@sdetweil Hey Sam …congratulations you solved my biggest Problem on my mirror, now it works and all devices where found. Thanks thanks …you are the greatest :folded_hands: :slightly_smiling_face:
@Stoffbeuteluwe cool. Glad to hear it
@sdetweil hi Sam can I ask you again ? :grinning_face:
my echo stopped working so I had to reset and now my devices are gone…
this is the same problem again but this time… put my ip adress into the MMM AlexaOnOff node.js helper does not workRequested network interface wlan0 not found! 21900 21901 21902 21903 21904 21905 21906 21907 21908 21909 21910 21911 21912 21913 21914 21915 21916 21917 21918 21919 21920 21921 21922 21923 21924 21925 21926 21927 21928 21929 21930 21931 21932 21933 21934 21935 21936 21937 21938 21939 21940 FauxMo service started. Listening on 127.0.0.1:21900-21940
@Stoffbeuteluwe said in MMM-Alexaonoff can’t find devices:
so, the network adapter name is wrong now
sudo ifconfig
to find the network adapter , then fix the MM config -
seems everything looks good but no devices can be found??
SONOS_UPDATE 21900 21901 21902 21903 21904 21905 21906 21907 21908 21909 21910 21911 21912 21913 21914 21915 21916 21917 21918 21919 21920 21921 21922 21923 21924 21925 21926 21927 21928 21929 21930 21931 21932 21933 21934 21935 21936 21937 21938 21939 21940 21941 FauxMo service started. Listening on 192.168.178.33:21900-21941
anybody an idea?
@Stoffbeuteluwe can u show the output of ifconfig?
This post is deleted! -
@Stoffbeuteluwe your device is en1, with that ip address… (192.168.178.33)
@sdetweil thanks will try again
@sdetweil the if config with wlan0 and 192.168.2.35 that was from your pi…
i think the only one i have done the last time …ist put my IP address in node js helper from the module than it works
but for now it’s not working
