    Removing modules
    7 Posts 3 Posters 9.2k Views 3 Watching
    • K
      killerwaffles
      Hello, i am very new to programming so i apologize in advance for asking repetitive/ dumb questions. I am wanting to remove the " US Holidays module from the screen but i am not exactly sure how to do it. Could someone please explain in detail how it can be done. I tried to delete the module in the config.js file but it seems to just blank the whole screen. Thanks for your help.
      andrewchumchalA 1 Reply Last reply
      • andrewchumchalA
        andrewchumchal @killerwaffles
        Hello @killerwaffles
        I will be glad to help you. If you look in your config file for this section
        			module: 'calendar',
        			header: 'US Holidays',
        			position: 'top_left',
        						symbol: 'calendar-check-o ',
        All you have to do is to remove these lines of code
        That should get ride of the us holidays calendar.
        • yawnsY
          yawns Moderator
          You need to remove or comment the whole block of the module. In your case I marked all lines with //
          Otherwise parsing of the config file will fail because of missing brackets or commas
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: 'en',
          	timeFormat: 24,
          	units: 'metric',
          			module: 'alert',
          			module: 'clock',
          //			module: 'calendar',
          //			header: 'US Holidays',
          //			position: 'top_left',
          //			config: {
          //				calendars: [
          //						symbol: 'calendar-check-o ',
          //						url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
          			module: 'compliments',
          			position: 'lower_third'
          			module: 'currentweather',
          			position: 'top_right',
          				locationID: '',  //ID from http://www.openweathermap.org
          				appid: 'YOUR_OPENWEATHER_API_KEY'
          			module: 'weatherforecast',
          			header: 'Weather Forecast',
          				locationID: '5128581',  //ID from http://www.openweathermap.org
          			module: 'newsfeed',
          			position: 'bottom_bar',
          				feeds: [
          						title: "New York Times",
          				showSourceTitle: true,
          				showPublishDate: true
          • K
            killerwaffles
            When i tried to just remove those lines of code, the “US Holiday” text still showed but it removed everything else. Using the // in front of the module completely removed it from the screen. Thank you all for your help.
            yawnsY 1 Reply Last reply
            • yawnsY
              yawns Moderator @killerwaffles
              @killerwaffles
              You are welcome.
              You could as well remove all lines of code you just commented out with //
              • K
                killerwaffles
                I actually tried that originally but the main MagicMirror screen popped up and it says “Please create a config file” which was a bit confusing.
                • andrewchumchalA
                  andrewchumchal
                  @killerwaffles If you were talking about the header not the calendar it self header: 'US Holidays', you could just change this part here. to say something like header: 'Events,
