    MMM-Alexaonoff can’t find devices
    26 Posts 2 Posters 10.7k Views 2 Watching
    • StoffbeuteluweS
      Stoffbeuteluwe Project Sponsor @sdetweil
      @sdetweil thanks will try again
      • StoffbeuteluweS
        @sdetweil the if config with wlan0 and 192.168.2.35 that was from your pi…
        i think the only one i have done the last time …ist put my IP address in node js helper from the module than it works
        but for now it’s not working
        • StoffbeuteluweS
          @sdetweil I set the device to en1 than the network adapter is ok but no devices
            sdetweil @Stoffbeuteluwe
            StoffbeuteluweS 1 Reply Last reply
            • StoffbeuteluweS
              @sdetweil I have a Mac mini, i think wlan0 never exists on my Mac
                • StoffbeuteluweS
                  @sdetweil hi Sam a month ago that was your post, you have shown me how it looks at your pi 😀
                  my Maschine is the same
                  S 2 Replies Last reply
                      @Stoffbeuteluwe so, can u go to one device and get its IP address somehow? so we can see if its on the same network address range…
                      also wonder if the code works on Mac… open the developers window and look at the console…
                      but u said it worked once…
                      maybe you can look in your router dhcp clients page
                        i can’t get alexa to discover any of virtual wemo devices
                        StoffbeuteluweS 2 Replies Last reply
                        • StoffbeuteluweS
                          @sdetweil maybe Alexa problem
                          • StoffbeuteluweS
                            21901
                            21902
                            21903
                            21904
                            21905
                            21906
                            21907
                            21908
                            21909
                            21910
                            21911
                            21912
                            21913
                            21914
                            21915
                            21916
                            21917
                            21918
                            21919
                            21920
                            21921
                            21922
                            21923
                            21924
                            21925
                            21926
                            21927
                            21928
                            21929
                            21930
                            21931
                            21932
                            21933
                            21934
                            21935
                            21936
                            21937
                            21938
                            21939
                            21940
                            21941
                             discoveryService not running +0ms
                            FauxMo service started. Listening on 192.168.178.35:21900-21941
                             discoveryService binding to port 1900 for ssdp discovery +2ms
                             discoveryService server listening 0.0.0.0:1900 +164ms
                             deviceEndpoints Setup Server running. +9ms
                            do you know what that means?
                              @Stoffbeuteluwe said in MMM-Alexaonoff can’t find devices:
                              means the code in the module has setup to listen on a number of known ports that the Wemo plugs use for discovery by the alexa plugin.
                              when alexa does home automation device discovery, it sends a broadcast message ('is anyone there?) to anything listening on those ports, and whatever is listening will respond with a predefined response (‘yes, I am here’)…
                              the discovery code for wemo plugs was built into alexa early code… but seems that Alexa has removed that code and expects a plugin to do the work… (My opinion)
                              a google search on ‘wemo app not finding devices’ produces a lot of info. I could never get alexa to discover my mirrors
                              • StoffbeuteluweS
                                @sdetweil ok thank you for your help…
