    MMM-Alexaonoff can’t find devices
    26 Posts 2 Posters 9.8k Views 2 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @sdetweil
      @sdetweil thanks sam i will try tonight
        @sdetweil Hey Sam …congratulations you solved my biggest Problem on my mirror, now it works and all devices where found. Thanks thanks …you are the greatest :folded_hands: :slightly_smiling_face:
          sdetweil @Stoffbeuteluwe
          @Stoffbeuteluwe cool. Glad to hear it
            @sdetweil hi Sam can I ask you again ? :grinning_face:
            my echo stopped working so I had to reset and now my devices are gone…
            this is the same problem again but this time… put my ip adress into the MMM AlexaOnOff node.js helper does not work
            Requested network interface wlan0 not found!
            21900
            21901
            21902
            21903
            21904
            21905
            21906
            21907
            21908
            21909
            21910
            21911
            21912
            21913
            21914
            21915
            21916
            21917
            21918
            21919
            21920
            21921
            21922
            21923
            21924
            21925
            21926
            21927
            21928
            21929
            21930
            21931
            21932
            21933
            21934
            21935
            21936
            21937
            21938
            21939
            21940
            FauxMo service started. Listening on 127.0.0.1:21900-21940
              @Stoffbeuteluwe said in MMM-Alexaonoff can’t find devices:
              so, the network adapter name is wrong now
              sudo ifconfig
              to find the network adapter , then fix the MM config
              StoffbeuteluweS 1 Reply Last reply Reply Quote 1
                seems everything looks good but no devices can be found??
                SONOS_UPDATE
                21900
                21901
                21902
                21903
                21904
                21905
                21906
                21907
                21908
                21909
                21910
                21911
                21912
                21913
                21914
                21915
                21916
                21917
                21918
                21919
                21920
                21921
                21922
                21923
                21924
                21925
                21926
                21927
                21928
                21929
                21930
                21931
                21932
                21933
                21934
                21935
                21936
                21937
                21938
                21939
                21940
                21941
                FauxMo service started. Listening on 192.168.178.33:21900-21941
                anybody an idea?
                  @Stoffbeuteluwe can u show the output of ifconfig?
                      @Stoffbeuteluwe your device is en1, with that ip address… (192.168.178.33)
                      StoffbeuteluweS 3 Replies Last reply Reply Quote 0
                        @sdetweil thanks will try again
                          @sdetweil the if config with wlan0 and 192.168.2.35 that was from your pi…
                          i think the only one i have done the last time …ist put my IP address in node js helper from the module than it works
                          but for now it’s not working
                            @sdetweil I set the device to en1 than the network adapter is ok but no devices
                                @sdetweil I have a Mac mini, i think wlan0 never exists on my Mac
                                    @sdetweil hi Sam a month ago that was your post, you have shown me how it looks at your pi 😀
                                    my Maschine is the same
                                        @Stoffbeuteluwe so, can u go to one device and get its IP address somehow? so we can see if its on the same network address range…
                                        also wonder if the code works on Mac… open the developers window and look at the console…
                                        but u said it worked once…
                                        maybe you can look in your router dhcp clients page
                                          i can’t get alexa to discover any of virtual wemo devices
                                          StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                                            @sdetweil maybe Alexa problem
