MMM-tvservice
6 Posts 4 Posters 5.9k Views 5 Watching
    Alvinger
    MMM-tvservice is a module that turns HDMI On or Off using the tvservice program.
    I got the idea from @ianperrin when he implemented notification functionality in MMM-ModuleScheduler. I highly recommend this module for scheduling On and Off times for MMM-tvservice.
    Check out the README ad https://github.com/Alvinger/MMM-tvservice.
    A 1 Reply Last reply Oct 12, 2016, 10:57 PM Reply Quote 0
      andrewchumchal @Alvinger
        paphko
        I like the idea of having fixed times to switch the mirror on and off, thank you for contributing this module :-)
        But your config looks unnecessarily complex. I would suggest such a format:
                notification_schedule: [
                    { HDMI_ON: "30 6 * * *" },
                    { HDMI_OFF: "0 23 * * *" },
          Alvinger
          @paphko: the config is not the MMM-tvservice config, it is the MMM-ModuleScheduler config. I am using that module to send the notifications. Send your suggestions to @ianperrin who is the author of MMM-ModuleScheduler.
          However, as the MMM-ModuleScheduler needs to be generic in order to cover a vast number of use cases I think that this added complexity is not an issue.
          P 1 Reply Last reply Oct 13, 2016, 12:27 PM Reply Quote 0
            paphko @Alvinger
            @Alvinger Sorry, my fault - I indeed thought that this were the configuration of the MMM-tvservice module O:-)
            But for more convenient configuration of your module, you could consider adding some delegate to the schedule for the proposed format ;-)
            • G Offline
              gismo2006
              Hi, a little question, I read about the tvservice and that you will be to chance the console at wake up, before you can use your option. So Yesterday I found this you can use vcgencmd display_power 0 / vcgencmd display_power 1 for power down your hdmi port. And it schould be faster and you havent to chanche your console at wake up. I don´t know enough, but could it be a better option for slleping an wake up?
              Here is the link to the webpage, but its in german:
              https://pi-buch.info/tag/tvservice/
