    MMM-Alexaonoff can’t find devices
    26 Posts 2 Posters 10.2k Views 2 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @sdetweil
      @sdetweil hi Sam can I ask you again ? :grinning_face:
      my echo stopped working so I had to reset and now my devices are gone…
      this is the same problem again but this time… put my ip adress into the MMM AlexaOnOff node.js helper does not work
      Requested network interface wlan0 not found!
      21900
      21901
      21902
      21903
      21904
      21905
      21906
      21907
      21908
      21909
      21910
      21911
      21912
      21913
      21914
      21915
      21916
      21917
      21918
      21919
      21920
      21921
      21922
      21923
      21924
      21925
      21926
      21927
      21928
      21929
      21930
      21931
      21932
      21933
      21934
      21935
      21936
      21937
      21938
      21939
      21940
      FauxMo service started. Listening on 127.0.0.1:21900-21940
        sdetweil @Stoffbeuteluwe
        @Stoffbeuteluwe said in MMM-Alexaonoff can’t find devices:
        so, the network adapter name is wrong now
        sudo ifconfig
        to find the network adapter , then fix the MM config
        StoffbeuteluweS 1 Reply Last reply Reply Quote 1
          seems everything looks good but no devices can be found??
          SONOS_UPDATE
          21900
          21901
          21902
          21903
          21904
          21905
          21906
          21907
          21908
          21909
          21910
          21911
          21912
          21913
          21914
          21915
          21916
          21917
          21918
          21919
          21920
          21921
          21922
          21923
          21924
          21925
          21926
          21927
          21928
          21929
          21930
          21931
          21932
          21933
          21934
          21935
          21936
          21937
          21938
          21939
          21940
          21941
          FauxMo service started. Listening on 192.168.178.33:21900-21941
          anybody an idea?
            @Stoffbeuteluwe can u show the output of ifconfig?
                @Stoffbeuteluwe your device is en1, with that ip address… (192.168.178.33)
                StoffbeuteluweS 3 Replies Last reply Reply Quote 0
                  @sdetweil thanks will try again
                    @sdetweil the if config with wlan0 and 192.168.2.35 that was from your pi…
                    i think the only one i have done the last time …ist put my IP address in node js helper from the module than it works
                    but for now it’s not working
                      @sdetweil I set the device to en1 than the network adapter is ok but no devices
                          @sdetweil I have a Mac mini, i think wlan0 never exists on my Mac
                              @sdetweil hi Sam a month ago that was your post, you have shown me how it looks at your pi 😀
                              my Maschine is the same
                                  @Stoffbeuteluwe so, can u go to one device and get its IP address somehow? so we can see if its on the same network address range…
                                  also wonder if the code works on Mac… open the developers window and look at the console…
                                  but u said it worked once…
                                  maybe you can look in your router dhcp clients page
                                    i can’t get alexa to discover any of virtual wemo devices
                                    StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                                      @sdetweil maybe Alexa problem
                                        21901
                                        21902
                                        21903
                                        21904
                                        21905
                                        21906
                                        21907
                                        21908
                                        21909
                                        21910
                                        21911
                                        21912
                                        21913
                                        21914
                                        21915
                                        21916
                                        21917
                                        21918
                                        21919
                                        21920
                                        21921
                                        21922
                                        21923
                                        21924
                                        21925
                                        21926
                                        21927
                                        21928
                                        21929
                                        21930
                                        21931
                                        21932
                                        21933
                                        21934
                                        21935
                                        21936
                                        21937
                                        21938
                                        21939
                                        21940
                                        21941
                                         discoveryService not running +0ms
                                        FauxMo service started. Listening on 192.168.178.35:21900-21941
                                         discoveryService binding to port 1900 for ssdp discovery +2ms
                                         discoveryService server listening 0.0.0.0:1900 +164ms
                                         deviceEndpoints Setup Server running. +9ms
                                        do you know what that means?
                                          means the code in the module has setup to listen on a number of known ports that the Wemo plugs use for discovery by the alexa plugin.
                                          when alexa does home automation device discovery, it sends a broadcast message ('is anyone there?) to anything listening on those ports, and whatever is listening will respond with a predefined response (‘yes, I am here’)…
                                          the discovery code for wemo plugs was built into alexa early code… but seems that Alexa has removed that code and expects a plugin to do the work… (My opinion)
                                          a google search on ‘wemo app not finding devices’ produces a lot of info. I could never get alexa to discover my mirrors
                                            @sdetweil ok thank you for your help…
