    MMM-Alexaonoff can’t find devices
    26 Posts 2 Posters 10.7k Views 2 Watching
      sdetweil @Stoffbeuteluwe
      @Stoffbeuteluwe cool. Glad to hear it
      StoffbeuteluweS 1 Reply Last reply
      • StoffbeuteluweS
        Stoffbeuteluwe Project Sponsor @sdetweil
        @sdetweil hi Sam can I ask you again ? :grinning_face:
        my echo stopped working so I had to reset and now my devices are gone…
        this is the same problem again but this time… put my ip adress into the MMM AlexaOnOff node.js helper does not work
        Requested network interface wlan0 not found!
        21900
        21901
        21902
        21903
        21904
        21905
        21906
        21907
        21908
        21909
        21910
        21911
        21912
        21913
        21914
        21915
        21916
        21917
        21918
        21919
        21920
        21921
        21922
        21923
        21924
        21925
        21926
        21927
        21928
        21929
        21930
        21931
        21932
        21933
        21934
        21935
        21936
        21937
        21938
        21939
        21940
        FauxMo service started. Listening on 127.0.0.1:21900-21940
          @Stoffbeuteluwe said in MMM-Alexaonoff can’t find devices:
          so, the network adapter name is wrong now
          sudo ifconfig
          to find the network adapter , then fix the MM config
          • StoffbeuteluweS
            seems everything looks good but no devices can be found??
            SONOS_UPDATE
            21900
            21901
            21902
            21903
            21904
            21905
            21906
            21907
            21908
            21909
            21910
            21911
            21912
            21913
            21914
            21915
            21916
            21917
            21918
            21919
            21920
            21921
            21922
            21923
            21924
            21925
            21926
            21927
            21928
            21929
            21930
            21931
            21932
            21933
            21934
            21935
            21936
            21937
            21938
            21939
            21940
            21941
            FauxMo service started. Listening on 192.168.178.33:21900-21941
            anybody an idea?
              @Stoffbeuteluwe can u show the output of ifconfig?
              • StoffbeuteluweS
                  @Stoffbeuteluwe your device is en1, with that ip address… (192.168.178.33)
                  StoffbeuteluweS 3 Replies Last reply
                  • StoffbeuteluweS
                    @sdetweil thanks will try again
                    • StoffbeuteluweS
                      @sdetweil the if config with wlan0 and 192.168.2.35 that was from your pi…
                      i think the only one i have done the last time …ist put my IP address in node js helper from the module than it works
                      but for now it’s not working
                      • StoffbeuteluweS
                        @sdetweil I set the device to en1 than the network adapter is ok but no devices
                          • StoffbeuteluweS
                            @sdetweil I have a Mac mini, i think wlan0 never exists on my Mac
                              • StoffbeuteluweS
                                @sdetweil hi Sam a month ago that was your post, you have shown me how it looks at your pi 😀
                                my Maschine is the same
                                S 2 Replies Last reply
                                    @Stoffbeuteluwe so, can u go to one device and get its IP address somehow? so we can see if its on the same network address range…
                                    also wonder if the code works on Mac… open the developers window and look at the console…
                                    but u said it worked once…
                                    maybe you can look in your router dhcp clients page
                                      i can’t get alexa to discover any of virtual wemo devices
                                      StoffbeuteluweS 2 Replies Last reply
                                      • StoffbeuteluweS
                                        @sdetweil maybe Alexa problem
                                        • StoffbeuteluweS
                                          21901
                                          21902
                                          21903
                                          21904
                                          21905
                                          21906
                                          21907
                                          21908
                                          21909
                                          21910
                                          21911
                                          21912
                                          21913
                                          21914
                                          21915
                                          21916
                                          21917
                                          21918
                                          21919
                                          21920
                                          21921
                                          21922
                                          21923
                                          21924
                                          21925
                                          21926
                                          21927
                                          21928
                                          21929
                                          21930
                                          21931
                                          21932
                                          21933
                                          21934
                                          21935
                                          21936
                                          21937
                                          21938
                                          21939
                                          21940
                                          21941
                                           discoveryService not running +0ms
                                          FauxMo service started. Listening on 192.168.178.35:21900-21941
                                           discoveryService binding to port 1900 for ssdp discovery +2ms
                                           discoveryService server listening 0.0.0.0:1900 +164ms
                                           deviceEndpoints Setup Server running. +9ms
                                          do you know what that means?
                                            means the code in the module has setup to listen on a number of known ports that the Wemo plugs use for discovery by the alexa plugin.
                                            when alexa does home automation device discovery, it sends a broadcast message ('is anyone there?) to anything listening on those ports, and whatever is listening will respond with a predefined response (‘yes, I am here’)…
                                            the discovery code for wemo plugs was built into alexa early code… but seems that Alexa has removed that code and expects a plugin to do the work… (My opinion)
                                            a google search on ‘wemo app not finding devices’ produces a lot of info. I could never get alexa to discover my mirrors
